What does "solver nth" refer to?
Like Tree2Likes
  • 1 Post By tomf
  • 1 Post By tomf
Old   June 16, 2020, 09:10
Default What does "solver nth" refer to?
Domenico Lahaye
dlahaye is on a distinguished road
What does
"rho.*"
solver nthn;
in e.g. tutorials/compressible/rhoPimpleFoam/RAS/squareBendLid/system/fvSolution refer to?
Thx, Domenico.
dlahaye is offline   Reply With Quote
Old   January 12, 2021, 05:38
Domenico Lahaye
Anybody? Thx!
Old   January 13, 2021, 09:38
Tom Fahner
tomf will become famous soon enoughtomf will become famous soon enough
Send a message via MSN to tomf Send a message via Skype™ to tomf
Hi Domenico,
I think it is just a placeholder in the sense that the rhoPimpleFoam solver needs a solver entry for rho or rhoFinal, but internally it uses always the diagonal solver. I just changed the nthn solver into xnthn and it also runs.
Using a grep nthn from my OpenFOAM installation folder only gives this output:
~/OpenFOAM/OpenFOAM-v2012>grep -r nthn .
./tutorials/compressible/rhoPimpleFoam/RAS/externalCoupledSquareBendLiq/system/fvSolution:        solver nthn;
./tutorials/compressible/rhoPimpleFoam/RAS/squareBendLiq/system/fvSolution:        solver nthn;
With diagonal or GAMG I can at least find references in code using grep.
Best Regards,
Tom
dlahaye likes this.
tomf is offline   Reply With Quote
Old   January 13, 2021, 13:42
Domenico Lahaye
Dear Tom,
Thank you for your reply.
My understanding is that rhoPimpleFoam is a pressure-based solver and that the density is updated from the pressure using the equation of state implemented in the thermodynamics as explained e.g. in this post [1].
A solver for density thus seems to be superfluous. Hence my confusion.
Could you please elaborate? Thanks, Domenico.
[1] How rho_ and psi_ are calculated in compressible solvers of OpenFOAM?
Old   January 14, 2021, 05:42
Tom Fahner
Dear Domenico,
I have to say I only tried to find any reference to the nthn part, but I just looked at the solver which reads for v2012:
rhoPimpleFoam.C:
            if (pimple.firstIter() && !pimple.SIMPLErho())
                #include "rhoEqn.H"
Based on the Make/include file I think that this rhoEqn.H is from
src/finiteVolume/cfdTools/compressible/rhoEqn.H:
    fvScalarMatrix rhoEqn
        fvm::ddt(rho)
      + fvc::div(phi)
        fvOptions(rho)
    fvOptions.constrain(rhoEqn);
    rhoEqn.solve();
    fvOptions.correct(rho);
and this solves the continuity equation for rho. I think this means that we will have mass conservation in cases there is a net influx or outflux into a cell, or is there is some source in fvOptions that creates or destroys mass. As the call to phi is explicit (fvc:div(phi)), I think this will result in a simple vector equation, or a pure diagonal matrix.
As to why this is necessary, I would have to spend more time than I have available I am afraid. I can imagine it has something to do with mesh motion at least and mass conservation as described above.
Best Regards,
Tom
dlahaye likes this.
Old   January 14, 2021, 12:08
Domenico Lahaye
Dear Tom,
This is very valuable information to receive. Sincere thanks!
Domenico.
Old   January 15, 2021, 08:32
Bloerb will become famous soon enough
I am pretty sure nthn is short for nothing. Hence no solver specified.
An easy way to see if you need to define something is to comment out the entire block:
"rho.*"
        solver nthn;
If you run your solver now you'll either get an error message that a definition for rho and maybe rhoFinal is missing, or nothing needs to be specified.
You can also try
"rho.*"
        solver banana;
Since there is definitively no banana solver, you'll get a list of all possible solvers.
Bloerb is offline   Reply With Quote
How can I refer to gas constant? KeiJun OpenFOAM Programming & Development 3 January 7, 2016 19:54
Refer an external image in figure in cfd post kar.coep ANSYS 0 July 27, 2015 07:02
RMS P-vol . what does it refer to? hmasenger CFX 5 August 23, 2013 03:14
Which Book i have to refer for Fluid dynamics? premal Main CFD Forum 0 July 28, 2012 09:20
Newbie: why don't I hear anyone refer to Re in FEM and FD methods? bzz77 Main CFD Forum 6 January 12, 2012 16:16
