PIMPLE: No convergence criteria found (please help) |
December 9, 2019, 16:12 |
Fawzi
Rep Power: 6 |
Hello everyone,
When running the shockTube tutorial with 100 cells in the x-direction, the solutions runs without any problem but when I change the number of cells to 1000, I get the following error: // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 PIMPLE: No convergence criteria found PIMPLE: No corrector convergence criteria found Calculations will do 2 corrections PIMPLE: Operating solver in transient mode with 2 outer correctors Reading thermophysical properties Selecting thermodynamics package { type hePsiThermo; mixture pureMixture; transport const; thermo hConst; equationOfState perfectGas; specie specie; energy sensibleInternalEnergy; } #0 Foam::error::printStack(Foam::Ostream&) at ??:? #1 Foam::sigFpe::sigHandler(int) at ??:? #2 ? in "/lib/x86_64-linux-gnu/libc.so.6" #3 Foam::heThermo<Foam::psiThermo, Foam::pureMixture<Foam::constTransport<Foam::speci es::thermo<Foam::hConstThermo<Foam::perfectGas<Foa m::specie> >, Foam::sensibleInternalEnergy> > > >::heThermo(Foam::fvMesh const&, Foam::word const&) at ??:? #4 Foam::fluidThermo::addfvMeshConstructorToTable<Foa m::hePsiThermo<Foam::psiThermo, Foam::pureMixture<Foam::constTransport<Foam::speci es::thermo<Foam::hConstThermo<Foam::perfectGas<Foa m::specie> >, Foam::sensibleInternalEnergy> > > > >::New(Foam::fvMesh const&, Foam::word const&) at ??:? #5 Foam::autoPtr<Foam::fluidThermo> Foam::basicThermo::New<Foam::fluidThermo>(Foam::fv Mesh const&, Foam::word const&) at ??:? #6 Foam::fluidThermo::New(Foam::fvMesh const&, Foam::word const&) at ??:? #7 ? in "/opt/openfoam7/platforms/linux64GccDPInt32Opt/bin/rhoPimpleFoam" #8 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" #9 ? in "/opt/openfoam7/platforms/linux64GccDPInt32Opt/bin/rhoPimpleFoam" Floating point exception (core dumped) *Note: I included the full case file and error log file Thank you in advance Last edited by fawzi; December 11, 2019 at 12:59. Reason: included the full case file and error log file |
December 10, 2019, 00:54 |
#2 | |
Kmeti Rao
Rep Power: 8 |
Hi, I don't know whether I could help you with the error but for sure, 'No convergence criteria found' is not an error. This means OpenFOAM is informing you to add something like below in your PIMPLE loop of fvSolutions, just in case if you require. It is not mandatory,
December 10, 2019, 01:59 |
#3 | |
Fawzi
Rep Power: 6 |
Thank you for your reply. When I read online, I found the suggestion that you mentioned and I implemented it but got the same warning let’s call it. Is that because the tolerances that I set for the p, u etc are small? Finally, even if I get that notification, I should expect to load the results in a post-processing package without a problem, correct? Regards, Fawzi |
December 10, 2019, 02:08 |
Rep Power: 16 |
Yes, you can run pimpleFoam without these convergence criteria and get results.
The PIMPLE convergence criteria are only applied if you also use outer loops. Then, you run outer loops until the residual at the first iteration of solving a matrix is below the threshold defined. |
December 10, 2019, 02:43 |
Fawzi
Rep Power: 6 |
Thanks a lot, things make much more sense now!
December 10, 2019, 08:01 |
#6 | |
Fawzi
Rep Power: 6 |
Hello again, I ran the simulation again and no solution results (files) were generated. I have a feeling it has to do with the part of the code that I attached above indicated by "#1" etc. Thanks in advance |
December 10, 2019, 08:29 |
Fawzi
Rep Power: 6 |
From reading online, it seems like the issue is related to a boundary condition that is causing nonphysical flow phenomena. What is confusing me is that the tutorial that I am following seems to work just fine for the tutor (on YouTube).
I have attached the 0 folder incase this can help. Thank you very much (sorry, I have just very recently started learning how to use OpenFOAM. |
December 10, 2019, 08:53 |
Rep Power: 16 |
Well if the error in post #1 still exists you will not get any results, because the simulation crashes.
I am not familiar with this tutorial, so someone else might help out, but I recommend to upload the whole case + log file when solving. |
February 8, 2024, 02:07 |
i have found these error while running my simulation
#9 |
Shashank Shekhar Sandilya
Rep Power: 4 |
PIMPLE: Operating solver in PISO mode Reading field p Reading field U Reading/calculating face flux field phi Selecting incompressible transport model Newtonian Selecting turbulence model type RAS Selecting RAS turbulence model kEpsilon RAS { RASModel kEpsilon; turbulence on; printCoeffs on; Cmu 0.09; C1 1.44; C2 1.92; C3 0; sigmak 1; sigmaEps 1.3; } No MRF models present No finite volume options present Courant Number mean: 1.03659e-07 max: 4.64481e-05 Starting time loop Courant Number mean: 1.03659e-07 max: 4.64481e-05 deltaT = 0.000119048 Time = 0.000119048 Killed |
February 8, 2024, 17:51 |
#10 |
Rep Power: 14 |
Did you forget to include your question?
[RapidCFD] Discussion thread on how to install and use RapidCFD | newoscar | OpenFOAM Community Contributions | 88 | May 17, 2024 09:39 |
[OpenFOAM.com] Issue configuring ./makeParaView - Ubuntu 16.04 | bjdarrer | OpenFOAM Installation | 2 | April 20, 2020 13:50 |
OpenFOAM 1.7.1 installation problem on OpenSUSE 11.3 | flakid | OpenFOAM Installation | 16 | December 28, 2010 08:48 |
What value shall I set for the Convergence criteria? | steventay | CFX | 7 | May 14, 2010 12:44 |
OF 1.6 | Ubuntu 9.10 (64bit) | GLIBCXX_3.4.11 not found | piprus | OpenFOAM Installation | 22 | February 25, 2010 13:43 |
