why spray has no vapor near nozzel using sprayFoam? |
February 24, 2020, 15:45 |
Junqian CAI
Rep Power: 10 |
Hello! I found the spray vapor is absent near nozzle (red circle region) when I test sprayFoam solver in tutorial acchemBomb. Is it a physical result? Maybe the evaporation is too slow there (red circle) but I don't know how to fix it. Any help or advice will be appreciated.
February 24, 2020, 22:28 |
Junqian CAI
Rep Power: 10 |
Time is 0.00045s after injection, and the parcel image is attached. It is strange that parcel exists while vapor is absent. Maybe the reason is that liquid spray does not break up there, so there is no vapor?
February 25, 2020, 14:31 |
Rep Power: 7 |
Hello acaist,
my first suggestion is to check the parcel temperature at injection. Before they start to evaporize, the parcels need to heat up and it could be that at the temperature you are injecting, the vapor pressure is so low that vapor release is almost unperceivable. Could you color the parcels with their temperature? RP |
February 7, 2022, 05:03 |
Junqian CAI
Rep Power: 10 |
2 years later, I remember my account. Thanks your suggestion, it works. By change the fuel injected temperature from 373 K to 573 K, the problem solved.
February 7, 2022, 05:06 |
#5 | |
Junqian CAI
Rep Power: 10 |
2 years later, I finally remember my account. Thanks your suggestion, it works. By change the fuel injected temperature from 373 K to 573 K, the problem solved. |
evaporation, sprayfoam |
Help with modeling a spray from a nozzle | dmcguire123 | FLUENT | 2 | June 9, 2021 03:34 |
Can anyone suggest a good tutorial of Spray Combustion in Ansys FORTÉ? | shubhra | ANSYS | 2 | October 5, 2017 06:06 |
[sprayFoam] strange spray formation behaviour | pbalz | OpenFOAM Running, Solving & CFD | 0 | March 23, 2015 11:41 |
Spray slows then stops | coastal593 | OpenFOAM Running, Solving & CFD | 6 | July 31, 2007 16:14 |
spray injection | mmacrb | FLUENT | 0 | January 10, 2007 04:57 |
