Error running a Tutorial Simulation RAs-LRR
Like Tree2Likes
  • 1 Post By HPE
  • 1 Post By dlahaye
Old   July 1, 2020, 17:19
Default Error running a Tutorial Simulation RAs-LRR
Giacomo Del Bianco
Giacomodb is on a distinguished road
Dear All,
I am sorry to disturb you but I would like to ask if someone can give me some hints to solve a problem I have.
I am not a professional, I am only interested to carry out some CFD simulation with this open source software so as to learn something.
To make it easy, I am carrying out a Tutorial (https://www.cfd.at/sites/default/fil...ExampleSix.pdf).
I followed the brief: generating the file R, later changed turbolenceProperties file to LRR:
simulationType RAS;
RAS
    RASModel        LRR;
 //   RASModel        kEpsilon;
    turbulence      on;
    printCoeffs     on;
I get an error that I am not able to understand:
--> FOAM FATAL IO ERROR:
keyword div((nu*dev2(T(grad(U))))) is undefined in dictionary "/home/giacomo/OpenFOAM/giacomo-7/run/Tutorialintermedi/BackwardFacingStep_basecaseLRR/system/fvSchemes.divSchemes"
file: /home/giacomo/OpenFOAM/giacomo-7/run/Tutorialintermedi/BackwardFacingStep_basecaseLRR/system/fvSchemes.divSchemes from line 30 to line 37.
    From function const Foam::entry& Foam::dictionary::lookupEntry(const Foam::word&, bool, bool) const
    in file db/dictionary/dictionary.C at line 573.
FOAM exiting
I like to pinpoint that I made also the kEpsilon and kOmega turbolent simulations and they worked fine. I got this problem only with the LRR one. I am not able to understand why that formula is undefined.
I am using the last version of Openfoam.
Do someone has experienced this problem? I have attached the whole project folder, through the dropBox link:
https://www.dropbox.com/s/4qnyopqhyc...ation.zip?dl=0
Thank you in advance for every your reply!
Giacomo
Giacomodb is offline   Reply With Quote
Old   July 1, 2020, 18:21
HPE
HPE's Avatar
Herpes Free Engineer
HPE is on a distinguished road
add the following into "fvSchemes" under "divSchemes":
div((nu*dev2(T(grad(U))))) <numerical scheme of choice>;
For example:
div((nu*dev2(T(grad(U))))) Gauss linear;
The error hints you that a numerical scheme necessary for the equation term "div((nu*dev2(T(grad(U)))))" is missing.
lpz456 likes this.
HPE is offline   Reply With Quote
Old   July 8, 2020, 15:26
Domenico Lahaye
dlahaye is on a distinguished road
or download from
https://github.com/ziolai/software/t...tress_R_manual
anaspauzi likes this.
dlahaye is offline   Reply With Quote
openfoam lrr ras error
simpleFoam tutorial PitzDaily using Reynolds stress tensor (LRR RASModel) dlahaye OpenFOAM Running, Solving & CFD 24 August 4, 2023 15:29
Choosing l in external aero simulation & nu used in motorbike tutorial edomalley1 OpenFOAM Running, Solving & CFD 0 November 28, 2017 13:39
Simulation FPEs - turbulence for transient and steady-state? DaveR OpenFOAM Running, Solving & CFD 5 March 5, 2017 16:06
Problems while running Cold Flow simulation 3D/ requesting 2D gmtry and tutorial ICE Excalibu2r FLUENT 0 February 26, 2017 11:58
need files of tutorial 10- Simulation of Wave Generation in a Tank Jonson Main CFD Forum 0 November 14, 2013 01:18
