rhoCentralFoam no converge at energy "e"
Like Tree1Likes
  • 1 Post By dennis722
Old   February 22, 2020, 03:54
Post rhoCentralFoam no converge at energy "e"
Dennis
dennis722 is on a distinguished road
Hi Guys,
I am currently simulating a helium gas tank with 660 bar at the beginning in openfoam 1712. This helium then enters a helium environment at 1 bar. So I have extremely large gradients, in the neighboring cells between 660 and 1 bar. However, the simulation does not converge with the settings in fvSolution, fvScheme and controlDict. And shows the following Error:
Error:
diagonal:  Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0
diagonal:  Solving for rhoUx, Initial residual = 0, Final residual = 0, No Iterations 0
diagonal:  Solving for rhoUy, Initial residual = 0, Final residual = 0, No Iterations 0
diagonal:  Solving for rhoUz, Initial residual = 0, Final residual = 0, No Iterations 0
smoothSolver:  Solving for Ux, Initial residual = 4.156134313229688e-09, Final residual = 4.265079601544407e-17, No Iterations 2
smoothSolver:  Solving for Uy, Initial residual = 5.497349689819279e-09, Final residual = 5.684861557058189e-17, No Iterations 2
smoothSolver:  Solving for Uz, Initial residual = 3.997193648837395e-11, Final residual = 3.997193648837395e-11, No Iterations 0
diagonal:  Solving for rhoE, Initial residual = 0, Final residual = 0, No Iterations 0
smoothSolver:  Solving for e, Initial residual = 4.275064316920496e-11, Final residual = 6.817779925127806e-14, No Iterations 2
smoothSolver:  Solving for omega, Initial residual = 5.299771101182694e-10, Final residual = 5.299771101182694e-10, No Iterations 0
smoothSolver:  Solving for k, Initial residual = 1.21586269016541e-07, Final residual = 2.371396085560514e-14, No Iterations 2
ExecutionTime = 317.15 s  ClockTime = 321 s
Mean and max Courant Numbers = 2.81431486062863e-05 0.4500049628815927
deltaT = 5.271744881150556e-10
Time = 1.356697112636851857e-06
smoothSolver:  Solving for Ux, Initial residual = 4.155135259471846e-09, Final residual = 4.308414013746852e-17, No Iterations 2
smoothSolver:  Solving for Uy, Initial residual = 5.493142623382779e-09, Final residual = 5.76015490406129e-17, No Iterations 2
smoothSolver:  Solving for Uz, Initial residual = 3.996263192897822e-11, Final residual = 3.996263192897822e-11, No Iterations 0
[245] #0  [246] #0  Foam::error::printStack(Foam::Ostream&)Foam::error::printStack(Foam::Ostream&) at ??:?
 at ??:?
[246] #1  [245] #1  Foam::sigFpe::sigHandler(int)Foam::sigFpe::sigHandler(int) at ??:?
[246] #2  ? at ??:?
[245] #2  ? in "/lib64/libc.so.6"
[246] #3  Foam::hePsiThermo<Foam::psiThermo, Foam::pureMixture<Foam::sutherlandTransport<Foam::species::thermo<Foam::hConstThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleInternalEnergy> > > >::calculate(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>&, bool) in "/lib64/libc.so.6"
[245] #3  Foam::hePsiThermo<Foam::psiThermo, Foam::pureMixture<Foam::sutherlandTransport<Foam::species::thermo<Foam::hConstThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleInternalEnergy> > > >::calculate(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>&, bool) at ??:?
[246] #4  Foam::hePsiThermo<Foam::psiThermo, Foam::pureMixture<Foam::sutherlandTransport<Foam::species::thermo<Foam::hConstThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleInternalEnergy> > > >::correct() at ??:?
[245] #4  Foam::hePsiThermo<Foam::psiThermo, Foam::pureMixture<Foam::sutherlandTransport<Foam::species::thermo<Foam::hConstThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleInternalEnergy> > > >::correct() at ??:?
[246] #5   at ??:?
[245] #5  ?? at ??:?
[246] #6  __libc_start_main at ??:?
[245] #6  __libc_start_main in "/lib64/libc.so.6"
[246] #7   in "/lib64/libc.so.6"
[245] #7  ?? at ??:?
 at ??:?
controlDict:
|  \\    /   O peration     | Version:  plus                                  |
|   \\  /    A nd           | Web:      www.OpenFOAM.com                      |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "system";
    object      controlDict;
application     rhoCentralFoam;
startFrom       startTime;//latestTime;
startTime       0;
stopAt          endTime;
endTime         2e-3;
deltaT          1e-10;
writeControl    adjustableRunTime;
writeInterval   1e-10;
purgeWrite      0;
writeFormat     ascii;
writePrecision  16;
writeCompression off;
timeFormat      general;
timePrecision   19;
runTimeModifiable true;
adjustTimeStep  yes;
maxCo           0.45;
//maxAlphaCo    0.45;
maxDeltaT       1;
functions
    #includeFunc  probes
    #includeFunc  residuals
    #includeFunc  surfaces
    MachNumber
        type               MachNo;
        libs               ("libfieldFunctionObjects.so");
        executeControl     timeStep;
        writeControl       writeTime;
fvSolution:
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "system";
    object      fvSolution;
solvers
    "(rho|rhoU|rhoE)"
        solver          diagonal; //inviscid part always solved explicit in rhoCentralFoam!!
    "(U|k|epsilon|omega|e)"
        solver          smoothSolver;
        smoother        GaussSeidel;
        nSweeps         2;
        tolerance       1e-09;
        relTol          0.01;
dennis722 is offline   Reply With Quote
Old   February 22, 2020, 03:56
Dennis
fvSchemes:
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "system";
    object      fvSchemes;
fluxScheme      Kurganov;
ddtSchemes
    default         Euler;
gradSchemes
    default         Gauss linear;
divSchemes
    default         none;
    div(tauMC)      Gauss linear;
    div(phi,omega)  Gauss upwind;
    div(phi,k)        Gauss upwind;
    div(phi,epsilon) Gauss upwind;
laplacianSchemes
    default         Gauss linear corrected;
interpolationSchemes
    default         linear;
    reconstruct(rho) vanLeer;
    reconstruct(U)  vanLeerV;
    reconstruct(T)  vanLeer;
snGradSchemes
    default         corrected;
wallDist
    method meshWave;
Old   February 22, 2020, 04:02
Dennis
So far I have found:
Using vanLeer for "reconstruct (rho / U / T)" causes the simulation to end after a few time steps with the error shown above. A change in the interpolation scheme from "reconstruct (rho)" to upwind makes the simulation work longer until it crashes with the error from above. And a change from "reconstruct (rho / U / T)" to upwind allows the simulation to converge without an error.
However, since this is hypersonic flow, an upwind scheme is not accurate enough. Therefore I would like to use a TVD scheme (e.g. vanLeer, limitedLinear, MUSCL, limitedCubic) if possible, since the developers of rhoCentralFoam also recommend using vanLeer or vanLeerV.
Maybe you have other ideas.
hogsonik likes this.
density based solver, hypersonic flow, openfoam 1712, rhocentralfoam, vanleer
Energy equation in rhoCentralFoam (revisited) usv001 OpenFOAM Programming & Development 4 September 6, 2024 08:51
Energy equation - where is the turbulent kinetic energy? usv001 OpenFOAM Programming & Development 1 January 25, 2022 16:04
Energy balance in conjugative/ porous simulation; Domain Energy is greater than Input Vishnu_bharathi CFX 2 June 27, 2018 11:08
Overall energy conservation in rhoCentralFoam dvoosten OpenFOAM Running, Solving & CFD 1 November 22, 2017 04:24
Why FVM for high-Re flows? Zhong Lei Main CFD Forum 23 May 14, 1999 14:22
