nutUSpaldingWallFunction vs enhanced wall treatment
Like Tree3Likes
  • 2 Post By tas38
  • 1 Post By cryabroad
Old   December 22, 2019, 10:45
Default nutUSpaldingWallFunction vs enhanced wall treatment
OliverB is on a distinguished road
I was wondering if the use of nutUSpaldingWallFunction for k-e models in OF can be reasonably used instead of enhanced wall treatment of commercial codes ?
I couldn't find much information about it.
Thanks
OliverB is offline   Reply With Quote
Old   December 22, 2019, 14:01
Troy Snyder
tas38 is on a distinguished road
The tentative answer is yes, this wall function attempts to provide a smooth transition between the laminar sublayer and log-layer. You should consult Spalding's original 1961 for a description.
However, this wall function is not the same blending/enhanced wall-function approach that is applied in commercial codes, say ANSYS fluent. Most notably, Spalding's universal function does not include adjustment's for adverse/favorable pressure gradients. If you take a look at the attached photo, I compare the Spalding wall-function with that of Fluent (less the pressure-dependent terms).
In practice, however, I have found it difficult to get grid-independent results using this nut..Spalding... wall function for y^+ > 1.0, the precise reason I chose to use it.
tariq and superkelle like this.
tas38 is offline   Reply With Quote
Old   December 23, 2019, 01:03
Ruiyan Chen
cryabroad is on a distinguished road
I did some similar tests a while ago and came to a conclusion that nutUSpalding is good for y+>5. For y+<5 I struggled to find a very good wall function though. I will add that my tests are not that rigorous, and my intention was to get a good mean velocity file at the end of a pipe (which feeds fluid into a much larger room).
Commerical codes tend to use a two-layer approach near the wall, and they use another nondimensional wall distance (y*) as the switch between these two layers. I think any wall function in FOAM that has this funtionality should be good. There's a very detailed document that explains wall functions in FOAM from Chalmers, just google it. I think it will help you a lot.
superkelle likes this.
cryabroad is offline   Reply With Quote
Old   December 23, 2019, 04:36
Thank you both, your answers are very usefull.
enhanced wall treatment, nutuspaldingwallfunction
Does realizable k-e model with enhanced wall treatment work for surface roughness? zyy95900 FLUENT 5 November 15, 2017 17:13
Very technical question about solving wall boundary layer ... jlb001 FLUENT 6 December 27, 2014 06:56
Enhanced wall Treatment marluc FLUENT 0 July 13, 2013 11:58
Applying enhanced wall treatment in free slip wall amarjogot FLUENT 1 June 26, 2013 13:44
Enhanced wall treatment with user-defined mu_t tstorm FLUENT 0 August 20, 2009 14:05
