March 25, 2020, 04:58 |
reactingFoam with adpative mesh
Jie Sun
Hi everyone,
I am new to learn OpenFoam. I want to simulate the combustion process of H2/Air using reactingFoam. Due to the appending of detonation wave, high gridient happened. I used the adaptive mesh in order to distinguish the detonation wave better and added the dynamicMeshDict file into the system files. But it seems that the dynamicMeshDict not be used during the solving process. There are no errors and the results is same as which not used adaptive mesh. I am looking forward to your help. Thanks a lot. |
May 29, 2020, 02:31 |
Re
Dae Young Jun
You need to use reactingDyMFoam for dealing with dynamic mesh.
Also, even if "DyM" is not implemented on some default solvers, you can modify normal solver to "DyM" solver without difficulties. I recommend you some AMR library, which is quite sophisticated. Paper:https://www.sciencedirect.com/scienc...52711018301699 git:https://github.com/ElsevierSoftwareX/SOFTX_2018_143 |
September 9, 2022, 01:01 |
Will the reactingDyMFoam work more efficient tha reactingFoam?
I suppose it can run with coarser grid at the start. It shall be easier to setup. Right? Could you share the dynamicMeshDict? Thank you. |
detonation, reactingfoam, with adpative mesh |
[snappyHexMesh] High quality mesh for wind in complex urban environment | ziboaa | OpenFOAM Meshing & Mesh Conversion | 1 | January 12, 2021 16:33 |
decomposePar problem: Cell 0contains face labels out of range | vaina74 | OpenFOAM Pre-Processing | 37 | July 20, 2020 06:38 |
[ICEM] Bad Quality Hybrid Mesh External Flow | tim13 | ANSYS Meshing & Geometry | 0 | March 8, 2020 03:22 |
[ICEM] Problem making structural mesh on a surface | froztbear | ANSYS Meshing & Geometry | 1 | November 10, 2011 09:52 |
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! | sc298 | OpenFOAM Meshing & Mesh Conversion | 2 | March 27, 2011 22:11 |
