September 10, 2019, 10:01 |
InterDyMFoam on damBreak 2D
X
Rep Power: 7 |
I am trying to use dynamic mesh refinement on the damBreak laminar case.
I copied the dynamicMeshDict file into the constant and included Code:
correctFluxes ( (phi none) (nHatf none) (rhoPhi none) (ghf none) (flux(alpha.water) none) ); I run blockMesh, setFields and interDyMFoam. After couple of time steps, it crashes with the error. Last part of the log file Code:
Selected 50 cells for refinement out of 50484. Refined from 50484 to 50834 cells. Selected 32 split points out of a possible 6061. Unrefined from 50834 to 50610 cells. Execution time for mesh.update() = 0.7 s DICPCG: Solving for pcorr, Initial residual = 1, Final residual = 9.294e-06, No Iterations 221 time step continuity errors : sum local = 3.80198e-09, global = -4.05311e-11, cumulative = 0.00084144 smoothSolver: Solving for alpha.water, Initial residual = 0.00141145, Final residual = 9.27232e-10, No Iterations 3 Phase-1 volume fraction = 0.130176 Min(alpha1) = -1.67578e-06 Max(alpha1) = 1 MULES: Correcting alpha.water MULES: Correcting alpha.water Phase-1 volume fraction = 0.130176 Min(alpha1) = -2.70158e-05 Max(alpha1) = 1 DICPCG: Solving for p_rgh, Initial residual = 0.0615071, Final residual = 0.00273732, No Iterations 2 time step continuity errors : sum local = 0.000159835, global = -9.99339e-07, cumulative = 0.000840441 DICPCG: Solving for p_rgh, Initial residual = 0.00378723, Final residual = 0.000157494, No Iterations 9 time step continuity errors : sum local = 9.10954e-06, global = -1.33525e-07, cumulative = 0.000840307 DICPCG: Solving for p_rgh, Initial residual = 0.000898502, Final residual = 9.3117e-08, No Iterations 193 time step continuity errors : sum local = 5.38355e-09, global = 5.51327e-12, cumulative = 0.000840307 ExecutionTime = 699.25 s ClockTime = 700 s Interface Courant Number mean: 0.00970562 max: 0.746663 Courant Number mean: 0.0885415 max: 0.993028 deltaT = 0.000191888 Time = 0.321025 Selected 18 cells for refinement out of 50610. Refined from 50610 to 50736 cells. Selected 23 split points out of a possible 6049. Unrefined from 50736 to 50575 cells. Execution time for mesh.update() = 0.7 s DICPCG: Solving for pcorr, Initial residual = 1, Final residual = 8.91003e-06, No Iterations 210 time step continuity errors : sum local = 1.37086e-09, global = 6.65906e-11, cumulative = 0.000840307 smoothSolver: Solving for alpha.water, Initial residual = 0.00141824, Final residual = 9.28577e-10, No Iterations 3 Phase-1 volume fraction = 0.130175 Min(alpha1) = -9.66966e-07 Max(alpha1) = 1 MULES: Correcting alpha.water MULES: Correcting alpha.water Phase-1 volume fraction = 0.130175 Min(alpha1) = -0.000515445 Max(alpha1) = 1 DICPCG: Solving for p_rgh, Initial residual = 0.059735, Final residual = 0.00258301, No Iterations 2 #0 Foam::error::printStack(Foam::Ostream&) at ??:? #1 Foam::sigFpe::sigHandler(int) at ??:? #2 Uninterpreted: #3 at tensorField.C:? #4 at ??:? #5 at ??:? #6 at ??:? #7 at ??:? #8 __libc_start_main in "/lib/i386-linux-gnu/libc.so.6" #9 at ??:? Floating point exception (core dumped) I have attached the screenshot (Left) dynamic mesh refinement - interDyMFoam (right) just interFoam I couldn't find anything on the error. |
September 11, 2019, 05:13 |
anonymous
Rep Power: 14 |
Hi!
Dynamic refinement is using the hexRef8 engine, so you cut every cell into 8. Thus you cannot use in 2D case, since you cut the cells in the 3rd dimension too. I had similar problems with it in 2D. And I think it must be because of the 2D case, since in 3D cases is working for me without any problems. Try to replace the empty patches with symmetry, or with simple walls but slip for U, and zeroGradient p, etc... Just a guess. I didn't spent too much time with it to find the solution. |
September 11, 2019, 09:51 |
X
Rep Power: 7 |
Thanks for the reply. It gave me more idea about dynamic mesh refinement. I was able to find another forum which spoke AMR.
2D adaptive Mesh Refinement The attachment from #20 has 2D as well as axi refinement - however, I am unable to compile it. Trying to convert into 3D case as well. |
September 24, 2021, 07:56 |
#4 | |
Viktor Klüber
Rep Power: 8 |
interDyMFoam with VOF + 6DOF instable | pbalz | OpenFOAM Running, Solving & CFD | 11 | October 9, 2020 05:19 |
Restart InterDymFoam simulation from latestTime | Giovanni_Do | OpenFOAM Running, Solving & CFD | 2 | April 11, 2019 05:22 |
interDyMFoam + dambreak | J.Y.Won | OpenFOAM Running, Solving & CFD | 0 | October 29, 2014 06:15 |
modifying interDyMFoam for floatingObject | Elisabeth_ofoam | OpenFOAM Programming & Development | 7 | June 11, 2014 08:42 |
error using interDyMFoam with kOmegaSST to simulate sloshing | anmartin | OpenFOAM Running, Solving & CFD | 0 | July 20, 2010 13:21 |
