Problem with noCombustion > rhoReactingFoam
Like Tree1Likes
  • 1 Post By rcrane22
Old   April 7, 2020, 18:44
Default Problem with noCombustion > rhoReactingFoam
IronArma is on a distinguished road
Hi Foamers,
It is few months since I have started dealing with OpenFOAM and of course i seldom run into multiple errors that i can usually takle also looking at the threads in this forum. This time i cannot manage to solve my problem.
In particular I am working on a problem that is very similar to the tutorial that you find in combustion/reactingFoam/counterFlowFlame2D. I am running the OpenFOAM v1912 version.
If i run the simulation as it is, everything works properly, however if i switch off the combustion by simply acting on the combustionProperties file:
| \\      /  F ield         | OpenFOAM: The Open Source CFD Toolbox
|  \\    /   O peration     | Version:  v1912
|   \\  /    A nd           | Website:  www.openfoam.com
|    \\/     M anipulation  |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "constant";
    object      combustionProperties;
combustionModel  noCombustion;
active  false;
noCombustionCoeffs
when i run the reactingFoam solver, the simulation is stuck at the selection of the combustion model... and the terminal freezes with this lines
Creating turbulence model.
Selecting turbulence model type laminar
Selecting laminar stress model Stokes
Creating reaction model
Selecting combustion model noCombustion
Of course, i have left unaltered all of the other files in the 0, constant and system directories.
Can you help me understanding what is going on?
IronArma is offline   Reply With Quote
Old   August 11, 2020, 14:34
Robert Crane
rcrane22 is on a distinguished road
did you ever figure this out? I am having the same problem.
rcrane22 is offline   Reply With Quote
Old   August 11, 2020, 16:32
Tobermory will become famous soon enough
Try "none" instead of "noCombustion" - that seems to work fine for me.
Tobermory is offline   Reply With Quote
Old   August 11, 2020, 17:02
Robert Crane
thank you, that worked for me as well.
Tobermory likes this.
Old   August 12, 2020, 04:29
Domenico Lahaye
dlahaye is on a distinguished road
Question: how do results, CPU run time and speed of convergence of rhoReactingFoam and reactingFoam differ for the test case considered? Thx.
dlahaye is offline   Reply With Quote
nocombustion, reactingfoam
area does not match neighbour by ... % -- possible face ordering problem St.Pacholak OpenFOAM 11 September 4, 2024 05:28
Heat Transfert, mixing problem Wazdq CFX 8 November 7, 2016 06:44
natural convection problem for a CHT problem Se-Hee CFX 2 June 10, 2007 07:29
Adiabatic and Rotating wall (Convection problem) ParodDav CFX 5 April 29, 2007 20:13
DNS to Eigenvalue -> Cauchy Problem RMG Main CFD Forum 0 February 4, 2004 06:50
