Error when running interFoam in parallel
Like Tree3Likes
  • 1 Post By HPE
  • 1 Post By tomf
  • 1 Post By tomf
Old   May 12, 2020, 18:04
Default Error when running interFoam in parallel
Carlos
cmoreno98 is on a distinguished road
I was running interFoam simulations in parallel with no problem until yesterday, that I got the following problem:
cmoreno@clufa01:~/prueba$ mpirun -np 4 interFoam -parallel | tee interFoam.log
[clufa01:24393] opal_os_dirpath_create: Error: Unable to create the sub-directory (/tmp/openmpi-sessions-cmoreno@clufa01_0/51976) of (/tmp/openmpi-sessions-cmoreno@clufa01_0/51976/0/0), mkdir failed [1]
[clufa01:24393] [[51976,0],0] ORTE_ERROR_LOG: Error in file util/session_dir.c at line 107
[clufa01:24393] [[51976,0],0] ORTE_ERROR_LOG: Error in file util/session_dir.c at line 402
[clufa01:24393] [[51976,0],0] ORTE_ERROR_LOG: Error in file ess_hnp_module.c at line 638
It looks like orte_init failed for some reason; your parallel process is
likely to abort.  There are many reasons that a parallel process can
fail during orte_init; some of which are due to configuration or
environment problems.  This failure appears to be an internal failure;
here's some additional information (which may only be relevant to an
Open MPI developer):
  orte_session_dir failed
  --> Returned value Error (-1) instead of ORTE_SUCCESS
Anyone knows how to fix it?
Thank you beforehand,
Carlos
cmoreno98 is offline   Reply With Quote
Old   May 13, 2020, 17:00
HPE
HPE's Avatar
Herpes Free Engineer
HPE is on a distinguished road
Hi
- Could you please retry to run your case?
- If the error persists, can you attach the last few hundred lines of log file?
cmoreno98 likes this.
HPE is offline   Reply With Quote
Old   May 14, 2020, 08:36
Carlos
Originally Posted by HPE View Post
Hi
inside the .log file is the following:
The simulation doesn't start.
Also when I type "cd + start of the folder name" in the console and I press tab (to not have to write the full directory name) it doesn't work:
cmoreno@clufa01:~/prueba$ cd p-bash: no se puede crear un fichero temporal para el documento-aquí: No queda espacio en el dispositivo
The translation is "a temporary file for the document cannot be created-here: there is no space left on the device"
It is strange because if I try to run the simulation without using mpirun it works perfectly (just typing interFoam), so I think it's not a problem of space.
Old   May 15, 2020, 09:40
Tom Fahner
tomf will become famous soon enoughtomf will become famous soon enough
Send a message via MSN to tomf Send a message via Skype™ to tomf
It looks like your root directory is full.
Please check if there are large tempory files in /tmp or other parts of your root directory that you can remove.
You will need root access to remove those of course.
Regards,
Tom
tomf is offline   Reply With Quote
Old   May 15, 2020, 10:51
Carlos
Regards,
Tom
I'm not used to work in Ubuntu. How do I check if the are large files in /tmp and remove them? I typed df -h and I got this:
cmoreno@clufa01:~$ df -h
S.ficheros     Tamaño Usados  Disp Uso% Montado en
udev             3,9G      0  3,9G   0% /dev
tmpfs            796M    81M  715M  11% /run
/dev/sda2         11G    11G     0 100% /
tmpfs            3,9G      0  3,9G   0% /dev/shm
tmpfs            5,0M      0  5,0M   0% /run/lock
tmpfs            3,9G      0  3,9G   0% /sys/fs/cgroup
/dev/sda1        511M   3,4M  508M   1% /boot/efi
/dev/sdb1         59G    43G   14G  76% /cluster
tmpfs            796M      0  796M   0% /run/user/1003
Old   May 15, 2020, 11:48
Tom Fahner
Ok, thanks for this information. It indeed showed that the root partition (which is mounted as '/' in linux) is full.
I would suggest the following:
su
cd /
du -h --max-depth=1
su will make you root user (you will have to type in your root password)
the second line may not be necessary, but it takes you to the main root partition.
The third line will show you the disk usage of each folder.
If the /tmp folder is large, you can probably remove some files/folder there.
Please do not touch other folders if you are not that familiar with linux.
If you are unsure, please search online for what is in what folder.
Hope this helps.
Best of luck,
Tom
Old   May 15, 2020, 11:58
Carlos
su
cd /
du -h --max-depth=1
Hope this helps.
Best of luck,
Tom
I'm not the admin of the server so I don't know the password...
cmoreno@clufa01:~$ su
Password:
su: Authentication failure
cmoreno@clufa01:~$ cd /
cmoreno@clufa01:/$ du -h --max-depth=1
16M    ./bin
du: cannot read directory './sys/fs/fuse/connections/41': Permission denied
du: cannot read directory './sys/kernel/debug': Permission denied
0    ./sys
4.4G    ./usr
du: cannot read directory './cluster/lost+found': Permission denied
du: cannot read directory './cluster/users/professors': Permission denied
etc...
Old   May 15, 2020, 12:08
Tom Fahner
In that case you would need to contact the administrator. I guess he would be able to help you further.
Regards,
Tom
[snappyHexMesh] Error while running SnappyHex in parallel mg.mithun OpenFOAM Meshing & Mesh Conversion 1 February 10, 2016 14:13
Parallel running of 3D multiphase turbulence model (unknown problem!!) MOHAMMAD67 OpenFOAM Running, Solving & CFD 7 November 23, 2015 11:53
parallel running student666 OpenFOAM Running, Solving & CFD 7 May 21, 2014 15:55
Something weird encountered when running OpenFOAM in parallel on multiple nodes xpqiu OpenFOAM Running, Solving & CFD 2 May 2, 2013 05:59
Statically Compiling OpenFOAM Issues herzfeldd OpenFOAM Installation 21 January 6, 2009 10:38
