Unable to run allrun scripts
Like Tree1Likes
  • 1 Post By rdajohansson
Old   September 12, 2019, 14:12
Default Unable to run allrun scripts
Sujay
sujay3101 is on a distinguished road
I have some allrun scripts that work completely fine on windows subsystem for linux.
I'm however unable to run them on a virtual machine running on linux.
some info:
the main allrun script calls other allrun scripts in subdriectories.
The allrun scripts were copied and edited from a random tutorial directory.
Both - the windows subsystem for linux as well as the virtual machine are running the same version: OF1906
I have tried the following:
chmod -R a+rX * on each directory with the allrun scripts.
now I get the message :
Can't open /bin/tools/RunFunctions
However, if I run a copy of an existing tutorial in the same directory, it runs.
Any suggestions about what might be going wrong and how it can be fixed?
sujay3101 is offline   Reply With Quote
Old   September 13, 2019, 08:52
Carlo_P
Carlo_P is on a distinguished road
...maybe can be \ instead of / ?
Carlo_P is offline   Reply With Quote
Old   September 13, 2019, 08:56
Sujay
I don't think so.
Cant see any difference in the content of the script that is working and the ones that are not.
Old   September 13, 2019, 12:33
Peter Hess
peterhess is on a distinguished road
open a terminal and type:
simpleFoam -help
If the system is giving such an output (must not be identical), then that means that openfoam is installed correctly and the problem is in the script...
if not then type:
gedit ~/.bashrc
at the ende of the file you opened type:
source /opt/openfoam7/etc/bashrc
then save and restart the terminal and retest.
Regards
Peter
peterhess is offline   Reply With Quote
Old   January 25, 2020, 17:49
Sverige
rdajohansson is on a distinguished road
Maybe it's the line termination.
Test by writing
file "filename" ex file Allrun and you will see
"filename": POSIX shell script, ASCII text executable, with CRLF line terminators
linux doesn't use CRLF (windows) of CR (mac), you can remove them by
sed -i 's/\r$//g' "filename"
ex sed -i 's/\r$//g' Allrun
njdyck likes this.
rdajohansson is offline   Reply With Quote
allrun script, bash on ubuntu on windows, openfoam
Scripts to run fluent in Linux cluster via windows sanjaykummar2810 FLUENT 1 September 19, 2018 17:23
[OpenFOAM] Unable to run paraview vaibhavkhare ParaView 1 July 23, 2018 15:44
Unable to run the case parallel using foam-extend in the cluster farahaqilah OpenFOAM 0 July 28, 2016 00:49
[snappyHexMesh] Able to run snappyHexMesh in parallel on local machine but unable to run on linux clu abhinav2601 OpenFOAM Meshing & Mesh Conversion 1 January 26, 2015 06:42
[OpenFOAM] Unable to run pvserver in parallel md_lieber ParaView 3 November 18, 2010 08:12
