Material Functions in rheoTestFoam
Like Tree1Likes
  • 1 Post By alimea
Old   July 4, 2020, 04:58
Default Material Functions in rheoTestFoam
A. Min
alimea is on a distinguished road
Dear foamers,
I used the rheological data presented in the paper entitled (attached):
http://webx.ubi.pt/~pjpo/coreia2004b.pdf
for numerical simulation of forced-convection heat transfer of PTT viscoelastic fluid. I want to calculate the material functions (Trouton ration, N1, N2 vs shear rate). In addition I want to Show the prediction of PTT model for stress ration (S = ratio of first normal stress to the shear stress), and the effect of epsilon (first parameter of PTT model) on the Trouton ratio.
My questions:
1- I used rheoTestFoam to obtain the requested material functions. I ran the problem for the FENE-CR model using rheoTestFoam in transient form and plotted the extensional viscosity against time (t/lambda). Also, I ran it for the exponential PTT (the 5-modes fluid introduced in the paper of Alves et .al) without any problem.
However, when I wanted to run the problem in ramp mode, the problem diverges. I have changed many of the parameters of the numerical solution, but I could not solve the problem.
2- I could not run the problem for a simple shear flow to obtain the shear viscosity, N1, and N2 vs shear rate. When I run it, gives me zero viscosity! It seems that the solver cannot realize the PTT model, because I ran the Herschel Bulkley without any problem.
3- A question about the material functions:
How can I calculate the stress ratio (tau_xx/tau_xy)? In simple shear flow, tau_xx is zero and in pure extensional flow, tau_xy is zero!
Thanks.
sourav90 likes this.
alimea is offline   Reply With Quote
material functions, rheofoam, viscoelasticfluid
UDF to disable wall functions Abhinand Fluent UDF and Scheme Programming 3 June 15, 2020 17:05
How to solve the boundary layer without wall functions? WhiteW OpenFOAM Running, Solving & CFD 4 January 20, 2020 05:55
CFX-solver crash with function defined material properties from data sheets oscol227 CFX 7 February 29, 2016 05:27
Wrong flow in ratating domain problem Sanyo CFX 17 August 15, 2015 07:20
Water subcooled boiling Attesz CFX 7 January 5, 2013 04:32
