Highly unstable buoyantPimpleFoam simulation
Like Tree2Likes
  • 2 Post By piotr.mecht
Old   September 27, 2019, 04:25
Default Highly unstable buoyantPimpleFoam simulation
Piotr Ładyński
piotr.mecht is on a distinguished road
Simulation background
I'm trying to perform a buoyantPimpleFoam simulation, but it quickly goes unstable in the first timesteps. The goal is to estimate inlet water jet deviation in domestic hot water tank possibly with different initial conditions and dimensions.
Flow conditions:
initial water temperature (internalField) 42°C
inlet water temperature 20°C
inlet/outlet connector diameter 0.023 m
tank diameter 0.45 m
connectors distance 1.0 m
water flow 3 l/min -> ~0.12 m/s on average (~0.15 m/s max with distributed profile)
Problem solution history
I've tried do reduce timestep, but my Courant number didn't get any smaller.
I also thought my mesh might be bad, because of some concave cells or some single cells with low determinant (checkMesh results), but concave cells are often hard to avoid with snappyHexMesh and they seem to be acceptable in many cases.
I tried to run the same case with fine tetmesh + layers addition + several nOrthogonalCorrectors, but the tendency was the same, so i think now that some other settings might be wrong or they require more tuning.
I blindly played with some fvSolution and fvSchemes, but with similiar results.
Residuals
Enthaply residual in each timestep starts with 1, when static pressure isn't initialized so i helped it with funkySetFields, its initial value reduced significantly but it starts with ~0.7 initial value in second iteration
p_rgh initial residual is >0.4 it seems to be high but it goes serveral orders of magnitude lower in piso and pimple loop (I don't think I understand this output clearly)
Second iteration starts with low max Courant number e.g. ~0.2 , but third or fourth instantly goes to ~100
Omega goes wild in the second iteration with minimum negative value and maximum value of >4.5E+4
Solver crashes whith being unable to converge correct
Output example:
Starting time loop
Courant Number mean: 1.49349e-08 max: 0.02674
Time = 0.0001
diagonal:  Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0
DILUPBiCG:  Solving for Ux, Initial residual = 1, Final residual = 5.48763e-08, No Iterations 3
DILUPBiCG:  Solving for Uy, Initial residual = 1, Final residual = 1.80726e-08, No Iterations 3
DILUPBiCG:  Solving for Uz, Initial residual = 1, Final residual = 2.18823e-08, No Iterations 3
DILUPBiCG:  Solving for h, Initial residual = 0.000321462, Final residual = 1.67432e-07, No Iterations 1
DICPCG:  Solving for p_rgh, Initial residual = 0.996965, Final residual = 0.00952103, No Iterations 479
DICPCG:  Solving for p_rgh, Initial residual = 0.000555127, Final residual = 5.38467e-06, No Iterations 86
DICPCG:  Solving for p_rgh, Initial residual = 5.38737e-06, Final residual = 5.28314e-08, No Iterations 167
DICPCG:  Solving for p_rgh, Initial residual = 5.28319e-08, Final residual = 9.66085e-09, No Iterations 392
[...char limit]
time step continuity errors : sum local = 1.32918e-13, global = -9.31681e-17, cumulative = 3.77663e-16
DICPCG:  Solving for p_rgh, Initial residual = 0.0396398, Final residual = 0.000376473, No Iterations 479
DICPCG:  Solving for p_rgh, Initial residual = 0.000235303, Final residual = 2.23339e-06, No Iterations 85
DICPCG:  Solving for p_rgh, Initial residual = 2.23373e-06, Final residual = 2.03148e-08, No Iterations 170
DICPCG:  Solving for p_rgh, Initial residual = 2.0315e-08, Final residual = 9.81896e-09, No Iterations 378
time step continuity errors : sum local = 1.35542e-13, global = -1.49899e-17, cumulative = 3.62673e-16
DILUPBiCG:  Solving for omega, Initial residual = 1.47021e-05, Final residual = 4.75973e-09, No Iterations 1
bounding omega, min: -52.5363 max: 95779.9 average: 224.474
DILUPBiCG:  Solving for k, Initial residual = 1, Final residual = 2.35803e-08, No Iterations 3
ExecutionTime = 215.67 s  ClockTime = 216 s
Courant Number mean: 1.90016e-05 max: 0.239056
Time = 0.0002
DILUPBiCG:  Solving for Ux, Initial residual = 0.0965107, Final residual = 1.40458e-09, No Iterations 2
DILUPBiCG:  Solving for Uy, Initial residual = 0.233133, Final residual = 3.71724e-09, No Iterations 2
DILUPBiCG:  Solving for Uz, Initial residual = 0.238017, Final residual = 1.34334e-09, No Iterations 2
DILUPBiCG:  Solving for h, Initial residual = 0.608475, Final residual = 9.47492e-10, No Iterations 2
DICPCG:  Solving for p_rgh, Initial residual = 0.488246, Final residual = 0.00484784, No Iterations 461
DICPCG:  Solving for p_rgh, Initial residual = 2.29527e-05, Final residual = 2.23269e-07, No Iterations 87
DICPCG:  Solving for p_rgh, Initial residual = 2.23269e-07, Final residual = 9.84747e-09, No Iterations 85
DICPCG:  Solving for p_rgh, Initial residual = 9.84746e-09, Final residual = 9.84746e-09, No Iterations 0
time step continuity errors : sum local = 3.94984e-11, global = -1.08582e-13, cumulative = -1.08219e-13
[...skipped some for character limit]]
DILUPBiCG:  Solving for omega, Initial residual = 9.8383e-06, Final residual = 2.19925e-07, No Iterations 1
bounding omega, min: -328.374 max: 95813.5 average: 225.052
DILUPBiCG:  Solving for k, Initial residual = 0.0024148, Final residual = 3.30216e-07, No Iterations 4
ExecutionTime = 335.97 s  ClockTime = 336 s
Courant Number mean: 0.00278018 max: 77.708
Time = 0.0003
DILUPBiCG:  Solving for Ux, Initial residual = 0.00294713, Final residual = 5.09134e-07, No Iterations 5
DILUPBiCG:  Solving for Uy, Initial residual = 0.0498396, Final residual = 1.30056e-07, No Iterations 9
DILUPBiCG:  Solving for Uz, Initial residual = 0.245217, Final residual = 8.18823e-07, No Iterations 8
DILUPBiCG:  Solving for h, Initial residual = 0.999938, Final residual = 5.25371e-07, No Iterations 3
DICPCG:  Solving for p_rgh, Initial residual = 0.869755, Final residual = 0.00846313, No Iterations 487
DICPCG:  Solving for p_rgh, Initial residual = 5.09343e-05, Final residual = 4.87965e-07, No Iterations 88
DICPCG:  Solving for p_rgh, Initial residual = 4.87965e-07, Final residual = 9.50119e-09, No Iterations 78
DICPCG:  Solving for p_rgh, Initial residual = 9.50298e-09, Final residual = 9.50298e-09, No Iterations 0
time step continuity errors : sum local = 1.18932e-09, global = 4.01695e-11, cumulative = 4.48692e-11
DICPCG:  Solving for p_rgh, Initial residual = 0.0262778, Final residual = 0.000244534, No Iterations 513
DICPCG:  Solving for p_rgh, Initial residual = 0.000155778, Final residual = 1.50242e-06, No Iterations 79
DICPCG:  Solving for p_rgh, Initial residual = 1.50243e-06, Final residual = 1.48662e-08, No Iterations 215
DICPCG:  Solving for p_rgh, Initial residual = 1.48865e-08, Final residual = 9.91452e-09, No Iterations 4
time step continuity errors : sum local = 1.14702e-09, global = 1.97249e-11, cumulative = 6.45941e-11
DILUPBiCG:  Solving for omega, Initial residual = 0.999996, Final residual = 4.51237e-08, No Iterations 8
bounding omega, min: -154.316 max: 1.68053e+13 average: 4.75822e+08
DILUPBiCG:  Solving for k, Initial residual = 0.965169, Final residual = 5.95112e-07, No Iterations 7
ExecutionTime = 508.91 s  ClockTime = 510 s
Courant Number mean: 0.3024 max: 2550.14
Time = 0.0004
DILUPBiCG:  Solving for Ux, Initial residual = 0.0150419, Final residual = 5.99711e-07, No Iterations 11
DILUPBiCG:  Solving for Uy, Initial residual = 0.236398, Final residual = 4.35313e-07, No Iterations 15
DILUPBiCG:  Solving for Uz, Initial residual = 0.312253, Final residual = 2.32705e-07, No Iterations 15
DILUPBiCG:  Solving for h, Initial residual = 0.99989, Final residual = 6.77965e-07, No Iterations 6
    From function Foam::scalar Foam::species::thermo<Thermo, Type>::T(Foam::scalar, Foam::scalar, Foam::scalar, Foam::scalar (Foam::species::thermo<Thermo, Type>::*)(Foam::scalar, Foam::scalar) const, Foam::scalar (Foam::species::thermo<Thermo, Type>::*)(Foam::scalar, Foam::scalar) const, Foam::scalar (Foam::species::thermo<Thermo, Type>::*)(Foam::scalar) const, bool) const [with Thermo = Foam::hPolynomialThermo<Foam::icoPolynomial<Foam::specie> >; Type = Foam::sensibleEnthalpy; Foam::scalar = double; Foam::species::thermo<Thermo, Type> = Foam::species::thermo<Foam::hPolynomialThermo<Foam::icoPolynomial<Foam::specie> >, Foam::sensibleEnthalpy>]
    in file /home/ubuntu/OpenFOAM/OpenFOAM-dev/src/thermophysicalModels/specie/lnInclude/thermoI.H at line 70
    Energy -> temperature conversion failed to converge:
          [0] iter          Test           e/h          Cv/p          Tnew
          [0] 0       316.267   2.73901e+06          4200      -341.927
          [0] 1      -341.927  -3.12693e+06          4200        396.53
          [0] 2        396.53   3.20771e+06          4200       -373.26
          [0] 3       -373.26  -3.19648e+06          4200       381.757
          [0] 4       381.757   3.11801e+06          4200      -366.676
          [0] 5      -366.676  -3.18078e+06          4200       384.601
          [0] 6       384.601   3.13528e+06          4200      -367.945
          [0] 7      -367.945  -3.18376e+06          4200       384.043
          [char limit saving]
          [0] 100       384.135   3.13245e+06          4200      -367.737
          [0] 101      -367.737  -3.18327e+06          4200       384.135
          [1] iter          Test           e/h          Cv/p          Tnew
          [1] 0       317.791   1.11566e+07          4200      -1245.64
          [1] 1      -1245.64  -6.61605e+06          4200       1422.51
          [1] 2       1422.51   5.20461e+06          4200       1276.22
          [1] 3       1276.22   4.85664e+06          4200       1212.77
          [1] 98       1104.47    4.7527e+06          4200       1065.77
          [1] 99       1065.77   4.81153e+06          4200       1013.06
          [1] 100       1013.06   4.96851e+06          4200       922.981
          [1] 101       922.981   5.52505e+06          4200        700.39
MPI_ABORT was invoked on rank 0 in communicator MPI COMMUNICATOR 3 SPLIT FROM 0
with errorcode 1.
Problem
No clue on how to make anything work. Are my BCs ok? Is my thermophysicalProperties entry any wrong? Should i change anything in fv* dictionaries? Is my mesh to coarse maybe? It's already several milion cells!
Thermophysical
thermoType
    type            heRhoThermo;
    mixture         pureMixture;
    transport       polynomial;
    thermo          hPolynomial;
    equationOfState icoPolynomial;
    specie          specie;
    energy          sensibleEnthalpy;
pRef            100000;
//dpdt off;
mixture
    specie
        molWeight       18;
    equationOfState
        rhoCoeffs<8> (117.045534 7.913913 -0.02254739 1.97987E-05 0 0 0 0);
    thermodynamics
        Hf              0;
        Sf                0;
        CpCoeffs<8> (4200 0 0 0 0 0 0 0);
    transport
        muCoeffs<8> (0.1368992 -0.0012040579 3.5597468E-06 -3.526231E-09 0 0 0 0);
        kappaCoeffs<8> (-2.4283206 0.0233779 -5.9953665E-05 5.2602452E-08 0 0 0 0);
p_rgh
internalField   uniform 1E+5;
boundaryField
    Inlet
        type            fixedFluxPressure;
        gradient        uniform 0;
        value           $internalField;
    Outlet
        type            fixedValue;
    Mantle
        gradient        uniform 0;
    Connectors
        gradient        uniform 0;
    SymmetryY
        type            symmetry;
p
internalField   uniform 1E+5; // initialize with funkySetFields
boundaryField
    Inlet
        type            calculated;
    Outlet
        type            calculated;
    Mantle
        type            calculated;
    Connectors
        type            calculated;
    SymmetryY
        type            symmetry;
velocity
internalField   uniform (0 0 0);
boundaryField
    Inlet
        type            groovyBC;
        //valueExpression "vector(0.015*pow((1-(sqrt(pow(pos().z,2)+pow(pos().y,2))/0.0115)),0.14),0,0)";
        valueExpression "vector(0.15*pow((1-(sqrt(pow(pos().z,2)+pow(pos().y,2))/0.0115)),0.14),0,0)";
        value           uniform (0.12 0 0);
    Outlet
        type            zeroGradient;
    Mantle
        type            noSlip;
    Connectors
        type            noSlip;
    SymmetryY
        type            symmetry;
omega
internalField   uniform 0.937;
boundaryField
    Inlet
        type            fixedValue;
        value           uniform 0.937;
    Outlet
        type            zeroGradient;
    Mantle
        type            omegaWallFunction;
    Connectors
    SymmetryY
        type            symmetry;
k
internalField   uniform 8.44E-5;
boundaryField
    Inlet
        type            fixedValue;
    Outlet
        type            zeroGradient;
    Mantle
        type            kLowReWallFunction;// kqRWallFunction;
    Connectors
    SymmetryY
        type            symmetry;
nut
internalField   uniform 0;
boundaryField
    Inlet
        type            calculated;
    Outlet
        type            calculated;
    Mantle
        type            nutLowReWallFunction; // nutkWallFunction; // nutLowReWallFunction
        value           uniform 0;
    Connectors
        value           uniform 0;
    SymmetryY
        type            symmetry;
T
internalField   uniform 315.15;
boundaryField
    Inlet
        type            fixedValue;
        value           uniform 293.15;
    Outlet
        type            zeroGradient; //inletOutlet;
        //inletValue      315.15 ;//$internalField;
        //value           $internalField;
    Mantle
        type            zeroGradient;
    Connectors
        type            zeroGradient;
    SymmetryY
        type            symmetry;
alphat
boundaryField
    Inlet
        type            calculated;
        value           uniform 0;
    Outlet
        type            calculated;
        value           uniform 0;
    Mantle
        type            compressible::alphatJayatillekeWallFunction;
        Prt             0.85;
        value           uniform 0;
    Connectors
        Prt             0.85;
        value           uniform 0;
    SymmetryY
        type            symmetry;
fvSolution
solvers
    cellDisplacement // OpenFOAM+ only
        solver          GAMG;
        smoother        GaussSeidel;
        tolerance       1E-07;
        relTol          0.01;
    "rho.*"
        solver          PCG;
        preconditioner  DIC;
        tolerance       0;
        relTol          0;
    p_rgh
        solver          PCG;
        preconditioner  DIC;
        tolerance       1e-8;
        relTol          0.01;
        maxIter            2000;    // non-default
    p_rghFinal
        $p_rgh;
        relTol          0;
    omega
        solver          PBiCGStab; // PBiCGStab;
        preconditioner  DILU;
        tolerance       1e-7;
        relTol          0.1;
    h
        tolerance       1e-7;
        relTol          0.01;
    "(U|h|e|k|R)"
        solver          PBiCG; // PBiCGStab;
        tolerance       1e-6;
        relTol          0.1;
        maxIter         1500;
    "(U|h|e|k|omega|R)Final"
        $U;
        relTol          0;
PIMPLE
    momentumPredictor yes;
    nOuterCorrectors 1; //3;
    nCorrectors     4; //3
    nNonOrthogonalCorrectors 1; // 0;
    pRefCell        0;
    pRefValue       1e5;
relaxationFactors
    fields
        p_rgh 0.6;
        p 0.6;
        rho 0.6;
equations
        "U.*" 0.7;
        "rho.*" 0.7;
        "p_rgh.*" 0.7;
        "epsilon" 0.3;
        "omega" 0.3;
        "h" 0.5;
        "k" 0.6;
fvSchemes
ddtSchemes
    default         Euler;
gradSchemes
    default         Gauss linear;
divSchemes
    default         none;
    div(phi,U)      Gauss linearUpwindV grad(U);
    div(phi,h)      Gauss linearUpwind grad(U);
    div(phi,e)      Gauss linearUpwind grad(U);
    div(phi,k)      Gauss linearUpwind grad(omega);
    div(phi,omega)  Gauss linearUpwind grad(omega);
    div(phi,R)      Gauss linearUpwind grad(U);
    div(phi,K)      Gauss linearUpwind grad(U);
    div(phi,Ekp)    Gauss linearUpwind grad(U);
    div(R)          Gauss linearUpwind grad(U);
    div(((rho*nuEff)*dev2(T(grad(U))))) Gauss linear;
laplacianSchemes
    default            Gauss linear uncorrected;
    laplacian(1,p)     Gauss linear corrected;
interpolationSchemes
    default         linear;
snGradSchemes
    default         corrected;
wallDist
    method meshWave;
fluxRequired
    default no;
    p_rgh;
piotr.mecht is offline   Reply With Quote
Old   May 20, 2020, 08:38
Khaled Yassin
Yassin-K is on a distinguished road
Hi piotr.mecht,
Have you found the soultion of this problem??
Best Regards,
Khaled Yassin,
Research Assistant
Institute for Energy and Environmental Research (IEK-14)
Forschungszentrum Jülich
Yassin-K is offline   Reply With Quote
Old   May 23, 2020, 10:15
Piotr Ładyński
Yes!
As the fluid i tried to simulate (water) was changing its density only due to temperature changes, the solver was having hard time trying to calculate pressure-work term.
From OpenFOAM-v1906 source code energy equation looks like:
fvScalarMatrix EEqn
        fvm::ddt(rho, he) + fvm::div(phi, he)
      + fvc::ddt(rho, K) + fvc::div(phi, K)
            he.name() == "e"
          ? fvc::div
                fvc::absolute(phi/fvc::interpolate(rho), U),
                p,
                "div(phiv,p)"
          : -dpdt
      - fvm::laplacian(turbulence->alphaEff(), he)
        rho*(U&g)
      + radiation->Sh(thermo, he)
      + fvOptions(rho, he)
You can disable dpdt calculation, by adding
dpdt off;
line to your thermophysicalProperties dictionary. It's available, when you use sensibleEnthalpy energy equation.
I remember, that buoyantPimpleFoam worked somehow differently in openfoam 7 and OpenFOAM-v1906, and that particular case was crashing in OF7.
My thermophysicalProperties dictionary looked like this:
|  \\    /   O peration     | Version:  v1906                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.com                      |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "constant";
    object      thermophysicalProperties;
thermoType
    type            heRhoThermo;
    thermo          hPolynomial;
    specie          specie;
pRef            1E+5;
dpdt off;
mixture
    specie
        nMoles            1;
        molWeight       18;
    equationOfState
    thermodynamics
        Hf              0;
        Sf                0;
    transport
arvindpj and saidc. like this.
Old   May 23, 2020, 10:33
Khaled Yassin
Thank you very much for your answer....I will try that
Best Regards,
Khaled Yassin,
Research Assistant
Some questions about flow boiling simulation in Fluent beastieboys6 FLUENT 8 November 21, 2017 00:47
Simulation FPEs - turbulence for transient and steady-state? DaveR OpenFOAM Running, Solving & CFD 5 March 5, 2017 16:06
Unstable LES simulation - Courant going higher throughout time - Flow around a sphere beluiz93 OpenFOAM Running, Solving & CFD 11 November 3, 2016 07:05
AMI simulation unstable within first few timesteps craig0a OpenFOAM Running, Solving & CFD 0 February 24, 2014 13:09
3-D Contaminant Dispersal Simulation Apple L S Chan Main CFD Forum 1 December 23, 1998 11:06
