fanPressureJump BC with buoyantPimpleFoam
Like Tree1Likes
  • 1 Post By charlesklewicki
Old   June 12, 2020, 12:34
Default fanPressureJump BC with buoyantPimpleFoam
charlesklewicki is on a distinguished road
Hi all,
I'm currently working on a project to simulate heat transfer through air in a confined space between a heating element and an evaporator and I am having trouble implementing the fanPressureJump BC. So far I have been able to setup my mesh and now I am working on adding the fanPressureJump BC to represent the evaporator blower.
I have followed the TJunctionFan tutorial and I was able to modify the tutorial by adding my own custom mesh and I get reasonable results when running pimpleFoam. The issue I am having is that when I try to switch the solver to buoyantPimpleFoam in order to incorporate buoyancy effects the fanPressureJump BC seems to cease functioning. I used the hotRoom tutorial as a starting point for the constants, fvSolution, fvSchemes, and controlDict files. I have attached images of the U magnitude results after 0.3 s from pimpleFoam and buoyantPimpleFoam and I have also attached a zipped file of the case.
Any help is much appreciated.
charlesklewicki is offline   Reply With Quote
Old   June 15, 2020, 12:19
Default p_rgh
I was able to resolve this issue by applying the fanPressureJump BC on the p_rgh file instead of the p file.
esma likes this.
Old   March 20, 2023, 03:38
ShaneheSSSS is on a distinguished road
hello,I encounter this problem as well,do you mean applying fanPressureJump BC on the system/createBafflesDict as well as the 0/p_rgh file?
Thank you in advance!
ShaneheSSSS is offline   Reply With Quote
Old   October 17, 2024, 16:42
esma is on a distinguished road
I appreciate your feedback as it saved me.
I've been struggling with a cyclic patch for the fan to work in buoyantSimpleFoam.
after applying topoSet and createBaffle to produce the patch, the solver automatically assigns the pressure jump to "p" and not "p_rgh". I copied the cyclic patch from p to p_rgh and now is functioning.
p_rgh
cyclicFaces_master
type fan;
patchType cyclic;
jump uniform 0;
value uniform 0;
jumpTable constant 15;
cyclicFaces_slave
type fan;
patchType cyclic;
value uniform 0;
esma is offline   Reply With Quote
buoyantpimplefoam, fanpressure
buoyantPimpleFoam vs. Oliveira and Issa paper MaryBau OpenFOAM 0 June 25, 2018 15:00
buoyantPimpleFoam high Courant numbers lcbuijs OpenFOAM Running, Solving & CFD 5 March 23, 2015 05:35
buoyantPimpleFoam with thermalBaffle1D: strange temperature decrease donQi OpenFOAM Running, Solving & CFD 0 July 14, 2014 21:30
buoyantPimpleFoam Convergence Issues joel.lehikoinen OpenFOAM 1 December 5, 2013 15:58
Questions about buoyantPimpleFoam and rhoPimpleFoam Mojtaba.a OpenFOAM Running, Solving & CFD 6 August 1, 2012 05:50
