rhoSimpleFoam - Newbie Issues
Like Tree1Likes
  • 1 Post By sapujapu
Old   January 29, 2020, 12:05
Default rhoSimpleFoam - Newbie Issues
Andy Robertson
AndyR is on a distinguished road
Folks,
First time using OpenFoam
about 30 yrs using other tools, but feeling like a newb ;-)
Running a small tube bundle problem.
Used the square bend as my starting template and it runs just fine.
The job starts, gets to time = 1 and then just stops.
attached is the dict, and log file.
I can upload the whole thing if necessary.
But first question.
Can I get more verbose output?
Is there a reference pressure in here somewhere? Not sure why the pressure control is showing pMin as low as it is. I have set the back pressure at the outlet to be just above atmospheric. I would expect the inlet pressure to rise to whatever is required to push the flow.
I have clearly made an error in my setup, but can't seem to find it.
Any help is appreciated.
Thanks
Andy
AndyR is offline   Reply With Quote
Old   January 29, 2020, 15:02
Default Follow Up #1
Andy Robertson
So I ran
rhoSimpleFoam -dry-run
And... it looks like the solver tries to run
Starting time loop
Time = 1
GAMG: Solving for Uy, Initial residual = 0.40392, Final residual = 0.000781681, No Iterations 1
GAMG: Solving for Uz, Initial residual = 1, Final residual = 0.000715822, No Iterations 1
GAMG: Solving for e, Initial residual = 1, Final residual = 0.00697091, No Iterations 1
GAMG: Solving for p, Initial residual = 1, Final residual = 0.0537728, No Iterations 1
time step continuity errors : sum local = 18767.5, global = 18767.5, cumulative = 18767.5
GAMG: Solving for epsilon, Initial residual = 1, Final residual = 2.09567e-16, No Iterations 1
GAMG: Solving for k, Initial residual = 1, Final residual = 3.25556e-07, No Iterations 1
ExecutionTime = 0.68 s ClockTime = 1 s
End
So....
Is running -dry-run really just running the first time step /iter?
If so , why does it seem to hang when I try and run the whole job?
Hmmm
Thanks
Andy
Old   January 29, 2020, 17:56
Default Follow Up # 2
Andy Robertson
So Dry run does not as far as I can tell give me an snapshot of the initial field. That is always an useful debugging tool. Is there a way to do that in OpenFoam?
I did try some different smoother settings and was told residuals were 1e200.
Clearly something wrong. My guess is my initialization of BCs, but I cant find it.
On question.
nCellsInCoarsestLevel was set to some number of order 10 in the example.
For a 625,000 cell model that seems ludicrously small.
Is there any documentation on solver/bc dependencies? solver initial condition dependencies? I have my sym boundaries in all my time 0 files. Not sure that is necessary, or that I specified them correctly.
My mesh has 4 sym planes, 2 define discontinuous boundaries. Do those need to be broken up?
Thanks
Andy
File Type: png HX_PointwiseGrid_ExtrudedTrisAndQuads.png (11.0 KB, 28 views)
Old   January 30, 2020, 04:33
Troy Snyder
tas38 is on a distinguished road
Andy,
More information is needed. Most notably, your boundary condition files and a log file after the simulation has run for a while. I would not overly focus on the specifics of the linear solver settings at this stage.
I assume that since your first post your simulation now runs for a bit as you have stated the residuals are very large, i.e. the solution is diverging.
tas38 is offline   Reply With Quote
Old   January 30, 2020, 11:09
Default Status
Andy Robertson
Troy,
So it doesn't really run, I fiddled with changed to simpler diagonal solver and got a little output.
Log file is fairly sparse. I know the mistake is mine, but just not getting enough feedback from the code to determine the issue. Can I get a more verbose log file?
It is also not clear what the difference is between
symmetry and symmetryPlane
The Log and BC files are below
Thanks
Andy
Log file:
PHP Code:
| \\      /  F ield         | OpenFOAM: The Open Source CFD Toolbox           |
|  \\    /   O peration     | Version:  v1912                                 |
|   \\  /    A nd           | Website:  [url]www.openfoam.com[/url]                      |
|    \\/     M anipulation  |                                                 |
Build  _f3950763fe-20191219 OPENFOAM=1912
Arch
"LSB;label=32;scalar=64"
Exec   : /opt/OpenFOAM/OpenFOAM-v1912/platforms/linux64Gcc63DPInt32Opt/bin/rhoSimpleFoam
Date
Jan 30 2020
Time
09:51:33
Host
FLWS03
PID
28327
I
/O    uncollated
Case   : /home/arobertson/OpenFOAM/arobertson-v1912/run/HXER
nProcs
1
trapFpe
Floating point exception trapping enabled (FOAM_SIGFPE).
fileModificationChecking Monitoring run-time modified files using timeStampMaster (fileModificationSkew 10)
allowSystemOperations Allowing user-supplied system call operations
Create time
Create mesh
for time 0
SIMPLE
convergence criteria
    field p     tolerance 0.001
    field U     tolerance 0.0001
    field e     tolerance 0.001
    field
"(k|epsilon|omega)"     tolerance 0.001
Reading thermophysical properties
Selecting thermodynamics package
type            hePsiThermo;
mixture         pureMixture;
transport       sutherland;
thermo          hConst;
equationOfState perfectGas;
specie          specie;
energy          sensibleInternalEnergy;
Reading field U
Reading
/calculating face flux field phi
pressureControl
    pMax 206820
    pMin 10341
Creating turbulence model
Selecting turbulence model type RAS
Selecting RAS turbulence model kEpsilon
RAS
RASModel        kEpsilon;
turbulence      on;
printCoeffs     on;
Cmu             0.09;
C1              1.44;
C2              1.92;
C3              0;
sigmak          1;
sigmaEps        1.3;
No MRF models present
No finite volume options present
Starting time loop
Time
Note it just ends. No time 1 folder is created
Clearly I have a major problem with my setup
alphat
PHP Code:
/*--------------------------------*- C++ -*----------------------------------*\
|   \\  /    A nd           | Website:  www.openfoam.com                      |
FoamFile
version     2.0;
format      ascii;
    class
volScalarField;
object      alphat;
dimensions      [--1 0 0 0 0];
internalField   uniform 0;
boundaryField
Inlet
type            calculated;
value           $internalField;
Outlet
type            calculated;
TubeWall1
type            compressible::alphatWallFunction;
Prt             0.85;
Sym_Xmax
type symmetry;
Sym_Xmin
type symmetry;
Sym_Ymax
type symmetry;
Sym_Ymin
type symmetry;
epsilon
PHP Code:
FoamFile
version     2.0;
format      ascii;
    class
volScalarField;
object      epsilon;
dimensions      [0 2 -3 0 0 0 0];
internalField   uniform 0.1;
boundaryField
Inlet
type            turbulentMixingLengthDissipationRateInlet;
mixingLength    0.005;
Outlet
type            inletOutlet;
inletValue      $internalField;
TubeWall1
type            epsilonWallFunction;
Cmu             0.09;
kappa           0.41;
E               9.8;
Sym_Xmax
type symmetry;
Sym_Xmin
type symmetry;
Sym_Ymax
type symmetry;
Sym_Ymin
type symmetry;
K
PHP Code:
FoamFile
version     2.0;
format      ascii;
    class
volScalarField;
object      epsilon;
boundaryField
Inlet
mixingLength    0.005;
Outlet
type            inletOutlet;
TubeWall1
Cmu             0.09;
kappa           0.41;
E               9.8;
Sym_Xmax
type symmetry;
Sym_Xmin
type symmetry;
Sym_Ymax
type symmetry;
Sym_Ymin
type symmetry;
nut
PHP Code:
FoamFile
version     2.0;
format      ascii;
    class
volScalarField;
object      nut;
dimensions      [0 2 -1 0 0 0 0];
internalField   uniform 0.01;
boundaryField
Inlet
type            calculated;
Outlet
type            calculated;
TubeWall1
type            nutkWallFunction;
Cmu             0.09;
kappa           0.41;
E               9.8;
Sym_Xmax
type symmetry;
Sym_Xmin
type symmetry;
Sym_Ymax
type symmetry;
Sym_Ymin
type symmetry;
P
PHP Code:
FoamFile
version     2.0;
format      ascii;
    class
volScalarField;
object      p;
dimensions      [--2 0 0 0 0];
internalField   uniform 103410;
boundaryField
Inlet
type            zeroGradient;
Outlet
type            fixedValue;
value           uniform 103410;
TubeWall1
type            zeroGradient;
Sym_Xmax
type symmetry;
Sym_Xmin
type symmetry;
Sym_Ymax
type symmetry;
Sym_Ymin
type symmetry;
T
PHP Code:
FoamFile
version     2.0;
format      ascii;
    class
volScalarField;
object      T;
dimensions      [0 0 0 1 0 0 0];
internalField   uniform 1000;
boundaryField
Inlet
type            fixedValue;
value           uniform 1000;
Outlet
type            inletOutlet;
TubeWall1
type            fixedValue;
value           uniform 1100;
Sym_Xmax
type symmetry;
Sym_Xmin
type symmetry;
Sym_Ymax
type symmetry;
Sym_Ymin
type symmetry;
U
PHP Code:
FoamFile
version     2.0;
format      ascii;
    class
volVectorField;
object      U;
dimensions      [0 1 -1 0 0 0 0];
internalField   uniform (0 0 0.01);
boundaryField
Inlet
type      fixedValue;
value   uniform   (0.0 0.0 0.25);
Outlet
type            inletOutlet;
TubeWall1
type            noSlip;
Sym_Xmax
type symmetry;
Sym_Xmin
type symmetry;
Sym_Ymax
type symmetry;
Sym_Ymin
type symmetry;
Old   March 10, 2020, 06:47
james freak
me45 is on a distinguished road
I have similar trouble.
me45 is offline   Reply With Quote
Old   March 10, 2020, 10:28
sapujapu is on a distinguished road
Right now you're setting an inlet velocity as BC. However, I don't see any info on your inlet density. rhoSimpleFoam is a compressible solver so I think you need that.
When you use a compressible solver, there's two ways of combining BCs for the inlet and outlet.
First option: Set a total pressure at the inlet and a static pressure at the outlet. This can be quite unstable if you have a complicated flowfield.
Second option: Set a massflow at the inlet and a static pressure at the outlet. The massflow BC works as like this:
inlet
type flowRateInletVelocity;
massFlowRate constant $yourvalue;
rhoInlet 0.5; // This is just an optional first guess and can be left out completely.
This method is quite stable, I've used it successfully to simulate very similar cases to yours.
If you really want to use a total pressure/static pressure setup, you can use the massflow to initialize the solution and then later change it to total pressure. I've found this to be quite stable.
lpz456 likes this.
sapujapu is offline   Reply With Quote
transsonic nozzle with rhoSimpleFoam Unseen OpenFOAM Running, Solving & CFD 8 July 1, 2022 07:54
Convergence issues for Flat plate with sharp edge rajnarayang FLUENT 3 June 20, 2017 13:02
rhoSimpleFoam angledDuctExplicitFixedCoeff tutorial fails in parallel donQi OpenFOAM Running, Solving & CFD 1 February 22, 2016 20:47
Multigrid Stability Issues ThomasHermann SU2 1 November 5, 2014 17:18
rhoSimpleFoam. patchField error. 123 OpenFOAM Running, Solving & CFD 4 June 6, 2014 16:22
