Solve fluid flow instability problems using OpenFOAM |
February 7, 2020, 08:14 |
Ravi Kant
How to solve a fluid flow instability problem (i.e. Linearized perturbed Navier-Stokes LNSE equations) using OpenFOAM ? I didn't find any tutorial/documentation by OpenFOAM community so far.
Although, recently I have encountered a research article title - Instability and sensitivity analysis of flows using OpenFOAM by Liu Qionga F.Gomezb J.M.Pereza and V.Theofilisa (link - https://www.sciencedirect.com/scienc...00936116300024) However, I have found out that NEK5000 has a dedicated tutorial on LNSE stability equation (link - http://nek5000.github.io/NekDoc/theo...ized-equations |
February 7, 2020, 14:20 |
Herpes Free Engineer
Rep Power: 13 |
No idea, but very interesting.
But maybe you can provide a tutorial to the community.
The OpenFOAM community is the biggest contributor to OpenFOAM: User guide/Wiki-1/Wiki-2/Code guide/Code Wiki/Journal Nilsson/Guerrero/Holzinger/Holzmann/Nagy/Santos/Nozaki/Jasak/Primer Governance Bugs/Features: OpenFOAM (ESI-OpenCFD-Trademark) Bugs/Features: FOAM-Extend (Wikki-FSB) Bugs: OpenFOAM.org How to create a MWE New: Forkable OpenFOAM mirror |
January 1, 2021, 15:44 |
Kadi
Rep Power: 12 |
Hi Ravi kant,
I have the same problem. did you find a solution? |
April 19, 2021, 06:08 |
Sorry couldnt find the answer.
Ravi Kant
Sorry couldnt find the answer, but I found 2 threads seeking similar problem -
1. Problem with linearized Navier-Stokes equations 2. Linearized Navier Stokes Solver |
fluid flow instability, lnse equation, nek5000, openfoam |
Question about adaptive timestepping | Guille1811 | CFX | 25 | November 12, 2017 18:38 |
A problem of incorrect fluid flow field using Openfoam | marialhm | OpenFOAM Running, Solving & CFD | 25 | June 12, 2017 03:34 |
Illogical problems with fluid flow | buksi | FLUENT | 0 | April 13, 2017 07:18 |
How to use the ODE solvers in OpenFoam to solve CFD problems? | mod0 | OpenFOAM Running, Solving & CFD | 0 | October 14, 2015 03:57 |
How can i solve orifice flow with OpenFOAM? | spk | OpenFOAM | 0 | October 2, 2011 18:48 |
