Including limiters in fvOptions
Like Tree5Likes
  • 4 Post By Swagga5aur
  • 1 Post By Swagga5aur
Old   January 21, 2020, 07:29
Question Including limiters in fvOptions
+lorenzo90+ is on a distinguished road
Dear all,
I'd like to know if there is a way to include limiters on equation variables such as p, U, etc. (max and min values) in the case of using SRFSimpleFoam, simpleFoam, etc.
Thanks in advance,
Lorenzo
+lorenzo90+ is offline   Reply With Quote
Old   January 21, 2020, 14:54
Post
Lasse Brams Vinther
Swagga5aur is on a distinguished road
Hello Lorenzo,
You can limit the velocity, temperature and such in fvOptions such as the following:
    limitU
        type            limitVelocity;
        active          yes;
        selectionMode   all;
        max             100;
Or in fvSolution as the following with the pressure or density as well limited.
SIMPLE
    nNonOrthogonalCorrectors 0;
    numberIterationsStator 1;
    numberIterationsRotor 1;
    UMax      500;
    pMin      pMin   [0 2 -2 0 0 0 0]    -1000;
    pMax      pMax   [0 2 -2 0 0 0 0]     1000;
Best regards,
Lasse
The King, Gerhard, altinel and 1 others like this.
Swagga5aur is offline   Reply With Quote
Old   January 22, 2020, 11:58
Originally Posted by Swagga5aur View Post
Hello Lorenzo,
    limitU
        type            limitVelocity;
        active          yes;
        selectionMode   all;
        max             100;
SIMPLE
    UMax      500;
Best regards,
Lasse
Thanks a lot Lasse,
the limiter on velocity works for the case I'm running, but the limiter on pressure does not seem to be read by the code (I tried to put banana instead of a value for pMax and the solver [SRFSimpleFoam] didn't complain). Do you have some further suggestions on this aspect?
Old   January 22, 2020, 14:59
Lasse Brams Vinther
Hello Lorenzo,
I may have been a bit too hasty regarding the pressure limiting, as it seems that incrompressible solvers does not read the limit specified in fvSolution as compressible solvers does in the pEqn. I'll make a test solver where this is included to be certain of the implementation.
masterJames likes this.
Old   January 22, 2020, 16:03
Lasse Brams Vinther
Alright so I was unable to apply the fvSolution limiter as the units of the pMin/pMax is different as it does not include the density as the incompressible solver does in the pressure field.
I then just added a pMin, pMax to the transportProperties in a new solver called limitedSimpleFoam an example of this is attached to this post, and restricted in the pressure in pEqn with min max.
I'm not certain its possible to limit the pressure directly in fvSolution for incompressible solvers, I at least was unable to locate it in the source.
Hope its adequate.
Regards,
Lasse
Old   January 23, 2020, 07:18
Hope its adequate.
Regards,
Lasse
Thanks a lot for the effort,
I'll try to include this feature in the SRFSimpleFoam solver too, to handle a case I'm currently running.
Can I use fvOptions to couple a solid region and a fluid region? titanchao OpenFOAM Running, Solving & CFD 4 January 14, 2022 08:55
What are the units used in the thermophysicalProperties and fvOptions dictionaries? ophr OpenFOAM Pre-Processing 2 June 16, 2019 02:29
Configuration of boundary conditions and fvOptions file Raza Javed OpenFOAM Running, Solving & CFD 16 May 3, 2019 17:35
topoSet/setSet and fvOptions pod OpenFOAM Running, Solving & CFD 5 April 30, 2019 06:41
Doubt regarding MUSCL scheme implementation and associated limiters SangeethCFD Main CFD Forum 0 October 7, 2017 10:00
