Prevent whole domain rotating in pitching airfoil |
TWB
Rep Power: 19 ![]() |
I have a pitching airfoil case. After reading tutorials, I tried to run my case and it worked and the whole domain rotates together with the airfoil. But I prefer my domain to stay fixed and only the mesh region near the airfoil moves and morphs. How can I do that? I have also tried to use topoSet to select a region around the airfoil (airfoil) which is supposed to rotate together with the airfoil. It works but then the domain outside the region is entirely fixed with the mesh becomes distorted. So how should I handle it? I have attached the relevant files and pictures. Thanks dynamicMeshDict Code:
dynamicFvMesh dynamicMotionSolverFvMesh; motionSolverLibs ("libfvMotionSolvers.so"); motionSolver solidBody; cellZone airfoil;//none; solidBodyMotionFunction oscillatingRotatingMotion; oscillatingRotatingMotionCoeffs { origin (0.25 0.007 0.125); amplitude (0.0 0.0 10.); //units of deg omega 0.698; //units of rad/s //axis (0 0 0); } Code:
actions ( { name airfoil; type cellSet; action new; source boxToCell; sourceInfo { box (-1 -1 -1) (3 1 1); } } { name airfoil; type cellZoneSet; action new; source setToCellZone; sourceInfo { set airfoil; } } ); Code:
dimensions [0 1 0 0 0 0 0]; internalField uniform (0 0 0); boundaryField { wing { type calculated; value uniform (0 0 0); } front { type empty; } back { type empty; } ".*" { type fixedValue; value uniform (0 0 0); } airfoil { type solidBodyMotionDisplacement; solidBodyMotionFunction oscillatingRotatingMotion; oscillatingRotatingMotionCoeffs { origin (0.25 0.007 0.125); //axis (0 0 1); amplitude (0.0 0.0 10); //units of deg omega 0.698; //units of rad/s } } } |
TWB
Hi all,
I finally managed to resolve the problem. I have posted an example here for the benefit of everyone. It is a naca0012 airfoil with a naca008 flap behind. The flap is supposed to rotate. https://app.box.com/s/s968xxa6pyfum8esjjs50ttfpr3h7a7o Hope it helps! |
James Rodgers
Rep Power: 13 ![]() |
Could you re-post your solution to this please?! I'm struggling with a similar problem. Thank you
TWB
Hi jrwrodgers, I have posted the solution with the case file. Did you try it?
CFX rotating Domain | cfxbeginner | CFX | 25 | June 21, 2017 11:00 |
Periodic Pressure drop | cfd_begin | CFX | 10 | May 25, 2017 07:09 |
Domain format problem on airfoil flow simulation | andrenonaka | CFX | 14 | December 7, 2015 00:42 |
Problem with restart solution in shape_optimization.py | robyTKD | SU2 Shape Design | 21 | May 29, 2013 09:26 |
Rotating Domain | Szczepan | CFX | 8 | January 19, 2013 09:27 |
