Difference between specified and calculated mass flow rate
Like Tree1Likes
  • 1 Post By mm66
Old   April 13, 2020, 18:52
Question Difference between specified and calculated mass flow rate
mm66 is on a distinguished road
Hi Foamers,
I am facing a problem with icoReactingMultiphaseInterFoam solver. In U boundary condition, I have specified the inlet mass flow rate as:
Inlet
        type        	flowRateInletVelocity;
        massFlowRate    constant 0.00785;
        value           $internalField;
But the solver returns:
Expression patchMassFlow on Inlet:  sum=-6.15397e-06
I have the following in controlDict:
	patchMassFlow
		type			patchExpression;
		accumulations (
			sum
		patches (
			Inlet
			Outlet
		expression		"phi";
		verbose			true;
		outputControlMode	timeStep;
		outputInterval		1;
		writeStartTime		2;
		allowCoupled		true;
Any ideas? Thanks
Regards,
MJ
HHK_1702 likes this.
mm66 is offline   Reply With Quote
Old   April 13, 2020, 18:58
Seems that it is being divided by the density (according to the inlet VOF). But why is the mass flow being divided by density?!!
Old   April 14, 2020, 18:24
Question
Anyone please? So confused here
More info for Gas:
thermoType
    type            heRhoThermo;
    mixture         pureMixture;
    transport       const;
    thermo          hConst;
    equationOfState incompressiblePerfectGas;
    specie          specie;
    energy          sensibleEnthalpy;
And for Liquid:
thermoType
    type            heRhoThermo;
    transport       const;
    thermo          hConst;
    equationOfState rhoConst;
    specie          specie;
Old   April 15, 2020, 10:12
Troy Snyder
tas38 is on a distinguished road
I believe you need to add the following to the 'flowRateInletVelocity' bc in order for it to be interpreted as mass flow rather than volumetric flow...
rho  rho;
tas38 is offline   Reply With Quote
Old   April 15, 2020, 10:19
Question
rho  rho;
Dear Troy,
Thanks a lot for your reply. I tried and specified rho as you mentioned but the solver still returns the same value (ignoring rho?). Don't know what is causing this
Regards,
MJ
Old   April 15, 2020, 10:30
Troy Snyder
I assume that the 'patchMassFlow' value you have quoted corresponds to the converged solution and not some intermediate step?
What results do you get for the inlet mass flowrate using the postprocessing utility? E.g.
postProcess -func 'flowRatePatch(name=Inlet)'
Old   April 15, 2020, 10:41
Question
Thanks Troy. Yes, it is for the converged solution. Here is an example:
ExecutionTime = 5.3 s  ClockTime = 5 s
Expression patchMassFlow on Inlet:  sum=-5.53761e-05
Expression patchMassFlow on Outlet:  sum=5.53761e-05
fieldAverage fieldAverage1 write:
    Calculating averages
Courant Number mean: 0.00156158 max: 1.5566
Interface Courant Number mean: 1.55945e-05 max: 0.991976
Maximum ddtAlpha : 8.60109e-16
Maximum DiffNum : 0
deltaT = 1.63891e-06
Time = 0.00101337
I also tried postProcess as you mentioned, it returns the same value, for example:
Time = 0.005
Reading fields:
    surfaceScalarField: phi
Executing functionObjects
surfaceFieldValue flowRatePatch(name=Inlet) write:
    sum(Inlet) of phi = -5.53761e-05
Old   April 15, 2020, 10:46
Peter Hess
peterhess is on a distinguished road
See 1.43:
https://k.kakaocdn.net/dn/cjKN6m/btq...&knm=tfile.pdf
Regards
Peter
peterhess is offline   Reply With Quote
Old   April 15, 2020, 11:40
Question
Originally Posted by peterhess View Post
Hi Peter,
Thanks for your reply. I updated the U boundary condition accordingly:
Inlet
        massFlowRate		0.00785;
	extrapolateProfile	yes;
	rho			rho;
        rhoInlet		140.14;
        value			uniform (0 0 0);
Still getting the same value
Old   April 15, 2020, 11:45
Troy Snyder
What is being set for the phase fraction (alpha) fields at the inlet? Is it single phase or some mixture of liquid and gas?
Old   April 15, 2020, 11:49
It is 90% gas:
    Inlet
        type            fixedValue;
        value           uniform 0.9;
or 10% liquid:
    Inlet
        type            fixedValue;
        value           uniform 0.1;
Old   April 15, 2020, 12:04
Troy Snyder
It appears that the behavior of the bc does not change from volume flow to mass flow despite the specification of rho and/or rhoInlet. The simplest solution would then be to specify the desired volumetric flow at the inlet. This is easy enough given that you have prescribed alpha.
It remains unclear, however, why the solver does not interaction with the bc in the manner typical of single phase flows. I have used the 'flowRateInletVelocity' bc previously for single phase simulations (simpleFoam and pimpleFoam) and the behavior most certainly changes following specification of rho.
Old   April 15, 2020, 12:20
Question
  #13
Yes, exactly. I have also worked with flowRateInletVelocity several times with no problem but this one looks different.
I have just specified the equivalent volumetricFlowRate the result is almost the same
I have also tried the equivalent velocity (fixedValue) for the boundary. Still getting values at the same order of magnitude (i.e. e-5)!!!
Old   April 18, 2020, 08:49
Bloerb will become famous soon enough
icoReactingMultiphaseInterFoam is an incompressible solver. Incompressible solvers are internally using a pressure divided by density for numerical efficiency. Hence phi might be u*A not rho*u*A. Please check the unit inside the phi file in one of your results directories. If that is the case "sum phi" will return the volumetric flow rate not the mass flowrate.
Bloerb is offline   Reply With Quote
Old   April 18, 2020, 09:04
Troy Snyder
While this is true, I think a bigger issue that the thread originator is having relates to the inlet boundary conditions. Changing the nature of the boundary condition to/from volumetric flowrate, mass flowrate, or prescribed velocity does not seem to illicit the desired response in the simulation. This issue seems to be related to the multiphase solver employed as both myself and the thread originator have successfully applied such inlet bcs for single phase simulations (simpleFoam, pimpleFoam, etc.).
Old   April 18, 2020, 13:38
i have looked it up. The solver uses two fields, phi, volumetric flux, and rhoPhi mass flux. Hence my assumption is correct that you calculated it wrong with your function object.
the inflow boundary condition does the following to calculate the patch value:
const scalar avgU = -flowRate_->value(t)/gSum(rho*patch().magSf());
operator==(avgU*n);
  • minus for inlow (negativ n direction is inside)
  • flowRate_->value(t) is the function1 value (value at the current time) of the volumetric flowrate or massflowrate (you can prescribe it as a function or table etc, in your case constant)
  • gSum(rho*patch().magSf()) means sum up all faces density*area values
if a volumetric flow rate is prescribed rho=1 else
                patch().lookupPatchField<volScalarField, scalar>(rhoName_);            const fvPatchField<scalar>& rhop =
the density name of the solver is rho and rhoName defaults to that, hence i do not see an issue with the boundary condition. You might have to check the rho file. Since it is created by default, it might not list the correct density corresponding to the alpha field at the boundary.
You should however note that is prescribes exactly one value for the entire patch, not a profile and it does not adress the phase distribution.
Old   April 18, 2020, 20:46
Question
  #17
operator==(avgU*n);
Dear Bloerb and Troy,
Thanks a lot for your time and help.
The strange thing is that regardless of the assigned value for the mass flow rate the solver returns the same patch mass flow rate value...
Bloerb, what "rho file" are you referring to?
flowrateinletvelocity, mass flow rate, mass flow rate bc, openfoamv1812
