Nusselt calculation
Like Tree1Likes
  • 1 Post By Ake
Old   November 6, 2019, 11:57
Default Nusselt calculation
regard is on a distinguished road
hi every body
i need to determine the local Nusselt number in vertical channel and then plot the nusselt versus length of the channel by openfoam but i dont know do it
how can i preform it?
(the wall of this channel under condition of constant heat flux and phase change occures)
any help, comment and reply would be appreciated
thanks in advance
regard is offline   Reply With Quote
Old   November 10, 2019, 15:35
any help, comment and reply would be very very appreciated
Old   November 15, 2019, 10:16
Ake
Kevin
Ake is on a distinguished road
I'm not sure I got it right, but that could be a solution. If it's ok with you, if you calculate it at the end.
Choose your location where you want to determine the nusselt number. Add some lines in a sampleDict (you dont need the line data but the wall temperature is the first entry of the line). For example the nusselt number at location y=0.1 and 0.2.
type sets;
interpolationScheme cellPoint;
setFormat raw;
writeControl    runTime;
writeInterval    1;
fields
    TMean //or T
TYPE lineUniform;
sets
    s00
        type            $TYPE;
        axis            distance;
        nPoints        3000;
        start          (0.0 0.1 0.0);
         end           (0.01 0.1 0.0);
      s01
        type            $TYPE;
        axis            distance;
        nPoints        3000;
        start          (0.0 0.2 0.0);
        end           (0.01 0.2 0.0);
With the wall temperature at a certain location T_w,i, the mean temperature of the flow T_m and the given heat flux at the wall q_w you can determine your local heat transfer coefficient alpha_i
alpha_i = q_w / (T_m - T_w,i)
And your local nusselt number
Nu_i = (alpha_i * D_h) / lambda
If you need a time evaluation you can also include the sampleDict in the controlDict and write the wall temperature at certain times. But still, this is a simple post processing solution. You need to calculate it afterwards, which could be time consuming if you need your local nusselt number at many time steps.
regard likes this.
Ake is offline   Reply With Quote
Old   November 15, 2019, 11:10
very very thanks for your kind reply
I use the swake for calculate the heat transfer coefficient in your idea this code can be corrected?
thanks in advance
code:
(q=30000)
h1
type swakExpression;
valueType surface;
surfaceName X1;
surface {
type plane;
basePoint (0 0.1 0);
normalVector (0 1 0);
interpolate true;
verbose true;
variables
"T_inf=sum(U.y*Sf().y*T)/sum(U.y*Sf().y);"
"Ts{patch'heater}=sum(T*area())/sum(area());"
expression "30000/(Ts-T_inf)";
accumulations (
average
//writeSurfaceOnConstruction true;
// autoWriteSurface true;
//surfaceFormat vtk;
outputControlMode timeStep;//outputTime;//
outputInterval 10;
//writeStartTime no;
nusselt calculation, nusselt local
Nusselt number calculation in Fluent Sharadkumar Yeri FLUENT 52 May 29, 2019 07:29
nusselt number calculation ? srinivasan648 FLUENT 0 June 4, 2014 08:41
Nusselt averaging in Unsteady calculation elyyan FLUENT 0 August 7, 2006 14:48
unsteady calculation and Nusselt averaging elyyan FLUENT 0 August 4, 2006 15:32
Warning 097- AB Siemens 6 November 15, 2004 05:41
