k-omega SST: what is the Reference length scale? |
February 19, 2020, 14:18 |
Andrea Stedile
Rep Power: 6 |
Hi all,
I'm trying to investigate the flow of air around a car with the RAS k-omega SST. The OpenFOAM guide: https://www.openfoam.com/documentati...omega-sst.html says that the following formula can be used to estimate omega, that is the turbulence specific dissipation rate: where L is the reference length scale, and cmu is equal to 0.09 I wanted to ask: what exactly is L? In my case, would it be the length of the car? I saw that OpenFOAM has a motorbike scenario and tutorial.
If we substitute for k, omega and Cmu, we get 3.058 m, which is different than the valur of lRef (the length of the motorbike). Therefore, I'm not anymore convinced that L is the length of the vehicle. Can anyone help me? Regards, Andrea |
February 20, 2020, 10:27 |
Rep Power: 6 |
The exact reference length is not that important afaik. The important thing is that your nu/nu_t ratio (laminar viscosity to turbulent viscosity) is small enough. This paper by Spalart & Rumsey gives some recommendations in Section C for external aerodynamics: https://ntrs.nasa.gov/archive/nasa/c...0070035069.pdf
February 20, 2020, 11:55 |
Lucky
Rep Power: 66 |
It's not the same length scale.
The length scale in forceCoeffs is related to the definition of your force coefficients like lift, and that one is a geometric length scale. The length scale in the formula for omega is a turbulent length scale for your boundary. Say if your oncoming flow comes from a fully developed flow in a duct with diameter D is a small fraction of D (usually estimated to be about L~0.07D). It's a boundary condition, you need to "know" what it is. It could be anything because not all flows come from fully developed ducts. |
February 20, 2020, 12:26 |
#4 | |
Andrea Stedile
Rep Power: 6 |
Do you have any idea on how to estimate the turbulent length scale for my case, which concerns the study of the air flow around a car, or even many cars? Can I use a value similar to the one used for the flow around the motorbike? If I do so, the yielded results seem convincing and reasonable. But I am wondering if there is a more "scientifical" sound way to do it. Also, do you know why the OpenFOAM developers have specifically chosen 3.058 as a value for the turbulent length scale? I can't seem to find the reason anywhere on the web. |
September 11, 2020, 14:39 |
João
Rep Power: 6 |
Hi everybody.
I'm studying the flow around a circular cylinder in the drag crisis region, using the kOmegaSST turbulence model. I'm struggling to find a plausible estimation for the turbulence lenght scale in the literature. What would be a good option? Thanks. |
September 27, 2021, 12:50 |
Edgar Alejandro Martínez Ojeda
Rep Power: 7 |
I made a tutorial on YT.
Here's the meshing part: https://www.youtube.com/watch?v=zWCPRhWHPqs And here is the case setup: https://www.youtube.com/watch?v=3yw6nf-bN20 Go to the video's description to get the link to the files. |
December 2, 2022, 10:48 |
#7 | |
Lorenzo Mazzei
Rep Power: 15 |
April 6, 2023, 20:34 |
#8 | |
Farzad Faraji
Rep Power: 8 |
Dear Steddy
did you find any answer for Code:
Do you have any idea on how to estimate the turbulent length scale for my case Thanks, Farzad Quote:
April 6, 2023, 20:39 |
#9 | |
Farzad Faraji
Rep Power: 8 |
Using the correct formula form here, I reversely solved motorBike problem and I got
Turbulent intensity = 0.02 turbulent length scale = 0.14 which is the 10% of Lref Thanks, Farzad Quote:
lref, motorbike, reference length, reference length scale, sst |
Turbulence length scale and integral length scale | rizhang | CFX | 2 | April 22, 2016 08:22 |
OF211: ThirdParty and /src compiled, but not /applications... | vkrastev | OpenFOAM Installation | 8 | October 18, 2012 16:53 |
Installing OpenFOAM-1.5-dev on a cluster | ZKM | OpenFOAM Installation | 4 | December 25, 2010 16:59 |
Error with Wmake | skabilan | OpenFOAM Installation | 3 | July 28, 2009 01:35 |
OpenFOAM on MinGW crosscompiler hosted on Linux | allenzhao | OpenFOAM Installation | 127 | January 30, 2009 20:08 |
