Checking time of a simulation
Like Tree2Likes
  • 1 Post By HPE
  • 1 Post By HPE
Old   April 14, 2020, 14:08
Default Checking time of a simulation
Josh McCraney
joshmccraney is on a distinguished road
Hi all!
When running a simulation, say something like this:
mpirun -np 16 interFoam -parallel > log.interFoam &
the terminal does not display an output. So how can I tell what time the simulation is at (not clocktime, but the simulation time)?
joshmccraney is offline   Reply With Quote
Old   April 14, 2020, 15:04
HPE
HPE's Avatar
Herpes Free Engineer
HPE is on a distinguished road
Hope understood your question correctly.
You direct the standard stream (excluding errors?) into the file `log.interFoam` by using `>` operator.
If you would like to see the accumulating content of `log.interFoam`, open another terminal at the same location, and do `tail -f log.interFoam`, which will output whatever recorded into the log file to the screen.
If you only would like to see the output, but not to save it to a file, just `mpirun -np 16 interFoam -parallel` will output to the screen.
joshmccraney likes this.
HPE is offline   Reply With Quote
Old   April 14, 2020, 15:10
Josh McCraney
Perfect and thanks!
Followup: if I want to kill the process, typically I would type ctrl+c. How would I do it for this?
Old   April 14, 2020, 17:39
HPE
HPE's Avatar
Yes, that would do. You can also change the `endTime` settings in `controlDict` if you would like to have an early exit.
bash script for pseudo-parallel usage of reconstructPar kwardle OpenFOAM Post-Processing 42 May 8, 2024 00:17
[Other] Contribution a new utility: refine wall layer mesh based on yPlus field lakeat OpenFOAM Community Contributions 58 December 23, 2021 03:36
pimpleDyMFoam computation randomly stops babapeti OpenFOAM Running, Solving & CFD 5 January 24, 2018 06:28
HiFiLES installation problem Eric Brant SU2 0 October 31, 2016 21:11
Stuck in a Rut- interDyMFoam! xoitx OpenFOAM Running, Solving & CFD 14 March 25, 2016 08:09
