compressibleMultiphaseInterFoam with RAS
Like Tree1Likes
  • 1 Post By clapointe
Old   June 25, 2020, 09:43
Default compressibleMultiphaseInterFoam with RAS
GasHighSpeedMixer is on a distinguished road
Hello everybody
I'm facing some difficulties with OpenFOAM. I've already looked up some similar problems but it seems that nothing is around on the web. Therefore I've just joint this online forum.
I've already done some quite few simulations with OpenFOAM, mostly with simpleFoam or pimpleFoam. This time I'm want to simulate a gas mixing chamber with different gases (compressible, transient and with kEpsilon). I'd like to use the solver called compressibleMultiphaseInterFoam, because the species are easy to integrate (e.g. alpha.O2 in the time directory).
However, as soon as I set-up my case, the simulation aborts. The error message is attached.
Now I want to ask, if somebody has experience with this solver and can help me to avoid the error message? Unfortunately there is no comparable tutorial with this solver around (only laminar flow - I'd like to simulate with kEpsilon turbulence model).
Please let me know if you desire my case in attachement.
Kind regards and many thanks!
File Type: txt errorMessage_compressibleMultiphaseInterFoam.txt (1,004 Bytes, 11 views)
GasHighSpeedMixer is offline   Reply With Quote
Old   June 25, 2020, 20:06
clapointe is on a distinguished road
The interFoam family of solvers are generally for multiple phases -- e.g. gas/liquid. It sounds like you're interested in a single phase (but multiple species). To simulate that I suggest trying reactingFoam -- just turn combustion off.
Caelan
clapointe is offline   Reply With Quote
Old   June 26, 2020, 05:46
Caelan
It seems that you are right. Thank you for your advice. But, since there is no reaction between the gases, should I turn off the combustion or chemistry?
And another question: What indicates the dimensionless files, e.g. CO2? Is that volume fraction, mass fraction or mole fraction?
Last edited by GasHighSpeedMixer; June 26, 2020 at 05:51. Reason: Additional question
Old   June 26, 2020, 06:39
You can turn both off. It uses mass fraction.
Caelan
GasHighSpeedMixer likes this.
kepsilon, multiphase, turbulence
Error in LRR (RAS) model in OpenFOAM v4.1 Inquisitor101 OpenFOAM 4 November 29, 2023 15:11
Error running RAS kEpsilon quarkz OpenFOAM Running, Solving & CFD 1 December 31, 2018 04:10
rhoSimpleFoam searches for RAS model hamsteri15 OpenFOAM Running, Solving & CFD 3 February 10, 2016 12:00
switching from RAS to LES fedvasu OpenFOAM Running, Solving & CFD 0 December 18, 2013 09:39
Turbulence dampening due to magnetic field in LES and RAS eelcovv OpenFOAM 0 June 8, 2010 12:35
