April 24, 2020, 12:50 |
Semi-implicit method MULES
Diego Jerez
Rep Power: 6 |
Hi to all,
I found that MULES method can be used as a semi implicit method, but I really dont understand very well how this works. On the page where this method is presented says: "It first executes an implicit predictor step, based on purely bounded numerical operators, e.g. Euler implicit in time, upwind for convection, etc., before constructing an explicit correction on which the MULES limiter is applied. This approach maintains boundedness and stability at an arbitrarily large Courant number." So, firts calculate the cell with implicit method and then use an explicit correction with courant number? how is that, choose other delta t? Sorry if a asking questions with no sense, im a begginer in OpenFOAM. Greetings! |
April 9, 2022, 17:13 |
qutadah
Rep Power: 5 |
I see no one has answered your question, I have another question, since it says semi-implicit is introduced i think in version 2.14, and now its version 9, which method is the standard MULES, semi-implicit or explicit?
April 10, 2022, 09:24 |
Rep Power: 21 |
"alpha.liquid.*" { cAlpha 0; nAlphaCorr 2; nAlphaSubCycles 2; MULESCorr yes; nLimiterIter 1; solver smoothSolver; smoother symGaussSeidel; tolerance 1e-8; relTol 0; } The semi-implicit version of MULES can be switched on through the MULESCorr switch. Hasn't changed since it's release in 2.3.0 |
April 11, 2022, 01:04 |
qutadah
Rep Power: 5 |
thank you, how do I know if my MULES algorithm is operating in the PIMPLE or PISO mode? Did I understand this correctly? It uses the subcycling but each individual subcycle operates normally as a PIMPLE/PISO algorithm?
Can I force it to work in one mode or another ? Or does it fully depend on what values i used for the nOuterCorrectors? Thanks! |
implicit enthalpy method for phase change | libya81 | System Analysis | 0 | April 8, 2015 00:28 |
On the alpha Eqn of VOF method when using Immersed boundary method in OpenFOAM | keepfit | OpenFOAM | 4 | January 31, 2014 15:32 |
Implicit method for Navier Stokes equations | Vasiliy | Main CFD Forum | 9 | December 3, 2012 14:07 |
Alpha higher than 1 and mules implicit. | Alexpzz | Main CFD Forum | 0 | November 2, 2012 23:20 |
Implicit method of FSI | cjtune | Siemens | 0 | March 12, 2003 13:07 |
