Solving flow past cylinder submerged near a free surface
Like Tree1Likes
  • 1 Post By venkcy
Old   September 19, 2019, 06:49
Default Solving flow past cylinder submerged near a free surface
venkcy is on a distinguished road
Greetings!
I am trying to simulate flow field of cylinder submerged near a free surface. I am not able to validate the results with the published literature even qualitatively under the same nondimensional parameters. I believe the problem might be in the boundary conditions.
I am attaching the boundary condition files for alpha, pressure and velocity. I need your kind feedback.
Thanks for your time.
//alpha
dimensions      [0 0 0 0 0 0 0];
internalField   uniform 0;
boundaryField
    inletAir
        type            fixedValue;
        value           uniform 0;
    inletWater
        type            fixedValue;
        value           uniform 1;
    outlet
        type            zeroGradient;
    ground
        type            zeroGradient;
    cylinder
        type            zeroGradient;
    sides
        type            empty;
    top
        type            zeroGradient;
//pressure
dimensions      [1 -1 -2 0 0 0 0];
boundaryField
    inletAir
        type            zeroGradient;
        value           uniform 0;
    inletWater
        type            zeroGradient;
        value           uniform 0;
    outlet
        type            zeroGradient;
        //p0              uniform 0;
    ground
        type            fixedFluxPressure;
        value           uniform 0;
    top
        value           uniform 0;
    cylinder
        type            zeroGradient;
    sides
        type            empty;
//Velocity
dimensions      [0 1 -1 0 0 0 0];
internalField   uniform (0.018 0 0);
boundaryField
    inletAir
        type            fixedValue;
        value           uniform (0.018 0 0);
    inletWater
        type            fixedValue;
    outlet
        type            zeroGradient;
        value           uniform (0 0 0);
    sides
        type            empty;
    cylinder
        type            fixedValue;
    top
        type            slip;
    ground
        type            slip;
irengclenk likes this.
venkcy is offline   Reply With Quote
Old   September 24, 2024, 07:13
Default Did you get answer for your question
John Philip
John Philip is on a distinguished road
John Philip is offline   Reply With Quote
cylinder laminar, free surface flow, interfoam
Internal Flow Instability with layers Zephiro88 OpenFOAM Running, Solving & CFD 1 June 20, 2019 05:20
Segmentation fault when using reactingFOAM for Fluids Tommy Floessner OpenFOAM Running, Solving & CFD 4 April 22, 2018 13:30
Floating point exception error lpz_michele OpenFOAM Running, Solving & CFD 53 October 19, 2015 03:50
calculation stops after few time steps sivakumar OpenFOAM Running, Solving & CFD 7 March 17, 2013 07:37
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 bookie56 OpenFOAM Installation 8 August 13, 2011 05:03
