overpimpledymfoam in openfoam v1912 unsteday case have not convergence |
July 15, 2020, 23:37 |
Rep Power: 6 |
I have already simulated an elliptical airfoil translation and rotation motion in 20 periods by using overpimpledymfoam. But the lift force and drag force are not converge to the same value for the different periods. I want to know the reason why the difference between two periods would happen.
July 16, 2020, 12:38 |
Rep Power: 14 |
Well, a first question to ask yourself is: is there actually a smooth, limit state pattern for this flow problem? And if so, is it indeed a pattern that has just one frequency of excitation? Are there other frequency modes? Indeed, is some form of chaotic motion expected?
I don't know what you are trying to simulate, or how you are simulating it (DES, RANS?), but these are some initial questions that I'd ask myself. Try also find examples online of others who have solved something similar, and compare. Good luck. |
July 17, 2020, 11:16 |
Rep Power: 6 |
Thank you for your reply Tobermory, the simulated case is period oscillation in platplane. Recording the relative papers validation, the simulation Cl and Cd present the period variation, rather than the simulation by myself.
July 17, 2020, 11:34 |
benoit paillard
Rep Power: 16 |
A couple of things to check: - The number of oscillations might not be sufficient. It is possible than more oscillations will bring convergence, due to the wake advection. - The usual mesh convergence check : refinement, y+, wake etc... - The number of inner iterations controlled by fvSolution: nOuterCorrectors 2; // number of pimple iterations; 1 : PISO mode nCorrectors 2; // number of p outter GAMG iteration; 0 : only pcorr nNonOrthogonalCorrectors 1; // number of p and pcorr inner GAMG iteration - Time scheme is fundamental in unsteady simulation. Backward is often very different from Euler or other 1st order schemes. - Eventually as ToberMemory said, it's possible that the oscillations remain variable from one oscillation to the next. In that case you can try to average the last oscilations, and check if you're close to experimental data. Keep in mind that wind tunnel experiments are almost always averaged as well. |
July 17, 2020, 23:34 |
Rep Power: 6 |
Dear bennn:
Your reply gives me a detailed description on the setting parmeters, than, I would try to test the case by following your suggestions. If there is any new progress, I will sort out the results and show them in here. |
September 8, 2020, 03:31 |
Rep Power: 6 |
thank you very much bennn
My problem have already solved in one object moving oscillation, your advice is very useful in my problem. |
Frequently Asked Questions about Installing OpenFOAM | wyldckat | OpenFOAM Installation | 3 | November 14, 2023 12:58 |
Some problems in naca 0012 V&V case of NASA TMR and DPW using OpenFOAM | chengdi | OpenFOAM Running, Solving & CFD | 7 | October 5, 2019 14:20 |
Suggestion for a new sub-forum at OpenFOAM's Forum | wyldckat | Site Help, Feedback & Discussions | 20 | October 28, 2014 10:04 |
New OpenFOAM Forum Structure | jola | OpenFOAM | 2 | October 19, 2011 07:55 |
Free surface boudary conditions with SOLA-VOF | Fan | Main CFD Forum | 10 | September 9, 2006 13:24 |
