How to read values in a file to a source file? |
April 6, 2020, 12:10 |
Goon
Rep Power: 6 |
I am trying to make a PID model to control valve using an immersed boundary method of foam-extend. The inlet velocity is fixed and the valve is controlled to adjust P_goal through PID algorithm. To do so, I need to calculate the pressure difference before and after the valve.
I calculated the pressure and the result is written /postProcessing/cuttingPlane/0/faceSourcePressure.dat, which is as below Code:
# Source : sampledSurface averagingPlane # Faces : 1543 # Area : 2.825372e-03 # Time areaAverage(p) 2.000000e-03 -2.124464e+00 4.000000e-03 -3.515062e-01 6.000000e-03 2.320372e-01 8.000000e-03 2.114872e-01 1.000000e-02 2.317919e-01 ... Code:
#include "valveControl.H" #include "addToRunTimeSelectionTable.H" #include "mathematicalConstants.H" using namespace Foam::mathematicalConstant; // * * * * * * * * * * * * * * Static Data Members * * * * * * * * * * * * * // namespace Foam { namespace solidBodyMotionFunctions { defineTypeNameAndDebug(valvePIDControl, 0); addToRunTimeSelectionTable ( solidBodyMotionFunction, valvePIDControl, dictionary ); }; }; // * * * * * * * * * * * * * Private Member Functions * * * * * * * * * * * // Foam::vector Foam::solidBodyMotionFunctions::valvePIDControl::calcPosition ( const scalar t ) const { return kP_*sin(2*pi*t/pGoal_); } // * * * * * * * * * * * * * * * * Constructors * * * * * * * * * * * * * * // Foam::solidBodyMotionFunctions::valvePIDControl::valvePIDControl ( const dictionary& SBMFCoeffs, const Time& runTime ) : solidBodyMotionFunction(SBMFCoeffs, runTime), pGoal_(readScalar(SBMFCoeffs_.lookup("pGoal"))), kP_(SBMFCoeffs_.lookup("kP")), kI_(SBMFCoeffs_.lookup("kI")), kD_(SBMFCoeffs_.lookup("kD")) {} // * * * * * * * * * * * * * * * * Destructors * * * * * * * * * * * * * * * // Foam::solidBodyMotionFunctions::valvePIDControl::~valvePIDControl() {} // * * * * * * * * * * * * * * Member Functions * * * * * * * * * * * * * * // Foam::septernion Foam::solidBodyMotionFunctions::valvePIDControl::transformation() const { scalar t = time_.value(); septernion TR(calcPosition(t), quaternion::I); Info<< "solidBodyMotionFunctions::valvePIDControl::transformation(): " << "Time = " << t << " transformation: " << TR << endl; return TR; } Foam::septernion Foam::solidBodyMotionFunctions::valvePIDControl::velocity() const { scalar t = time_.value(); scalar dt = time_.deltaT().value(); septernion TV ( (calcPosition(t) - calcPosition(t - dt))/dt, quaternion::zero ); return TV; } bool Foam::solidBodyMotionFunctions::valvePIDControl::read ( const dictionary& SBMFCoeffs ) { solidBodyMotionFunction::read(SBMFCoeffs); SBMFCoeffs_.lookup("pGoal") >> pGoal_; SBMFCoeffs_.lookup("kP") >> kP_; SBMFCoeffs_.lookup("kI") >> kI_; SBMFCoeffs_.lookup("kD") >> kD_; return true; } Sincerely Goon |
April 7, 2020, 16:06 |
MD SHADAB
Rep Power: 8 |
Hi Goon,
Instead of reading the average pressure data from the dat file written by function objects, you can calculate it directly inside the code by performing the area average of pressure by looping over the all face of inlet patch/ or the face of any face zone. Or Incude the functionality of reading the file by ifstream class by giving the address of that file and read always the latest and last line of file. I hope it solves your problem. Cheers, Shadab |
April 8, 2020, 02:44 |
MD SHADAB
Rep Power: 8 |
Here is the demo code you can use it something like this.
//Average pressure calculation at 2D location // Retrieve a reference to the pressure field const volScalarField& p = obr_.lookupObject<volScalarField>(pName_); // itnerpolate onto the faces surfaceScalarField pface = fvc::interpolate(p); scalar twoDPressure(0.0); scalar twoDArea(0.0); // create a twoDfaceId_ by directly reading the patch faces and then perform this calculations forAll(twoDfaceId_, faceI){ twoDPressure += pface[twoDfaceId_[faceI]]* mesh_.magSf()[twoDfaceId_[faceI]]; twoDArea += mesh_.magSf()[twoDfaceId_[faceI]]; } // reduce for parallel running reduce(twoDPressure, sumOp<scalar>()); reduce(twoDArea, sumOp<scalar>()); twoDPressure =twoDPressure/twoDArea; Info << "2D average pressure on the " << returnReduce(twoDfaceId_.size(), sumOp<label>()) << " faces is [m2/s2]: " << twoDPressure << nl << endl; I hope it will solve your problem. Regards, Shadab |
April 8, 2020, 05:18 |
Goon
Rep Power: 6 |
I appreciate for your reply. I have three further questions.
1. Right. I think that I am implementing my code as a function object. I compile valve.c (the code that I attached) and make library file at $FOAM_USER_LIBBIN. And then add the library in the controlDict. Is it right what you mean? 2. If so, where can I add the codes that you wrote for me to my code valve.C? 3. In the part [// create a twoDfaceId_ by directly reading the patch faces], should I add additional dummy patches only to calculate the pressure? Because I need to calculate the averaged pressure at the two places (before and after valve), which are not inlet and outlet. When I use faceSource library to calculate the averaged pressure, I separately generated the patches at constant/triSurface/averagingPlane1.stl & constant/triSurface/averagingPlane2.stl. Can I still use the two patches there? I appreciate for your reply again. Thanks |
[Other] Tabulated thermophysicalProperties library | chriss85 | OpenFOAM Community Contributions | 62 | October 2, 2022 04:50 |
what is swap4foam ?? | AB08 | OpenFOAM | 28 | February 2, 2016 02:22 |
[swak4Foam] swak4foam building problem | GGerber | OpenFOAM Community Contributions | 54 | April 24, 2015 17:02 |
OpenFOAM on MinGW crosscompiler hosted on Linux | allenzhao | OpenFOAM Installation | 127 | January 30, 2009 20:08 |
DecomposePar links against liblamso0 with OpenMPI | jens_klostermann | OpenFOAM Bugs | 11 | June 28, 2007 18:51 |
