Qeustion Regarding dimensions of UEqn.H of pisoFoam
Like Tree2Likes
  • 1 Post By Sereff
  • 1 Post By hjasak
Old   April 12, 2020, 11:36
Default Qeustion Regarding dimensions of UEqn.H of pisoFoam
Sereff
Sereff is on a distinguished road
Hi Foamers,
This might be a stupid question, but please bear with me. I am trying to understand pisoFoam source code in mathematical equations, and it is quite confusing. In UEqn.H the matrix of momentum equation for prediction stage is given by, the follwing code, and has a dimention of [m^4/s^2],
fvVectorMatrix UEqn
    fvm::ddt(U) + fvm::div(phi, U)
  + MRF.DDt(U)
  + turbulence->divDevReff(U)
    fvOptions(U)
However on the solving step we have, with dimension of [m/s^2]
solve(UEqn == -fvc::grad(p));
It seems that the UEqn is acceleration integrated over a control volume, however fvc::grad(p) on the RHS of solve() returns just acceleration. Could anyone please explain why are the dimensions not matching?
kind regards,
Sereff is offline   Reply With Quote
Old   April 12, 2020, 19:15
Hrvoje Jasak
Easy. p means P/rho, where P Is in Pascal and rho in kg/m^3
Hrvoje Jasak
Old   April 12, 2020, 20:40
Sereff
Sir thank you for you reply,
Yes, I understant that "p" in pisoFoam is dynamic pressure which means Pascal over density, which is why p has dimension of [m^2/s^2] and fvc::grad(p) has dimension of [m/s^2]. What confuses me is that in the following line,
term UEqn on the lhs has different dimension than the rhs which is -fvc::grad(p). It seems that fv<Type>Matrix class is integrated over control volume whereas the pressure gradient term isn't.
kind regards,
Old   April 13, 2020, 05:23
Troy Snyder
tas38 is on a distinguished road
kind regards,
It is unclear how you came to the conclusion that the lhs, i.e. the UEqn has units of [m^4/s^2]. It has units of [m/s^2] consistent with the pressure term to which it is equated. This units are most obvious in looking at the transient term... fvm::ddt(U). This is the first temporal derivative of the velocity field w.r.t time and has units 1/s * (m/s) = m/s^2.
tas38 is offline   Reply With Quote
Old   April 13, 2020, 09:00
Sereff
Hi tas38
thank you for you reply. I agree with you that UEqn is supposed to have dimension of [m/s^2]. However, I came to this conclusion because I included the following line after UEqn is constructed.
Info << "dimension of UEqn is: " << UEqn.dimensions() << endl;
and the terminal prints out
dimension of UEqn is: [0 4 -2 0 0 0 0]
kind regards,
ruloz likes this.
Old   April 13, 2020, 10:10
Hrvoje Jasak
Yes - at the point of solution, the equation is multiplied by the volume - as will be the case with the rhs. This is "integrated over the control volume"
Hrv
cryabroad likes this.
Hrvoje Jasak
Differences in solution method for pisoFoam and buoyantBoussinesqPisoFoam mchurchf OpenFOAM 7 August 6, 2023 10:12
pisoFoam and pimpleFoam are unstable in foam-extend 4.0/4.1 (misunderstanding ?) Kombinator OpenFOAM Running, Solving & CFD 4 January 14, 2021 05:10
pisoFoam, fully developed pipe flow using cyclic BC's thijs1909 OpenFOAM Running, Solving & CFD 17 February 21, 2018 23:07
Incompatible dimensions for operation ruben23 OpenFOAM Running, Solving & CFD 2 June 12, 2015 05:14
pisoFoam compiling error with OF 1.7.1 on MAC OSX Greg Givogue OpenFOAM Programming & Development 3 March 4, 2011 18:18
