6DOF with Overset in OpenFoam v1912
Like Tree1Likes
  • 1 Post By Michael@UW
Old   June 12, 2020, 12:57
Default 6DOF with Overset in OpenFoam v1912
TAKILT said
TAKILT said is on a distinguished road
I use OpenFoam v1912 to simulate the movement of the 2D object (hydrofoil in forced pitching motion and free heaving) under the force of the fluid .
I tried it using pimpleDyMFoam but mesh deformation is too big to simulate.
So now I am working on it by using oversetmesh function.
I ran some tutorials about oversetmesh but I could not use oversetmesh(overPimpleDyMFoam) with 6DOF.
How can I use oversetmesh with 6DOF?
TAKILT said is offline   Reply With Quote
Old   July 21, 2020, 13:37
Michael@UW is on a distinguished road
Include "libsixDoFRigidBodyMotion.so" in controlDict like
libs            ("liboverset.so" "libfvMotionSolvers.so" "libsixDoFRigidBodyMotion.so");
, then you should be able to use sixDoFRigidBody motion solver.
HTML Code:
valid solver types:
14
coded
displacementComponentLaplacian
displacementInterpolation
displacementLaplacian
displacementLayeredMotion
displacementSBRStress
multiSolidBodyMotionSolver
[B]sixDoFRigidBodyMotion[/B]
solidBody
solidBodyDisplacementLaplacian
surfaceAlignedSBRStress
velocityComponentLaplacian
velocityDisplacement
velocityLaplacian
Michael@UW is offline   Reply With Quote
Old   August 31, 2021, 02:27
Francisco T
frantov is on a distinguished road
Hi Michael
Do you know if is possible to model the advection of a solid inside a stream using overset methods?
Since all the functions in SolidBodyMotion require to specify a type of motion for the mesh inside (linear, oscillating etc), but for this case it would be "free motion" due to advection.
any help would be appreciated.
frantov is offline   Reply With Quote
Old   August 31, 2021, 11:48
Hi frantov,
From my knowledge, it is not possible to couple overset with this motion in current OpenFoam. The solid is free moving by the force of the fluid, so it’s a Fsi problem and you have to know the force exerted on the solid from the fluid. Maybe foam-extend has this capability, but I am not very familiar with it.
frantov likes this.
Old   August 31, 2021, 20:11
Francisco T
Thanks for your reply, yes that's what Im interested an overset mesh with free movement. I'll keep exploring OF. Good luck on your simulations!
Old   October 18, 2023, 05:43
Xin Li
YongCLee is on a distinguished road
Hi frantov,
Have you figured out this problem, I'm also interested.
YongCLee is offline   Reply With Quote
Frequently Asked Questions about Installing OpenFOAM wyldckat OpenFOAM Installation 3 November 14, 2023 12:58
2DOF Planning hull resistance study with overset CFD_fan OpenFOAM Running, Solving & CFD 7 July 13, 2021 06:03
[OpenFOAM.com] Building OpenFOAM V1912 on armh8/arm64 EternalSeekerX OpenFOAM Installation 6 May 6, 2020 20:41
[OpenFOAM.com] OpenFOAM v1912 Windows7+Docker - OF_Create_Env not working simucentral OpenFOAM Installation 2 April 29, 2020 13:14
[ANSYS Meshing] Creating a 2D Mesh with Ansys Workbench for OpenFOAM v1912 fanta ANSYS Meshing & Geometry 1 April 4, 2020 09:59
