pisoFoam and pimpleFoam are unstable in foam-extend 4.0/4.1 (misunderstanding ?) |
October 20, 2019, 10:25 |
Artem
Rep Power: 12 |
Dear Foamers,
Some time ago I ran into a problem which I would like to put here in order to clarify or to share the experience. I work mainly with pisoFoam in foam-extend 4.0, and the solver works properly besides a few bugs ( e.g. not able to use pFinal and uFinal in fvSolution). Recently I decided to try pimpleFoam in foam-extend 4.0 because I wanted to use PIMPLE algorithm. However, when I applied pimpleFoam to my case (3d duct LES flow y+ < 1, Co < 1, Smagorinsky SGS - which worked properly with pisoFoam) I found that the solution immediately blew up after 2-3 iterations, although I used exactly the same schemes settings as for pisoFoam. I tried to simulate the laminar duct flow and again the solution immediately diverged after a few iterations. Then I tried to simulate a standard pimpleFoam tutorial with the standard settings in foam-extend 4.0 - "t-junction tutorial" and it diverged as well. When I went through the pimpleFoam solver code, I found that compare to other OpenFoam versions (foam-extend 3.2, OpenFoam 7 etc), the algorithm in foam-extend 4.0 is different. The main difference is that in foam-extend 4.0 developers do not include a time derivative term into HUeqn: Foam-extend 4.0: pimpleFoam/UEqn.H Code:
fvVectorMatrix HUEqn ( fvm::div(phi, U) + turbulence->divDevReff() ); Code:
// Prepare clean Ap without time derivative contribution and // without contribution from under-relaxation // HJ, 26/Oct/2015 aU = HUEqn.A(); // Store velocity under-relaxation point before using U for the flux // precursor U.storePrevIter(); U = HUEqn.H()/aU; Foam-extend 3.2: pimpleFoam/UEqn.H Code:
tmp<fvVectorMatrix> UEqn ( fvm::ddt(U) + fvm::div(phi, U) + turbulence->divDevReff(U) ); Code:
U = rUA*UEqn().H(); Then I moved to foam-extend 4.1 and found that besides pimpleFoam they introduced the same feature for pisoFoam as well: Foam-extend 4.1: pisoFoam.C Code:
// Pressure-velocity PISO corrector { // Momentum predictor // Time-derivative matrix fvVectorMatrix ddtUEqn(fvm::ddt(U)); // Convection-diffusion matrix fvVectorMatrix HUEqn ( fvm::div(phi, U) + turbulence->divDevReff() ); After numerous tries, I found out that for these new algorithms the laminar duct flow would work only if I initialize the velocity field with the values closed to expected and the LES duct flow would work only with highly dissipative schemes for the convection term (like upwind schemes that is obviously not good for results). Additionally, I found the paper where developers explained the advantages of approximately the same algorithm: https://www.sciencedirect.com/scienc...495?via%3Dihub However, it seems that on practice even standard tutorials do not work or maybe I just don't understand how to use it properly. Any explanations or experience sharing would be very appreciated. Thank you. Regards, Artem Last edited by Kombinator; October 20, 2019 at 13:41. |
October 20, 2019, 12:40 |
Arjun
Rep Power: 34 |
i looked at the paper you mentioned and based on my experience with flow solvers i can point out to you that the most probable culprit is the extrapolation of velocity and pressure to new time level.
My experience says that this idea more or less does not work, it creates more problems then it helps. It might have worked for the test problems they have used so it is pushed in. The reasons as to why extrapolation does not work it that in practice the extrapolated velocity does not satisfy the continuity (which kind of play critical role in convection term, the one they are trying to fix). |
October 21, 2019, 11:42 |
Artem
Rep Power: 12 |
Hey Arjun,
Thank you for the answer and for the explanation. In case somebody needs this - I adapted the "old" usual pimpleFoam algorithm from the previous version in order to be compiled in foam-extend 4.0 (and probably in foam-extend 4.1 but I didn't check). It works properly so far - I attached the solver here. Best regards, Artem |
July 28, 2020, 02:43 |
Chaewoong Ban
Rep Power: 13 |
Thanks for sharing your experiences.
I have been suffered with same problem with you. pimpleFoam in version of FE41 always diverged except for using Euler for ddt term and Gauss upwind for div(phi,U) term. In addition, the solution is too dissipative that I cant get any expected results from simulation. |
January 14, 2021, 05:10 |
H Fossum
Rep Power: 5 |
I also add my thanks for this post, as I've been having the same problems. I will definitely try the truePimpleFoam code. Meanwhile, I also came across this ticket in SourceForge:
https://sourceforge.net/p/foam-extend/tickets/39/ It appears to address the same issue, but as far as I can see, there has been no reply from foam-extend devs. I guess we'll have to wait and see if anything is changed in the next version of foam-extend. |
pimpleFoam vs simpleFoam vs pisoFoam vs icoFoam? | phsieh2005 | OpenFOAM Running, Solving & CFD | 45 | March 22, 2021 10:14 |
pisoFoam and pimpleFoam showing steady for UNsteady phenomena | aerospain | OpenFOAM Running, Solving & CFD | 0 | May 10, 2016 11:56 |
pimpleFoam - pisoFoam residuals | RodriguezFatz | OpenFOAM Running, Solving & CFD | 1 | September 25, 2014 09:37 |
pisoFoam, pimpleFoam - Fluent user's questions | RodriguezFatz | OpenFOAM Running, Solving & CFD | 0 | September 4, 2013 05:26 |
I got complete different results for pisofoam and pimplefoam? | lakeat | OpenFOAM Running, Solving & CFD | 6 | December 27, 2012 05:25 |
