October 7, 2019, 05:10 |
Speeding up chtMultiRegionSimpleFoam
Nejc
Rep Power: 9 |
is there a way to speed up temperature convergence in chtMultiRegionSimpleFoam? My velocity residuals have converged long ago but the temperature keeps rising, just awfully slowly. For instance, could I fake density and/or specific heat because it's a steady state case? Increasing nNonOrthogonalCorrectors in solid regions doesn't help. Thanks! |
October 7, 2019, 05:38 |
Carlo_P
Rep Power: 8 |
Yes, there are at least three options:
-change fvSolution file -change the fvSchemes file -initialized in a different way the temperature. The easiest way is to decrease the tollerance or nMinIt of the velocity and pressure in fvSolution and increase the number of iteration or tollerance of the temperature. Probably you can also increase the relaxation factor of the temperature. Can you attach the fvSolution file? Thanks |
October 7, 2019, 06:51 |
Nejc
Rep Power: 9 |
Here is a fvSolution file for fluid region:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: v1906 | | \\ / A nd | Web: www.OpenFOAM.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object fvSolution; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // solvers { rho { solver PCG; preconditioner DIC; tolerance 1e-7; relTol 0; } p_rgh { solver GAMG; tolerance 1e-7; relTol 0.01; smoother GaussSeidel; } "(U|h|k|omega|epsilon|G|Ii|gammaInt|ReThetat)" { solver PBiCGStab; preconditioner DILU; tolerance 1e-8; relTol 0.01; } "(f|v2)" { solver smoothSolver; smoother symGaussSeidel; tolerance 1e-07; relTol 0.01; } G { $p_rgh; tolerance 1e-05; relTol 0.1; } } SIMPLE { consistent yes; momentumPredictor yes; nNonOrthogonalCorrectors 2; // pRefCell 0; // pRefValue 100000; rhoMin 0.5; rhoMax 1.5; } relaxationFactors { fields { rho 1.0; p_rgh 0.7; } equations { U 0.5; h 0.5; "(k|omega|epsilon|f|v2|gammaInt|ReThetat)" 0.7; G 0.7; "ILambda.*" 0.7; qr 0.7; } } // ************************************************************************* // Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 5 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object fvSolution; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // solvers { "h.*" { solver PCG; preconditioner DIC; tolerance 1e-07; relTol 0.01; } } SIMPLE { nNonOrthogonalCorrectors 10; // faster temperature convergence (?) } relaxationFactors { equations { h 1.0; } } // ************************************************************************* // |
October 7, 2019, 07:23 |
Carlo_P
Rep Power: 8 |
In the fvSolution of the Solid, you are using 10 Correctors,,normally it is not usefull to use more than 3, but only for very "shitty" mesh.
You can change the relTol, decreasing it. In this way, you will have a faster convergence for the solid. You can take a look here: Conjugate Heat Transfer: slow solid temperature convergence Normally is also not usefull to use 1 as relaxationFactor. Yes, you will have a faster convergence, but maybe it is unsteable, so in the end you can't reach a good convergence. Can I aks you to share your project or at least the folders,without the geometry? I would like to do something like this in the short future. |
October 7, 2019, 08:11 |
Nejc
Rep Power: 9 |
Here is my complete chtMultiRegionSimpleFoam case. The mesh is made in a separate directory, then I copy mesh files to simulation/ dir.
Check out readme.txt file for more explanations. |
October 7, 2019, 10:17 |
Rep Power: 21 |
Change your h relaxation-factor (or e if you intend to solve for that) to 1.0 in all regions. This is the main cause of extremely slow temperature convergence. You basically shouldn't relax temperature unless you need it for stability. And in that case 0.99 should suffice. Another usefull thing is to use
SIMPLE / or PIMPLE depending on the solver { ... frozenFlow yes; } |
October 7, 2019, 10:32 |
Nejc
Rep Power: 9 |
Thank you, I will try that!
[snappyHexMesh] Speeding up snappyHexMesh when using many regions | wildfire230 | OpenFOAM Meshing & Mesh Conversion | 1 | March 31, 2022 04:38 |
Speeding convergence, SRFSimplefoam | c_dowd | OpenFOAM Running, Solving & CFD | 1 | March 9, 2016 05:13 |
speeding up the calculation / iteration in fluent | stefenbink | FLUENT | 0 | January 3, 2014 17:59 |
speeding up vortex shedding | Harish | Main CFD Forum | 2 | March 15, 2007 04:24 |
Speeding up size functions | Riaan | FLUENT | 1 | March 20, 2006 10:07 |
