Turbulent flow over NACA0012 airfoil validation case (openfoam.com)
Like Tree1Likes
  • 1 Post By Luke_M
Old   January 18, 2020, 06:03
Default Turbulent flow over NACA0012 airfoil validation case (openfoam.com)
Luke
Luke_M is on a distinguished road
Hello everyone!
I’m trying to recreate a validation case of NACA0012 airfoil exactly how they did it on openfoam.com website:
https://www.openfoam.com/documentati...irfoil-2d.html
They claim that the base for this case is a tutorial case from /incompressible/simpleFoam/airFoil2D so that’s the first thing I copied.
Then I had to download the 3D mesh: (3-D) 2 x 897 x 257 (2 x 513 point on airfoil surface) from this website:
https://turbmodels.larc.nasa.gov/naca0012_grids.html
Standard plot3dToFoam command didn't work, because it was producing an error:
Create time
Reading 1 blocks
block 0 nx:2 ny:897 nz:257
Reading block points
block 0:
Reading 461058 x coordinates...
Reading 461058 y coordinates...
Reading 461058 z coordinates...
Reading 461058 blanks...
--> FOAM FATAL IO ERROR:
Attempt to get back from bad stream
file: n0012_897-257.p3dfmt at line 461062.
    From function bool Foam::Istream::getBack(Foam::token&)
    in file db/IOstreams/IOstreams/Istream.C at line 56.
FOAM exiting
So to convert the .p3dfmt file I used a command (which created only one wall "defaultFaces" in boundary file):
plot3dToFoam -noBlank n0012_897-257.p3dfmt
The message from this command looked like this:
Create time
Reading 1 blocks
block 0:
Looking at cell 0 0 0 to determine orientation.
Right-handed block.
Merged points within 2.22045e-16 distance. Merged from 461058 down to 460672 points.
Creating cells
Creating boundary patches
--> FOAM Warning :
    From function Foam::polyMesh::polyMesh(const Foam::IOobject&, Foam::pointField&&, const cellShapeList&, const faceListList&, const wordList&, const wordList&, const Foam::word&, const Foam::word&, const wordList&, bool)
    in file meshes/polyMesh/polyMeshFromShapeMesh.C at line 595
    Found 460672 undefined faces in mesh; adding to default patch.
Writing polyMesh
End
After that I used a command:
autoPatch -overwrite 15
which produced a message:
Create time
Create polyMesh for time = 0
Mesh read in = 0.91 s
Feature:15
minCos :0.965926
Assigned 512 faces to patch auto0
Assigned 229376 faces to patch auto1
Assigned 229376 faces to patch auto2
Assigned 512 faces to patch auto3
Assigned 896 faces to patch auto4
End
Then I edited the files as best as I can to match the guidelines on openfoam.com website. After editing I used standard commands:
decomposePar
simpleFoam
I ran simulation on OpenFoam v7 and v1612+ and both of them produce an error at Time=459 or 463 or 471. The error looks like this:
Time = 471
smoothSolver:  Solving for Ux, Initial residual = 0.403553, Final residual = 0.00133943, No Iterations 52
smoothSolver:  Solving for Uz, Initial residual = 0.423146, Final residual = 0.00205817, No Iterations 40
#0  Foam::error::printStack(Foam::Ostream&) at ??:?
#1  Foam::sigFpe::sigHandler(int) at ??:?
#2  ? in "/lib64/libc.so.6"
#3  Foam::GAMGSolver::scale(Foam::Field<double>&, Foam::Field<double>&, Foam::lduMatrix const&, Foam::FieldField<Foam::Field, double> const&, Foam::UPtrList<Foam::lduInterfaceField const> const&, Foam::Field<double> const&, unsigned char) const at ??:?
#4  Foam::GAMGSolver::Vcycle(Foam::PtrList<Foam::lduMatrix::smoother> const&, Foam::Field<double>&, Foam::Field<double> const&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::PtrList<Foam::Field<double> >&, Foam::PtrList<Foam::Field<double> >&, unsigned char) const at ??:?
#5  Foam::GAMGSolver::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const at ??:?
#6  Foam::fvMatrix<double>::solveSegregated(Foam::dictionary const&) at ??:?
#7  Foam::fvMatrix<double>::solve(Foam::dictionary const&) at ??:?
#8  Foam::fvMatrix<double>::solve() at ??:?
#9  ? at ??:?
#10  __libc_start_main in "/lib64/libc.so.6"
#11  ? at ??:?
Floating point exception (core dumped)
From the infromation I gathered it seems that this error comes when there is some expression dividing value by zero.
EDIT: Nvm, I figured it out. Turned out I messed up my BC .
Jack Sun likes this.
Luke_M is offline   Reply With Quote
Old   July 5, 2021, 19:45
GDS
GS
GDS is on a distinguished road
I am trying to run this same case. Can you explain how to edit the files created by autoPatch? I cannot find any useful documentation on how to use this utility.
GDS is offline   Reply With Quote
Validation: Turbulent Channel Flow, pisoFoam, LES Xiaoyu Yang OpenFOAM Running, Solving & CFD 23 December 19, 2019 12:51
SA-DDES Validation laminar or turbulent flow? Davide95 OpenFOAM Running, Solving & CFD 0 November 23, 2018 15:50
About Some Concepts:Laminar flow, turbulent flow, steady flow and time-dependent flow Jing Main CFD Forum 8 October 5, 2018 18:02
Is Playstation 3 cluster suitable for CFD work hsieh OpenFOAM 9 August 16, 2015 15:53
Turbulent Channel validation case - Pressure gradient ZviH Main CFD Forum 2 July 8, 2015 17:11
