time varying gravity for interFoam in OpenFOAM 6
Like Tree2Likes
  • 1 Post By clapointe
Old   May 19, 2020, 15:52
Default time varying gravity for interFoam in OpenFOAM 6
Josh McCraney
joshmccraney is on a distinguished road
Hi FOAMers!
Do you know how to change gravity to a function of time? I read a thread here but this is very dated. If anyone knows how to change this I'd be very grateful!
joshmccraney is offline   Reply With Quote
Old   May 19, 2020, 18:17
clapointe is on a distinguished road
I've done something similar a long time ago, but I think the following should point you in the right direction. If you look at solvers with buoyancy you'll see
#include "readGravitationalAcceleration.H"
#include "gh.H"
in createFields. As gravity is usually constant, these lines are clearly only read once -- during simulation initialization. For gravity to very with time, though, code similar to that in the includes will need to be used every iteration.
So something like :
Create the field g and (initial) gh in create fields. Then inside the solver (probably after updating time with runTime++) something like
g = cos(t)*dimensionedScalar(gmag,dimVelocity*dimVelocity,9.81) *vector(1,0,0) + sin(t)*dimensionedScalar(gmag,dimVelocity*dimVelocity,9.81) *vector(0,1,0) //update g
//update gh, ghf
gh = g & mesh.C();
ghf = g & mesh.Cf();
Note I've not tested this, but a scan of the old thread suggests this could work. Also make sure the trig is correct!
Caelan
clapointe is offline   Reply With Quote
Old   May 20, 2020, 02:12
Josh McCraney
#include "gh.H"
So something like :
//update gh, ghf
gh = g & mesh.C();
Caelan
Thanks for the response. After discussing with peers, it seems perhaps an easier approach than altering gravity is to include a body force source term. To do this, I created a new solver (copied interFoam folder and made my own titled bfInterFoam).
The UEqn.H looks like this
    MRF.correctBoundaryVelocity(U);
    # define omega 0.05
    const dimensionedVector mySource("mySource", dimensionSet(0,1,-2,0,0,0,0), 10*Foam::sin(runTime.value()*omega)*vector(0,1,0));
    fvVectorMatrix UEqn
        fvm::ddt(rho, U) + fvm::div(rhoPhi, U)
      + MRF.DDt(rho, U)
      + turbulence->divDevRhoReff(rho, U)
        fvOptions(rho, U)
      + mysource
    UEqn.relax();
(green is what I added). When running wmake I get the error
In file included from bfInterFoam.C:142:0:
UEqn.H: In function ‘int main(int, char**)’:
UEqn.H:14:9: error: ‘mysource’ was not declared in this scope
       + mysource
UEqn.H:14:9: note: suggested alternative: ‘mySource’
       + mysource
         mySource
/opt/openfoam6/wmake/rules/General/transform:25: recipe for target '/opt/openfoam6/platforms/linux64GccDPInt32Opt/applications/solvers/multiphase/bfInterFoam/bfInterFoam.o' failed
make: *** [/opt/openfoam6/platforms/linux64GccDPInt32Opt/applications/solvers/multiphase/bfInterFoam/bfInterFoam.o] Error 1
Any idea how to declare 'mysource'?
Old   May 20, 2020, 11:40
There's a typo -- as the error message says try replacing "mysource" with "mySource".
Caelan
joshmccraney likes this.
Old   May 20, 2020, 12:23
Josh McCraney
Caelan
I feel so stupid missing mistakes like these. How did you know, so that in the future I can diagnose the issue?
Old   May 20, 2020, 12:37
The error messages are always a good place to start -- and are usually pretty helpful. Using your case as an example, the relevant bit of the message read "note: suggested alternative: ‘mySource’". Otherwise carefully looking at the new code is good practice.. there's probably a post or guide floating around with more comprehensive debugging information.
Caelan
Old   May 20, 2020, 13:06
Josh McCraney
Caelan
Got it! Thanks for your help!
pressure in incompressible solvers e.g. simpleFoam chrizzl OpenFOAM Running, Solving & CFD 13 March 28, 2017 06:49
High Courant Number @ icoFoam Artex85 OpenFOAM Running, Solving & CFD 11 February 16, 2017 14:40
Micro Scale Pore, icoFoam gooya_kabir OpenFOAM Running, Solving & CFD 2 November 2, 2013 14:58
mixerVesselAMI2D's mass is not balancing sharonyue OpenFOAM Running, Solving & CFD 6 June 10, 2013 10:34
Could anybody help me see this error and give help liugx212 OpenFOAM Running, Solving & CFD 3 January 4, 2006 19:07
