September 23, 2019, 18:36 |
Cannot find patchField entry for inletfuel
Keshawa Bandara
I am new to OpenFOAM and got the below error message when I was trying to run a custom solver which was developed using reactingFoam solver. Code:
--> FOAM FATAL IO ERROR: Cannot find patchField entry for inletfuel file: /home/keshawa/OpenFOAM/keshawa-7/run/reactingFoam/adsorpFoam/0/p.boundaryField from line 26 to line 44. From function void Foam::GeometricField<Type, PatchField, GeoMesh>::Boundary::readField(const Foam::DimensionedField<TypeR, GeoMesh>&, const Foam::dictionary&) [with Type = double; PatchField = Foam::fvPatchField; GeoMesh = Foam::volMesh] in file /opt/openfoam7/src/OpenFOAM/lnInclude/GeometricBoundaryField.C at line 191. FOAM exiting Code:
dimensions [1 -1 -2 0 0 0 0]; internalField uniform 101325; boundaryField { inlet { type zeroGradient; } outlet { type inletOutlet; inletValue uniform 101325; value uniform 101325; } adsorptwall { type zeroGradient; } wall { type zeroGradient; } frontAndBack { type zeroGradient; } } Thanks for your time, Kesh |
September 24, 2019, 04:32 |
Yann
Rep Power: 29 |
Hi Kesh,
In your mesh, you have a patch named "inletfuel" but it is not defined in your 0/p files (there is "inlet" instead). You need to define a boundary condition for the patch "inletfuel" for every variable in 0. Cheers, Yann |
September 25, 2019, 19:13 |
Keshawa Bandara
Thanks so much for taking time to help me. In fact I was wrong to keep the inletfuel patch. I removed that and made outlet type as fixed value. That worked for me.
Thanks again Yann. |
Cannot find patchField entry for InletWall | range_rover | OpenFOAM Running, Solving & CFD | 5 | November 18, 2020 22:21 |
Parallel snappyHexMesh problem: Cannot find patchField entry for procBoundary2to7 | hconel | OpenFOAM Pre-Processing | 0 | October 5, 2018 18:22 |
OpenFOAM 1.6-ext git installation on Ubuntu 11.10 x64 | Attesz | OpenFOAM Installation | 45 | January 13, 2012 13:38 |
Problem Building OF on Centos cluster (no admin rights) | CKH | OpenFOAM Installation | 5 | November 13, 2011 07:32 |
Converting Starccm+ mesh | Ladnam | OpenFOAM | 0 | September 14, 2011 07:30 |
