February 8, 2020, 13:22 |
kEpsilon vs. kOmegaSST
Tobias Holzmann
Rep Power: 52 |
Hi all,
just a simple question. As we all know, the kOmegaSST model is the extension of the kOmega model. In some posts I read the following which should be correct (as far as I know):
So far so good. I do have a case here, which is a freestream (such as the sandia flame). I calculated the 4 vol.-% species contour for the kEpsilon and kOmegaSST model which is different (that is obvious). What I figured out
So the question in this particular regards is:
In general, I would prefer the kEpsilon for the freestream case but for some reason, I could imagine that the kOmegaSST model predicts the turbulent quantities more accurate around the pipe which lead to the higher diffusion... I know, turbulence modeling is an own big topic and each model predicts its own values. So any hint or knowledge is recommend. Sure, I know that kOmegaSST is used widely in industries but for this problem, I am not sure if the kEpsilon fits better.
Keep foaming, Tobias Holzmann |
February 9, 2020, 12:24 |
Herpes Free Engineer
Rep Power: 13 |
Please note that kOmegaSST comprises of the standard kEpsilon in theory. Under certain conditions, it should recover to kEpsilon, therefore. So, I would stick with kOmegaSST unless otherwise suggested.
Having said that the standard kEpsilon is mostly lighter than kOmegaSST to run. Yet since floating-point computation is virtually free in 2020, unlike memory constraints, nobody should give a f.ck. However, numerical stability is another aspect kEpsilon might be less favourable, and this may tradeoff the gains you would get from kEpsilon's lightness. On the other hand, both models will provide `wrong` results. So, I would go for LES or DES or very large LES, or even LES with RANS grid. In the long term, you end up with immense amount of loss in terms of time when you stick with RANS. I might also be wrong with the above remarks. So, for them, I only cite my arse, for those who would assume their complete validity. Hope you find your answer.
The OpenFOAM community is the biggest contributor to OpenFOAM: User guide/Wiki-1/Wiki-2/Code guide/Code Wiki/Journal Nilsson/Guerrero/Holzinger/Holzmann/Nagy/Santos/Nozaki/Jasak/Primer Governance Bugs/Features: OpenFOAM (ESI-OpenCFD-Trademark) Bugs/Features: FOAM-Extend (Wikki-FSB) Bugs: OpenFOAM.org How to create a MWE New: Forkable OpenFOAM mirror |
February 9, 2020, 13:13 |
Tobias Holzmann
Rep Power: 52 |
Thanks for your thoughts.
Well, modeling in RANS seems to be old-school nowadays as the computers get more powerful and memory as well as cpu power is available and thus, LES gets more interesting. However, the point is always: wasting computational power for a more accurate results or be fine with averaged 'wrong' results. Thanks. I stay with the SST.
February 14, 2020, 01:23 |
Joe
Rep Power: 10 |
Hi Tobi. For interest sake, have you perhaps considered LRR and compare against k-e and SST?
February 14, 2020, 16:04 |
Rep Power: 13 |
Could you please elaborate why you specifically consider LRR?
Error using kOmegaSST in sprayFoam | CFDUser_ | OpenFOAM Running, Solving & CFD | 17 | November 20, 2023 16:29 |
simpleFoam kOmegaSST LowRe pressure divergence | Pat84 | OpenFOAM Running, Solving & CFD | 2 | August 12, 2013 18:42 |
ERCOFTAC Centrifugal Pump with kOmegaSST Model | marcelgt87 | OpenFOAM Running, Solving & CFD | 4 | March 13, 2013 11:49 |
kOmegaSST OF2.1 Help needed! | wiedangel | OpenFOAM Running, Solving & CFD | 0 | May 9, 2012 11:01 |
Wrong calculation of nut in the kOmegaSST turbulence model | FelixL | OpenFOAM Bugs | 27 | March 27, 2012 10:02 |
