March 5, 2020, 13:25 |
T-junction simulation using interFoam
Carlos
Rep Power: 6 |
Hello everybody,
I'm new to OpenFOAM and I'm trying to run a simulation of a T-junction (air entering through one inlet and water through the other) in microgravity conditions (g approximately 0). Since a picture is worth a thousand words, I show you the geometry and the mesh: The mesh is done in Ansys and exported in .msh format. Then, the fluent3DMeshToFoam command is used to convert it from ASCII format to foam format. The diameter of the channels is 1 mm, through the horizontal inlet (inlet1, walls1) enters air and through the vertical inlet (inlet2, walls2) enters water, both at 0.1 m/s. I can consider the two flows to be incompressible, so I use interFoam solver. I know that the results should be something like this: Air should advance through the horizontal pipe, meet the water at the junction and generate some bubbles. But when I run the simulation, air is not advancing through the channel and it's getting 'stucked' at the inlet like this: I attach the three directories "0" (alpha.air, p_rgh and U files), "constant" (g, transportProperties and turbulenceProperties files) and "system" (controlDict, fvSchemes and fvSolution files) in the following link because I don't know where the problem is: https://www.mediafire.com/file/60tv4...ction.rar/file Some parameters:
How could I fix this problem? Thank you in advance, Carlos. |
March 6, 2020, 07:04 |
Carlos Rubio Abujas
Rep Power: 11 |
Hi Carlos,
The problem is on the boundary definition of the pressure. You have to tell OpenFOAM to calculate the required pressure to provide a specific flux, not just set it to 0. Than can be done using fixedFluxPressure BC. You have to do it with both inlet1 and inlet2. 0/p_rgh: Code:
inlet1 { type fixedFluxPressure; value uniform 0; } Hope it works! |
March 6, 2020, 12:38 |
#3 | |
Carlos
Rep Power: 6 |
But I have another problem: the simulation is not behaving as expected when the two fluids meet at the junction. These are the results at t = 0.0112 (everything is OK): This is the last time step where the results are the ones that I expect. From this point on, air and water mix in a strange way (screenshot at t = 0.0192): The Courant number blows up, causing the simulation to stop (the last directory that I obtain is t = 0.0272, when it should end at t = 0.2). I don't know if the problem is that the mesh is not good enough or that some files are not OK. For instance, inside "system" directory, I don't know if decomposeParDict or setFieldsDict are mandatory files I didn't include them... (soy nuevo en OpenFOAM y puede que haya cosas básicas que esté haciendo mal, no sé si el problema estará en el mallado o en alguno de los archivos) Anyone knows how to solve this problem? Thanks |
March 9, 2020, 04:19 |
Carlos Rubio Abujas
Rep Power: 11 |
Hello again Carlos,
It seems that you have some issues with the BC of the phases. On the file alpha.air you have fixed the value of the walls to always be 0 (water). I don't know if that is a design requirement but it seems that is blowing up your simulation. Try changing it to zeroGradient, that would make the simulation more stable. You can check your mesh using the command checkMesh, that will tell you if some mesh metrics is wrong, altough if you use an external mesher you may have that information from it. The mesh do not seem to be too distorted, although the cell size can be too big to capture the interphase properly or other flux phenomenon. If you want to play around with mesh size you can use refineMesh to create a more resolute version of the current mesh. Concerning the files you mentioned, the file decomposeParDict is for paralleling your simulation. It tells OF how to split your mesh in sections for each parallel process. The file setFieldDict is for imposing a set of values inside your domain. Neither of these file is strictly mandatory. Hope that helps you! |
March 10, 2020, 18:39 |
#5 | |||
Carlos
Rep Power: 6 |
Good night Carlos,
Using the command checkMesh on this mesh, the result is the following: Code:
/*---------------------------------------------------------------------------*\ ========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox \\ / O peration | Website: https://openfoam.org \\ / A nd | Version: 6 \\/ M anipulation | \*---------------------------------------------------------------------------*/ Build : 6-fa1285188035 Exec : checkMesh Date : Mar 10 2020 Time : 17:27:50 Host : "carlos" PID : 4375 I/O : uncollated Case : /home/carlos/OpenFOAM/carlos-6/run/prueba nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 10) allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create polyMesh for time = 0 Time = 0 Mesh stats points: 42144 internal points: 37871 faces: 227803 internal faces: 221109 cells: 95071 faces per cell: 4.72186 boundary patches: 5 point zones: 0 face zones: 1 cell zones: 1 Overall number of cells of each type: hexahedra: 7200 prisms: 54228 wedges: 0 pyramids: 0 tet wedges: 0 tetrahedra: 33643 polyhedra: 0 Checking topology... Boundary definition OK. Cell to face addressing OK. Point usage OK. Upper triangular ordering OK. Face vertices OK. Number of regions: 1 (OK). Checking patch topology for multiply connected surfaces... Patch Faces Points Surface topology inlet1 582 500 ok (non-closed singly connected) walls1 4174 2138 ok (non-closed singly connected) inlet2 756 639 ok (non-closed singly connected) walls2 600 640 ok (non-closed singly connected) outlet 582 500 ok (non-closed singly connected) Checking geometry... Overall domain bounding box (0 -0.0005 -0.0005) (0.006 0.0015 0.0005) Mesh has 3 geometric (non-empty/wedge) directions (1 1 1) Mesh has 3 solution (non-empty) directions (1 1 1) Boundary openness (-3.83452e-17 -8.17958e-17 -2.72592e-17) OK. Max cell openness = 1.39693e-15 OK. Max aspect ratio = 38.1396 OK. Minimum face area = 1.38676e-10. Maximum face area = 1.38029e-08. Face area magnitudes OK. Min volume = 5.93772e-15. Max volume = 4.59938e-13. Total volume = 5.50062e-09. Cell volumes OK. Mesh non-orthogonality Max: 58.5843 average: 13.0879 Non-orthogonality check OK. Face pyramids OK. Max skewness = 2.52523 OK. Coupled point location match (average 0) OK. Mesh OK. End Quote:
So, following your recommendations, alpha.air, p_rgh, U and controlDict files should be like this? Code:
/*--------------------------------*- C++ -*----------------------------------*\ ========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox \\ / O peration | Website: https://openfoam.org \\ / A nd | Version: 6 \\/ M anipulation | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class volScalarField; object alpha.air; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 0 0 0 0 0 0]; internalField uniform 0; boundaryField { inlet1 { type fixedValue; value uniform 1; } inlet2 { type fixedValue; value uniform 0; } walls1 { type zeroGradient; } walls2 { type zeroGradient; } outlet { type zeroGradient; } } // ************************************************************************* // Code:
/*--------------------------------*- C++ -*----------------------------------*\ ========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox \\ / O peration | Website: https://openfoam.org \\ / A nd | Version: 6 \\/ M anipulation | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class volScalarField; object p_rgh; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [1 -1 -2 0 0 0 0]; internalField uniform 0; boundaryField { inlet1 { type fixedFluxPressure; value uniform 0; } inlet2 { type fixedFluxPressure; value uniform 0; } walls1 { type zeroGradient; } walls2 { type zeroGradient; } outlet { type fixedValue; value uniform 0; //Atmospheric pressure (Pgage) } } // ************************************************************************* // Code:
/*--------------------------------*- C++ -*----------------------------------*\ ========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox \\ / O peration | Website: https://openfoam.org \\ / A nd | Version: 6 \\/ M anipulation | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class volVectorField; location "0"; object U; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 1 -1 0 0 0 0]; internalField uniform (0 0 0); boundaryField { inlet1 { type fixedValue; value uniform (0.1 0 0); } inlet2 { type fixedValue; value uniform (0 -0.1 0); } walls1 { type noSlip; } walls2 { type noSlip; } outlet { type zeroGradient; } } // ************************************************************************* // Code:
/*--------------------------------*- C++ -*----------------------------------*\ ========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox \\ / O peration | Website: https://openfoam.org \\ / A nd | Version: 6 \\/ M anipulation | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; location "system"; object controlDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // application interFoam; startFrom startTime; startTime 0; stopAt endTime; endTime 0.2; deltaT 0.000005; writeControl adjustableRunTime; writeInterval 0.0016; purgeWrite 0; writeFormat ascii; writePrecision 6; writeCompression off; timeFormat general; timePrecision 6; runTimeModifiable yes; adjustTimeStep no; maxCo 2; maxAlphaCo 1; // ************************************************************************* // It doesn't make sense and causes the Courant number to blow up after some iterations. Why is this happening? Is there a way to restrict the entrance of air into the vertical pipe? Or is happening because the cells of the mesh are not small enough? I could improve the mesh but I should decrease the time step in order to ensure that (and this simulation already took me 3.5 hours...). I would be hugely grateful if you can help me with this issue. Thank you very much, Carlos. |
March 11, 2020, 11:20 |
Carlos Rubio Abujas
Rep Power: 11 |
Hi again!
Its hard to tell... I've tried your set up and it worked for me. Maybe is related with he OF version, what version are you using? I've tried it with OF6. You can find the results and the case definition I've used here. I don't know it those are the expected results. The interface may be better resolved with a finer mesh, but that shouldn't make the entire simulation to crash. Neither the residuals nor the courant number seems to have unreasonable values. By the way, you may find interesting to use PyFoam for plotting relevant information while solving. Concerning the simulation times, you may consider using a parallel running. Add a decomposeParDict file to your system file. This file may have different configuration parameters but I recommend you to start using the scotch method, that takes care of splitting your domain for each processor. That should reduce the time of simulation. system/decomposeParDict: Code:
/*--------------------------------*- C++ -*----------------------------------*\ ========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox \\ / O peration | Website: https://openfoam.org \\ / A nd | Version: 7 \\/ M anipulation | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; location "system"; object decomposeParDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // // Change 4 to your machine number of cores. numberOfSubdomains 4; method scotch; // ************************************************************************* // Code:
# Split your domain in different regions, one for each process. decomposePar # Run in parallel. The -np value must be the same defined in the decomposeParDict mpirun -np 4 interFoam -parallel # Recompose the case to process the results reconstructPar |
March 13, 2020, 07:44 |
#7 | |||
Carlos
Rep Power: 6 |
I'm using OF6 aswell. Quote:
You say that a finer mesh shouldn't make the entire simulation to crash, but it does I have tried to make the time step smaller (from 5 to 1 ), but the Courant number gets very big and the simulation stops at time t = 0.01 s approximately (after running for 10 hours). Maybe the mesh is too fine? 500k cells are too many cells? (maybe I should try with 300k or so). I checked the mesh and it is OK: Code:
/*---------------------------------------------------------------------------*\ ========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox \\ / O peration | Website: https://openfoam.org \\ / A nd | Version: 6 \\/ M anipulation | \*---------------------------------------------------------------------------*/ Build : 6-fa1285188035 Exec : checkMesh Date : Mar 13 2020 Time : 12:27:15 Host : "carlos" PID : 2305 I/O : uncollated Case : /home/carlos/OpenFOAM/carlos-6/run/Structured/0.5_0.5_15 nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 10) allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create polyMesh for time = 0 Time = 0 Mesh stats points: 190032 internal points: 175778 faces: 1160192 internal faces: 1136584 cells: 503802 faces per cell: 4.55889 boundary patches: 5 point zones: 0 face zones: 1 cell zones: 1 Overall number of cells of each type: hexahedra: 28800 prisms: 223968 wedges: 0 pyramids: 0 tet wedges: 0 tetrahedra: 251034 polyhedra: 0 Checking topology... Boundary definition OK. Cell to face addressing OK. Point usage OK. Upper triangular ordering OK. Face vertices OK. Number of regions: 1 (OK). Checking patch topology for multiply connected surfaces... Patch Faces Points Surface topology inlet1 1418 1126 ok (non-closed singly connected) walls1 16604 8405 ok (non-closed singly connected) inlet2 1784 1413 ok (non-closed singly connected) walls2 2400 2480 ok (non-closed singly connected) outlet 1402 1118 ok (non-closed singly connected) Checking geometry... Overall domain bounding box (0 -0.0005 -0.0005) (0.006 0.0015 0.0005) Mesh has 3 geometric (non-empty/wedge) directions (1 1 1) Mesh has 3 solution (non-empty) directions (1 1 1) Boundary openness (8.67928e-17 -5.65932e-16 6.04785e-17) OK. Max cell openness = 8.52587e-16 OK. Max aspect ratio = 19.5164 OK. Minimum face area = 6.89058e-11. Maximum face area = 2.7508e-09. Face area magnitudes OK. Min volume = 1.41624e-15. Max volume = 6.88307e-14. Total volume = 5.54272e-09. Cell volumes OK. Mesh non-orthogonality Max: 60.3291 average: 14.111 Non-orthogonality check OK. Face pyramids OK. Max skewness = 2.49182 OK. Coupled point location match (average 0) OK. Mesh OK. End Code:
/*--------------------------------*- C++ -*----------------------------------*\ ========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox \\ / O peration | Website: https://openfoam.org \\ / A nd | Version: 6 \\/ M anipulation | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class volScalarField; object alpha.air; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 0 0 0 0 0 0]; internalField uniform 0; boundaryField { inlet1 { type fixedValue; value uniform 1; } inlet2 { type fixedValue; value uniform 0; } walls1 { type constantAlphaContactAngle; theta0 165; limit gradient; value uniform 0; } walls2 { type constantAlphaContactAngle; theta0 165; limit gradient; value uniform 0; } outlet { type zeroGradient; } } // ************************************************************************* // Quote:
The parallel running is great! The simulation time is really shortened. Thank you very much again I'm trying as hard as a I can to stay calm hahaha It is really hard. If you could help me with the new mesh problem I would be appreciated. Saludos, Carlos. |
March 16, 2020, 10:38 |
Carlos Rubio Abujas
Rep Power: 11 |
Refinie the mesh may increase significantly the computation time. I can help you further without more details. If you say that the computation takes almost 10h to fail... It would be nice to share the computation log instead of let me waste those 10h .
If you don't know how to log the output, you can try piping the output. Code:
# Show the results on screen AND store them into "interFoam.log" interFoam | tee interFoam.log Concerning PyFoam, altough it has been certainly written in python is not required to know python to use. When you install it (using pip its quite easy to do so) you get access to a bunch of executable fies with the name pyFoam... For example: Code:
# Launch interFoam and show the results. Automatically generates a log file. pyFoamPlotRunner interFoam # Read a log file and plot the relevant information. pyFoamPlotWatcher interFoam.log |
March 19, 2020, 09:15 |
#9 | |
Carlos
Rep Power: 6 |
I tried a new mesh of 428k cells. You can download the case folder here (I also included the .log file of the simulation). I used 2 different time steps: 2e-6 and 5e-6. I also installed PyFoam as you recommended. Results for 5e-6: - Execution time: 9h 25min - Residuals: - Courant: Results for 2e-6: - Execution time: 22h 22min - Residuals: - Courant: Comparison using ParaView: - Time = 0.0064: - Time = 0.0072: - Time = 0.008: Is it better to use a smaller time step? The max Courant number is smaller, but the results at ParaView are very simillar... I don't know if it's worth to "lose" 13h decreasing the time step to 2 microseconds when I get no substantial improvement. Another doubt that I have is that it seems that (is barely noticeable) the bubbles are being "sucked" at the outlet. There is a small bubble deformation, but I don't know why. The boundary conditions at the outlet are zeroGradient for alpha.air and U files and fixedValue (value 0) for p_rgh file. Thank you very much, Carlos. |
March 19, 2020, 10:28 |
#10 |
Carlos Rubio Abujas
Rep Power: 11 |
Hi, nice that you managed to solve it!
Concerning the mesh resolution, you have already performed some kind of mesh sensibility analisis. It is nice that the results are pretty simillar, it is a sign that you are going in the right track. What since is enough? That is something you have to determine. What is the purpuse of the simulation? Which error is acceptable? I do not know how to help you further with the outlet issue. I am vaguely aware of wave reflection issie with some BC, but I never used them neither know if there is something implemented in OF. Good luck with the model and your way with OF |
March 20, 2020, 13:05 |
#11 | |
Carlos
Rep Power: 6 |
Right now I would like to generate a plot like this: It shows the fraction of air at two given surfaces (located at x=7 and x=8 mm in this case) with respect to time. Do you know any way of generating two surfaces and extract the fraction of air at each time step? I think that I have to create some functions inside controlDict file but I don't know how to do it. Is there a way to get this information using PyFoam? The volume of the bubbles for example. It would be extremely useful. Thanks, Carlos |
October 7, 2020, 09:52 |
#12 |
najmeh
Hi Carlos
I hope you are fine. I'm trying to run a simulation of a T-junction (cold water entering through one inlet and hot water through the other) The mesh is done in Ansys and exported in .msh format. Then, the fluent3DMeshToFoam command is used to convert it from ASCII format to foam format. but I don't understand why it doesn't work. It gets an error from me and I can not see it in Paraview. Can I take your Ansys file in this example? |
October 8, 2020, 05:04 |
#13 | |
Carlos Rubio Abujas
Rep Power: 11 |
What kind of problems are you experiencing? For exporting mesh from ANSYS to OpenFoam I think its needed to ensure that they are in ASCII format. By default they are in binary, so you just need to explore the exporting options of ANSYS Meshing to do so. Try that approach or share more information of the error you have so we can assest you better. |
October 10, 2020, 20:19 |
#14 |
Andersson Romero
Rep Power: 6 |
Hi Everyone
May 20, 2022, 16:45 |
Can you help me
#15 |
mumu
Rep Power: 4 |
Hello
I'm a new OpenFOAMer and I'm trying to run a similar question. The blockMesh has always been unsuccessful, can you give me the blockMesh file? Thank you. |
May 21, 2022, 14:31 |
#16 | |
Berin Šeta
Rep Power: 12 |
BR |
July 25, 2023, 01:10 |
#17 | |
Gaurav Kumar
Rep Power: 4 |
Could you help me with a similar problem? I am trying to simulate capillary-driven flow in an open microchannel. But unfortunately with all the boundary conditions, I am getting this result: open.JPG This is obviously not correct. I am attaching my case files here: PLEASE CHECK Could you please let me know what's wrong? I am able to simulate closed channel but facing this problem in open channel. |
bubbles, interfoam, t-junction |
Transient Simulation in CFX | ashtonJ | CFX | 1 | September 28, 2018 02:18 |
restarting paused transient simulation using reactingFoam | JMDag2004 | OpenFOAM Running, Solving & CFD | 1 | August 10, 2015 11:15 |
Strange error in multithread simulation with interFoam | davidmd | OpenFOAM Running, Solving & CFD | 3 | December 13, 2014 21:45 |
setting up a simulation with multiple interactions | phandy | OpenFOAM Running, Solving & CFD | 1 | October 6, 2014 04:16 |
Discrete event simulation vs. fixed time (discrete time simulation) | jenjon | FLUENT | 0 | March 10, 2013 07:58 |
