May 5, 2020, 10:43 |
simpleFoam diverges at low Reynolds number
Charles
Rep Power: 10 |
Morning Foamers,
I used simpleFoam to simulate air flow in a complex geometry. The air flow velocity is 0.1 m/s so I thought I should use laminar flow model. It ran well (4000 iterations) and gave me result. I then checked Reynolds number. Depending on where on the geometry, I got Reynolds number between 8,700 and 37,000. So, if it is a pipe flow, it is in turbulence regime. But RAS k-epsilon model keeps giving me divergence result in the first 5 steps. I adjust initial value of k and epsilon (they are very low though) and relaxation factors and cannot get the problem resolved. Any suggestion on solving low Reynolds flow problem? Kind Regards, Charles |
May 5, 2020, 14:10 |
Andrew O. Winter
Rep Power: 11 |
This is the first thing that jumped out at me. Since your geometry is "complex," have you tried verifying the quality of your mesh using the checkMesh utility? The number of issues will be indicated by "Failed # mesh checks" at the end of the output. I would try this and see what you get in terms of skew and non-orthogonality values. If the skew is less than 2 and the non-orthogonality is below 60 degrees, then it's probably not the mesh, but if either value is higher than that I would try improving your mesh quality. There can be other issues besides these two, but they usually cause most numerical blow-up problems due to bad meshing.
Also, if you can post some images of the mesh, then maybe it would be easier to identify if there are issues. For instance, even if you don't get a bad output from the checkMesh utility, perhaps you still have large jumps in cell size that are causing your simulation to diverge. Additionally, the k-espilon model can be problematic if you have flow separation in your model. If this is the case, using the k-omega SST model is a better choice. |
May 5, 2020, 14:58 |
Charles
Rep Power: 10 |
Thanks Andrew.
I did check mesh. There is only one failure. Code:
***Max skewness = 4.84351, 2 highly skew faces detected which may impair the quality of the results As the number of cells is large (2M), it would be difficult to display the mesh in one or two images. The first question comes to me is that, why it converges well with laminar flow (can run 4000 iteration and, maybe, forever), but diverge with RAS k-epsilon model in less than 10 iterations. I dialed down the relaxation factor to 0.2 but it still diverges with the first few steps. As the velocity is low (from 0.1 m/s to 10 m/s) and flow is inside an enclosure, I'm not expecting separation. But if k-omega is stable, I don't mind to try it out. |
May 5, 2020, 17:37 |
Andrew O. Winter
Rep Power: 11 |
First of all, are you getting "bounding value" messages for the turbulence field variables, k and epsilon, in your solver output? This will tell you the turbulence model is the reason for the divergence, but it could be caused by a bad mesh rather than the model being inadequate for your case.
The skewness value you mentioned is rather high, but to know whether it is an issue or not I would try to identify if those cells are causing the divergence using a visualization. This video by the awesome Josef Nagy is helpful in showing how you can isolate elements that have poor mesh quality and then load them in ParaView. Note that Josef is using the .com version of OpenFOAM, which has additional checkMesh functionality compared to the .org version of OpenFOAM. More specifically, the -writeAllFields option is available only for the .com version, but all you really need is the -writeSets <surfaceFormat> option, where surfaceFormat can be either vtk or ensight. Once you've loaded and plotted the problematic elements, then you can also load your OpenFOAM case and create a threshold filter for one of the field variables that's blowing up to see if the region where things are blowing up overlaps with the skewed cells. If they don't overlap, that's fine. The threshold filter showing where the divergence is occurring might reveal something else bad about your mesh, which might be a notable jump in cell size (you always want smooth cell size variation if possible, which can be done using the uniform grading method in your blockMeshDict file). I also just thought of something, could you post the unmeshed geometry to show how complex it is to identify possible problem regions as well as your blockMeshDict and snappyHexMeshDict files? |
May 5, 2020, 18:51 |
Charles
Rep Power: 10 |
I will check out the video for identifying the skewed faces. Thanks. The mesh is not created by snappyHexMesh but by cfMesh. The dictionary is quite simple.
k and, especially, epsilon grew very quickly beyond the bounding values on the 1st and 2nd step, for most of time, on the 1st step. I agree that the divergence is when solving k and epsilon equations. It seems that these two equations are very sensitive to the cell quality. Is k-Omega a better choice? |
May 7, 2020, 07:58 |
Yogesh Bapat
Rep Power: 16 |
As you have not mentioned abount BCs for k and epsilon I suggest that you check these BCs. You can use intensity based on Re and hydraulic dia or turbulence length scale for epsilon.
May 7, 2020, 11:25 |
Charles
Rep Power: 10 |
Thanks Yogesh. The inlet is an duct 0.9m X 1m with velocity 0.135m/s. The Reynolds number (air) is then 8,704 (> 4,000 and thus turbulent).
Inlet boundary turbulence kinetic energy k and dissipation rate epsilon are estimated 6.8e-5 and 9.5e-8, which is very small (and I guess that is the cause of divergence). Outlet boundary condition uses inletoutlet boundary conditions with the above values. Wall boundary layer is applied to walls. |
SimpleFoam & Theater | jipai | OpenFOAM Running, Solving & CFD | 3 | June 18, 2019 11:11 |
SigFpe when running ANY application in parallel | Pj. | OpenFOAM Running, Solving & CFD | 3 | April 23, 2015 15:53 |
low reynolds number models in Fluent | doug | Main CFD Forum | 6 | August 4, 2012 15:39 |
DecomposePar unequal number of shared faces | maka | OpenFOAM Pre-Processing | 6 | August 12, 2010 10:01 |
Multicomponent fluid | Andrea | CFX | 2 | October 11, 2004 06:12 |
