scalarCodedSource fvOptions example moving heat source
Like Tree6Likes
  • 6 Post By superkelle
Old   May 28, 2020, 07:18
Post scalarCodedSource fvOptions example moving heat source
alexander thierfelder
superkelle is on a distinguished road
I had some trouble to implement a scalarCodedSource in fvOptions for rhoPimpleFoam. But I got it working and I want to share it with you, maybe it is helpful for someone, since I read some other posts that had trouble with it. Here is my example for the sqareBendLiq tutorial ( /rhoPimpleFoamTutorials/RAS/squareBendLiq/ ) , you can just create an fvOptions file in system directory and run rhoPimpleFoam after blockMesh.
It will create an sinodial moving heat source upward the stream. It has no physical meaning and was just for testing. Have fun, I will attach a gif.
https://media.giphy.com/media/lrc8Xa...G8aE/giphy.gif
  \\      /  F ield         | OpenFOAM: The Open Source CFD Toolbox
   \\    /   O peration     | Website:  https://openfoam.org
    \\  /    A nd           | Version:  7
     \\/     M anipulation  |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      fvOptions;
energySource
    type            scalarCodedSource;    //scalarSemiImplicitSource
    active          true; //for activation either don't use any "active" or use value "true", for deactivation "false"
    name            sourceTime;
    scalarCodedSourceCoeffs
        fields          (e);
        fieldNames        (e);
        name            sourceTime;
        selectionMode   all;
        codeInclude
        codeCorrect
        codeAddSup
            const Time& time = mesh().time();
            const scalarField& V = mesh_.V();
            const vectorField& C = mesh_.C();
            const scalar endTime = 0.5;
            const scalar xt = -0.45 + time.value()*2;
            const scalar yt = -0.05+0.01*sin(time.value()*100.0);
            const scalar rt = 0.00005;
            //const scalar  zt = -0.05;
            scalarField& heSource = eqn.source();
            forAll (C,i)
                const scalar & Cx =C[i].component(0);
                const scalar & Cy =C[i].component(1);
                const scalar & Cz =C[i].component(2);
                if ( (sqr(Cx-xt) + sqr(Cy-yt) ) <= rt && time.value() < endTime)
                    heSource[i] = - 2e10 * V[i];
                if (Cx <= xt && Cy >= 0.8*yt && Cy <= 1.2*yt && time.value() < endTime)
                    heSource[i] = - 5e9 * V[i];
        codeSetValue
        code
            $codeInclude
            $codeCorrect
            $codeAddSup
            $codeSetValue
    sourceTimeCoeffs
       selectionMode   all;
Last edited by superkelle; May 28, 2020 at 07:22. Reason: gif was to big, added link
superkelle is offline   Reply With Quote
Old   March 4, 2021, 16:59
Jonathan Wells
jdw135 is on a distinguished road
I am trying to get a scalarCodedSource working as well, but I am getting a warning during runtime that says "Source ICM defined for field qq but never used". Below is my fvOptions code. I would greatly appreciate any help!
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "constant";
    object      fvOptions;
energySource
        name            sourceTime;
        active          yes;
            selectionMode   all;
            fields          (qq);
            codeInclude
            codeCorrect
                Pout<< "**codeCorrect**" << endl;
            codeAddSup
                const volScalarField& rhoS = mesh_.lookupObject<volScalarField>("rho");
                const volVectorField& uS = mesh_.lookupObject<volVectorField>("U");
                const volScalarField& pS = mesh_.lookupObject<volScalarField>("p");
                scalarField& SoS = sqrt(1.4*(pS/rhoS));
                scalarField& mach = uS/SoS;
                scalarField& rhoQ = (pS*(1-(mach*mach))1005)/(1.4*(mach*mach)*287.058);
                scalarField& qq = eqn.source();
                qq -= rhoQ*V;
            codeConstrain
                Pout<< "**codeConstrain**" << endl;
            // Dummy entry. Make dependent on above to trigger recompilation
            code
                $codeInclude
                $codeCorrect
                $codeAddSup
                $codeConstrain
        sourceTimeCoeffs
            // Dummy entry
jdw135 is offline   Reply With Quote
fvoptions, moving source, scalarcodedsource
[swak4Foam] swak4foam for OpenFOAM 4.0 mnikku OpenFOAM Community Contributions 80 May 17, 2022 09:06
polynomial BC srv537 OpenFOAM Pre-Processing 4 December 3, 2016 10:07
OpenFOAM without MPI kokizzu OpenFOAM Installation 4 May 26, 2014 10:17
Moving Heat Source on a CV Tomster0815 OpenFOAM Running, Solving & CFD 8 November 3, 2013 05:10
friction forces icoFoam ofslcm OpenFOAM 3 April 7, 2012 11:57
