fvOptions-velocity generates against direction of momentum.
Like Tree1Likes
  • 1 Post By mrishi
Old   September 25, 2019, 10:48
Default fvOptions-velocity generates against direction of momentum.
Rishikesh
mrishi is on a distinguished road
Hi all,
I am trying to setup an algebraic body force distribution with pimpleFoam. Previously, this code had worked quite well when I tried with ANSYS Fluent UDFs. However, when I use fvOptions to add momentum source, I find that velocity generated is in opposite direction to the source Term. A simple case to illustrate my point:
1. mesh.png shows the cylindrical bath I am simulating
2. The region marked for adding source (shown in the cross section)
3. The sourceTerm vector
4. and finally, the resultant velocity field that is generated:
There is a clear inversion of direction going from direction of source to direction of velocity, whose reason I can't quite pinpoint.
Things which seem important:
a. the direction of g is (0 -9.81 0), so -ve y direction. Could this be interfering? The solver is pimpleFoam, where createFields creates a sense of height opposite to gravity through through ghRef.H and gh.H.
b. this body force is a toy case for the actual force distribution, which has gaussian decay. I have used simpler expression to verify this "misdirection". Here I have applied a basic constant source term as vectorCodedSource as follows:
codeAddSup
  vectorField& momSource = eqn.source(); //momentum source pointer
    const Time& runTime = mesh_.time();
        const vectorField& C = mesh_.C();
        const scalarField& V = mesh_.V();
//termSource creation with r/w
       volVectorField  termSource
           IOobject
               "termSource",
               runTime.timeName(),
               mesh_,
               IOobject::NO_READ,
               IOobject::AUTO_WRITE
           mesh_,
           dimensionedVector
               "source",
               dimVelocity,
               vector::zero
         volScalarField plumeMarker
             IOobject
                "plumeMarker",
                runTime.timeName(),
                mesh_,
                IOobject::NO_READ,
            mesh_,
            dimensionedScalar
                 "marker",
                 dimless,
                 scalar(0)
//cylindrical polar coordinates
        const scalarField cellRadius = sqrt(pow(C.component(0),2)+pow(C.component(2),2));
        const scalarField cellTan = C.component(1)/cellRadius;
        const scalarField cellHeight = C.component(1);
scalarField Rp = (cellHeight)*0.176; //threshold to mark region of force action
//loop to set values
  forAll(C, i)
      if(cellRadius[i]<Rp[i])
          sourceLocal[i].component(0) = 0.0;
          sourceLocal[i].component(1) = 998.1*9.81; //use of density is redundant, gets divided out later, but keeping it in spirit of the actual algebraic Body force term.
          sourceLocal[i].component(2) = 0.0;
          plumeMarker[i] = 0; //IOobject for postProcess
          termSource[i] = sourceLocal[i]/998.1;
      else
          sourceLocal[i] = vector(0,0,0);
          plumeMarker[i] = 1;
   momSource += sourceLocal/998.1;
   if(runTime.outputTime())
       plumeMarker.write();
       termSource.write();
So effectively, in the central region there is zero net gravity while everywhere else, it is downward. And yet the flow seems to go the other way round. To me it seems an issue of wrong direction specification when the fields are declared, but if i think in terms of global coordinate system, the terms appear to be oriented alright.
I really appreciate help on figuring out what went wrong in the process.
mrishi is offline   Reply With Quote
Old   September 25, 2019, 11:00
Rishikesh
I must add that with reference to above, even with changing the direction of g vector, the reversal from source to actual velocity persists.
The way this source term is added to UEqn is:
tmp<fvVectorMatrix> tUEqn
    fvm::ddt(U) + fvm::div(phi, U)
  + MRF.DDt(U)
  + turbulence->divDevReff(U)
    fvOptions(U)
fvVectorMatrix& UEqn = tUEqn.ref();
so sign reversal of source should not happen considering that it is on RHS.
Old   September 25, 2019, 16:15
Rishikesh
In the documentation of codedSource,
https://cpp.openfoam.org/v6/classFoa...e.html#details
the example shows a sample energySource code, where the sourceTerm is SUBTRACTED instead of adding. Is that really the key to understanding it? It seems very counter-intuitive.
Perhaps I should try and play with some scalar and see how this affects things, does positive source reduce and vice versa?
 codeAddSup
             const Time& time = mesh().time();
             scalarField& heSource = eqn.source();
             heSource -= 0.1*sqr(time.value())*V;
giacomo likes this.
fvoptions momentum source, gravity force
serial udf to parallel udf radioss Fluent UDF and Scheme Programming 10 January 19, 2019 09:56
How to achieve actual velocity profile at the inlet (y-axis direction) hanis_iz Fluent UDF and Scheme Programming 1 November 19, 2018 07:07
Air diffuser velocity magnitude and direction kenzosenzo FLUENT 17 March 31, 2014 08:03
Derivation of Momentum Equation in Integral Form Demonwolf Main CFD Forum 2 October 29, 2009 20:53
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 10:11
