buoyantBoussinesqPimpleFoam - false result in the corner |
Grivalszki Péter
Rep Power: 7 ![]() |
I'm trying to simulate a simple heat transfer case (getting to know the software for further researches) with buoyantBoussinesqPimpleFoam. Unfortunately, I have some numeric error in the results (pictures attached). Why is this weird field in the corner? How can I get rid of it? Thank you in advance! Griva Last edited by GrivalszkiP; September 21, 2019 at 05:19. |
Eren
Rep Power: 9 ![]() |
As a novice myself, you need to share your files too. All I can assume is you have way too course mesh. I modified buoyantBoussinesqPimpleFoam and used many times and never had this kind of issue.
Grivalszki Péter
Thank you, but I don't think so... Anyway, here are my files:
U PHP Code:
PHP Code:
PHP Code:
PHP Code:
PHP Code:
PHP Code:
PHP Code:
PHP Code:
PHP Code:
PHP Code:
PHP Code:
PHP Code:
PHP Code:
Kirk Jarvis
Rep Power: 17 ![]() |
The boundary conditions for the outlet appears to be a problem.
for p_rhg try something like: outlet { type fixedValue; value $internalField; } for U try something like: outlet { type inletOutlet; inletValue uniform (0 0 0); value uniform (0 0 0); } for T try something like: outlet { type inletOutlet; inletValue $internalField; value $internalField; } You should get good results with the above recommendations. |
Grivalszki Péter
Thank you, it's working!!
boussinesq, buoyant, corner, error, heat |
[snappyHexMesh] How to generate Layers at the corner | amin.nbkh | OpenFOAM Meshing & Mesh Conversion | 3 | June 22, 2023 10:46 |
[snappyHexMesh] Problem with prism layers at corner edges | Fauster | OpenFOAM Meshing & Mesh Conversion | 1 | September 30, 2016 00:25 |
Corner flows | akivarma | Main CFD Forum | 0 | February 15, 2016 03:00 |
Sharp corner with O-grid non-convergence | dlinton | OpenFOAM Running, Solving & CFD | 16 | October 7, 2015 05:54 |
[GAMBIT] 3D Wedge Corner Shape? | cjz | ANSYS Meshing & Geometry | 1 | October 29, 2010 03:03 |
