from interFoam to interIsoFoam
Like Tree1Likes
  • 1 Post By brammekeuh987
Old   April 15, 2020, 14:05
Default from interFoam to interIsoFoam
Bram Kerkhofs1
brammekeuh987 is on a distinguished road
Hi
I'm trying to experiment with interIsoFoam.
As a source for the alpha field and the other fields, I use a case which is made with interFoam.
Problem: it looks like interIsoFoam with the isoAdvection-solver diverges.
I.e.:
first iteration, first innerloop:
isoAdvection: Before conservative bounding: min(alpha) = -1.240522232e-83, max(alpha) = 1 + 0.0005295133074
after 12 innerloops it ends this outerloop:
isoAdvection: Before conservative bounding: min(alpha) = 0, max(alpha) = 1 + 0.05453439826
Second iteration, first innerloop::
isoAdvection: Before conservative bounding: min(alpha) = 0, max(alpha) = 1 + 0.05925915669
after 13 innerloops it ends the second outerloop.
Complete residual output:
PIMPLE: iteration 13
AMI: Creating addressing and weights between 9100 source faces and 8832 target faces
AMI: Patch source sum(weights) min:0.9999303843 max:1.000053447 average:0.9999900626
AMI: Patch target sum(weights) min:0.9999507692 max:1.000064161 average:1.000016928
GAMG:  Solving for pcorr, Initial residual = 1, Final residual = 0.009026559663, No Iterations 4
GAMG:  Solving for pcorr, Initial residual = 0.002355974942, Final residual = 1.763078088e-05, No Iterations 9
GAMG:  Solving for pcorr, Initial residual = 8.719498349e-05, Final residual = 4.59847574e-07, No Iterations 6
time step continuity errors : sum local = 7.176612991e-15, global = -2.42387998e-15, cumulative = 3.276703364e-13
Number of isoAdvector surface cells = 186848
isoAdvection: Before conservative bounding: min(alpha) = 0, max(alpha) = 1 + 0.1004676957
isoAdvection: After conservative bounding: min(alpha) = 0, max(alpha) = 1 + 1.061161496e-07
isoAdvection: time consumption = 9%        Phase-1 volume fraction = 0.3363172403  Min(alpha.water) = 0  Max(alpha.water) = 1
Number of isoAdvector surface cells = 186451
isoAdvection: Before conservative bounding: min(alpha) = 0, max(alpha) = 1 + 0.08699985256
isoAdvection: After conservative bounding: min(alpha) = 0, max(alpha) = 1 + 6.039899377e-06
isoAdvection: time consumption = 10%        Phase-1 volume fraction = 0.33631726  Min(alpha.water) = 0
DILUPBiCGStab:  Solving for Ux, Initial residual = 1.069829319e-05, Final residual = 5.84321495e-17, No Iterations 2
DILUPBiCGStab:  Solving for Uy, Initial residual = 5.240697493e-06, Final residual = 3.936466577e-17, No Iterations 2
DILUPBiCGStab:  Solving for Uz, Initial residual = 7.094111304e-06, Final residual = 1.364192158e-15, No Iterations 2
GAMG:  Solving for p_rgh, Initial residual = 0.005823560349, Final residual = 4.094078189e-05, No Iterations 4
GAMG:  Solving for p_rgh, Initial residual = 0.000686784676, Final residual = 5.994351588e-06, No Iterations 5
GAMG:  Solving for p_rgh, Initial residual = 0.0001680834125, Final residual = 1.503036888e-06, No Iterations 5
time step continuity errors : sum local = 2.884203884e-11, global = 3.31358195e-14, cumulative = 3.608061559e-13
GAMG:  Solving for p_rgh, Initial residual = 7.030436671e-05, Final residual = 4.803836496e-07, No Iterations 6
GAMG:  Solving for p_rgh, Initial residual = 2.313309644e-05, Final residual = 2.1642675e-07, No Iterations 5
GAMG:  Solving for p_rgh, Initial residual = 7.406384726e-06, Final residual = 9.159079788e-10, No Iterations 41
time step continuity errors : sum local = 1.803777673e-14, global = -1.83394836e-16, cumulative = 3.606227611e-13
DILUPBiCGStab:  Solving for omega, Initial residual = 8.06232745e-07, Final residual = 6.681602759e-17, No Iterations 2
DILUPBiCGStab:  Solving for k, Initial residual = 6.124043567e-06, Final residual = 1.83465517e-16, No Iterations 2
DILUPBiCGStab:  Solving for ReThetat, Initial residual = 4.492151369e-06, Final residual = 1.538420557e-15, No Iterations 2
DILUPBiCGStab:  Solving for gammaInt, Initial residual = 9.401681685e-06, Final residual = 1.569161983e-16, No Iterations 2
PIMPLE: converged in 13 iterations
As you can see the other residuals stay more or less in check. time consumption of the isoAdvection does rise.
So the first iteration takes 12 innerloops, the second one 13, the third one 14
and the forth one I stopped after 39 innerloops. Reason why they don't converge anymore is because the U-residuals are getting messed-up and don't get below 1e-5 anymore.
The isoAdvection residual for this 39'th innerloop was:
isoAdvection: Before conservative bounding: min(alpha) = 0, max(alpha) = 1 + 0.1084360555
As reference: with interFoam it takes 4 innerloops to converge.
Since the alpha-solver diverges, it's my number 1 suspect of messing up the simulation. I tried to manipulate the alpha-field in advance. So I clipped (rounded) all the alpha-values to 1, 0.5 or 0. This made some more contrast in the field. Results are shown in before_clipping.png and after_clipping.png But this didn't help.
The results of the above iterations were with the case where the values were clipped. When the values aren't clipped, the simulation derails within the first iteration: it just never converges. The isoAdvection-residual becomes something like:
isoAdvection: Before conservative bounding: min(alpha) = -20, max(alpha) = 1 + 60
The Courant numbers don't get really high:
Courant Number mean: 0.0002644452277 max: 0.4862678596        Interface Courant Number mean: 1.950778666e-06 max: 0.002363813456
The case is kind of big (~1GB), so I try to solve it without the need to upload it.
The fvSolution:
	//INTERFOAM
    "alpha.water.*"
        nAlphaCorr        2;
        nAlphaSubCycles     2;
        cAlpha              1;
		//interfaceMethod "isoAdvector"; // interIsoFoam
        MULESCorr       yes;
        nLimiterIter    15;
        alphaApplyPrevCorr  yes;
        solver          smoothSolver;
        smoother        symGaussSeidel;
        tolerance       1e-10;
        relTol          0;
        minIter         1;
		maxIter		100;
		//interIsoFoam:
		isofaceTol		1e-7; 	// Error tolerance on alph when cutting surface cells into sub-cells // interIsoFoam
		surfCellTol		1e-6 ;	// Only cells with surfCellTol < alpha < 1- surfCellTol,  are treated as surface cells //interIsoFoam
		nAlphaBounds	3;		//Number of times the ad-hoc bounding step should try to correct unboundedness.
								//Strictly volume conserving (provided that sum(phi)=0 for a cell) // interIsoFoam
		snapTol			1e-12; 	//Optional: cells with alpha < snaphAlphaTol are snapped to 0 and cells with 1- alpha < snaphAlphaTol are snapped to 1 // interIsoFoam
		clip			true; 	//Optional: clip remaining unboudedness // interIsoFoam
		//If present, the following variables can be removed from alpha.water in fvSolution:
		nAlphaCorr
		MULESCorr
		nLimiterIter
		solver
		smoother
		tolerance
		relTol
    ".*(rho|rhoFinal)"
        solver          diagonal;
    cellDisplacement
        solver          GAMG;
        smoother        GaussSeidel;
        tolerance       1e-7;
        relTol          0.001;
    "(p_rgh|pcorr.*)"
	solver          GAMG; // GAMG PBiCGStab PCG smoothSolver
        //tolerance       1e-07;
	tolerance		1e-09; //interIsoFoam, the tolerance needs to be < 10 -100 times surfCellTol
        relTol          0.01;
        maxIter         100;
        minIter         2;
        cacheAgglomeration true;
        agglomerator    faceAreaPair;
        nCellsInCoarsestLevel 1200;
 //       mergeLevels     1;
        smoother        DIC;//symGaussSeidel;//GaussSeidel;
//	nSweep		1; //Voor DIC-smoother
//        nPreSweeps      0;
	nPostSweeps     3; //2 B
//	postSweepsLevelMultiplier 1;
//	maxPostSweeps   4;
//	nFinestSweeps   2;
//	scaleCorrection true;
    "(p_rgh)Final"
        $p_rgh;
        tolerance       1e-09;
        relTol          0;
	maxIter 	150;
My current OF-version is V1906.
Anyone any idea how I get this working? Are there any other suspects I'm not getting?
Cheers!
Bram
Aabadani likes this.
brammekeuh987 is offline   Reply With Quote
Old   April 17, 2020, 11:28
Santiago Lopez Castano
Santiago is on a distinguished road
Originally Posted by brammekeuh987 View Post
Hi
I.e.:
The fvSolution:
	//INTERFOAM
    "alpha.water.*"
        nAlphaCorr        2;
        nAlphaSubCycles     2;
        cAlpha              1;
        MULESCorr       yes;
        nLimiterIter    15;
        tolerance       1e-10;
        relTol          0;
        minIter         1;
		maxIter		100;
		//interIsoFoam:
		nAlphaCorr
		MULESCorr
		nLimiterIter
		solver
		smoother
		tolerance
		relTol
    ".*(rho|rhoFinal)"
        solver          diagonal;
    cellDisplacement
        solver          GAMG;
        tolerance       1e-7;
        relTol          0.001;
    "(p_rgh|pcorr.*)"
        //tolerance       1e-07;
        relTol          0.01;
        maxIter         100;
        minIter         2;
 //       mergeLevels     1;
//        nPreSweeps      0;
//	maxPostSweeps   4;
//	nFinestSweeps   2;
    "(p_rgh)Final"
        $p_rgh;
        tolerance       1e-09;
        relTol          0;
	maxIter 	150;
Cheers!
Bram
You shouldn't be reconstructing the free-furface for each inner pimple loop, because there is no real time-advance in said inner loops! If the free surface doesn't stay put then how do you expect the inner SIMPLE cycles to converge?
Adjust the free-surface once, at the first PIMPLE loop, and then go on with the rest of the pimple loops WITHOUT updating the free surface.
MY TWO CENTS....
Santiago is offline   Reply With Quote
Old   April 18, 2020, 08:52
Bram Kerkhofs1
Hi Santiago
Thanks for your input!
So I looked at the tutorials and indeed: they run in 'PISO'-mode, no additional internal pimple loops! This looks kind of a big thing to mention, since this ain't the real 'pimple'-philosophy where you can get larger timesteps, residual parameters on convergence, .... .
So I guess there is no other way to make the solver only do the alpha calculation once, than setting the nOuterCorrectors to 0 (PISO-mode)?
I tried the simulation in PISO-mode.
at the first time step:
second time step:
isoAdvection: Before conservative bounding: min(alpha) = 0, max(alpha) = 1 + 0.01646964113
third time step:
isoAdvection: Before conservative bounding: min(alpha) = 0, max(alpha) = 1 + 0.06370722414
the last step before I stopped the simulation:
isoAdvection: Before conservative bounding: min(alpha) = -2.179964275, max(alpha) = 1 + 6.860999516
So it looks like it didn't really change the outcome
interfoam, interisofoam, isoadvector
Adding diffusion term to interFoam transport equation Gearb0x OpenFOAM Programming & Development 3 February 14, 2023 05:16
interFoam vs. simpleFoam channel flow comparison DanM OpenFOAM Running, Solving & CFD 12 January 31, 2020 16:26
Question about interFoam Solver Kahnbein.Kai OpenFOAM Running, Solving & CFD 2 August 26, 2019 16:36
interFoam (HELYX-OS) pressure boundary conditions SFr OpenFOAM Running, Solving & CFD 8 June 23, 2016 17:36
k-e & GAMG interFoam Schemitisation Stability Issue JFM OpenFOAM Running, Solving & CFD 3 December 1, 2015 06:58
