Using the matchedFlowRateOutletVelocity boundary condition
Like Tree1Likes
  • 1 Post By bshambaugh
Old   September 16, 2019, 23:28
Default Using the matchedFlowRateOutletVelocity boundary condition
Brent Shambaugh
bshambaugh is on a distinguished road
Forgive me, I am not sure what to ask. I am trying to use the matchedFlowRateOutletVelocity boundary condition for compressible flow, and I am not sure what sorts of things are allowable for boundary conditions with this condition. I came up with some questions:
When matchedFlowRateOutletVelocity is applied as a boundary condition for U, what should the boundary conditions be for p, T, nut, k, epsilon, and alpat when running with rhoSimpleFoam?
More simply when matchedFlowRateOutletVelocity is applied as a boundary condition for U, what
should p and T be when running rhoPimpleFoam?
I usually get an error like this. Maybe I cannot use the calculated b.c. Perhaps, fixedValue?
--> FOAM FATAL ERROR:
cannot be called for a calculatedFvPatchField
on patch fineMeshOutletLeft of field e in file "/home/brent/OpenFOAM/brent-7/run/tutorials/compressible/rhoPimpleFoam/laminar/b2_forwardStep/0/e"
You are probably trying to solve for a field with a default boundary condition.
From function Foam::tmp<Foam::Field<Type> > Foam::calculatedFvPatchField<Type>::gradientIntern alCoeffs() const [with Type = double]
in file fields/fvPatchFields/basic/calculated/calculatedFvPatchField.C at line 188.
object T;
type calculated;
value $internalField;
object p;
type calculated;
erinsam likes this.
bshambaugh is offline   Reply With Quote
sliding mesh problem in CFX Saima CFX 46 September 11, 2021 08:38
Centrifugal fan j0hnny CFX 13 October 1, 2019 14:55
Accessing multiple boundary patches from a custom boundary condition file ripudaman OpenFOAM Programming & Development 0 October 22, 2014 19:34
Radiation interface hinca CFX 15 January 26, 2014 18:11
An error has occurred in cfx5solve: volo87 CFX 5 June 14, 2013 18:44
