Time Step decreases after a long time of running, why? |
Nidal
Rep Power: 7 ![]() |
My time step starts out at ~1e-9 which is acceptable since my model is basically a 2mm block. After many time steps, almost 1500, my time step decreases to ~1e-15. Anyone knows the reason why this might happen? Thanks a lot ![]() |
Kmeti Rao
Rep Power: 8 ![]() |
Which simulation you are using? What kind of solver?
Please go through the following link. How to give enough info to get help Assuming that you are using a transient solver, check your CFL(courant number), also, the solver settings and quality of the mesh you are using. If something is not ok please fix it |
Nidal
I am using rhoPimpleFoam, When I did the simulation using first order divergence schemes it worked just fine. now that I am solving using second order the time step reduces a lot after some time steps. basically my simulation is a pressure difference across porous media. I have a geometry of a porous structure and I am simulating flow across it. Please let me know if you need more info. My courant number is set to a max of 1, even if I increase it to 5 the time step remains ~1e-15
Kmeti Rao
I have not carried out simulations in your application but during dynamic simulation of external flow over a propeller, I had similar issues. I have overcome that by improving the quality of mesh and calculating the possible time step using CFL.
Jan Majcher
Hi Kmeti,
May I ask you how exactly did you improve the mesh quality? Did you decrease non-orthogonality? Cheers, Jan |
courant number increases to rather large values | 6863523 | OpenFOAM Running, Solving & CFD | 22 | July 5, 2023 23:48 |
AMI speed performance | danny123 | OpenFOAM | 21 | October 24, 2020 04:13 |
High Courant Number @ icoFoam | Artex85 | OpenFOAM Running, Solving & CFD | 11 | February 16, 2017 13:40 |
mixerVesselAMI2D's mass is not balancing | sharonyue | OpenFOAM Running, Solving & CFD | 6 | June 10, 2013 09:34 |
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 | bookie56 | OpenFOAM Installation | 8 | August 13, 2011 04:03 |
