#sinclude "sampling" in controlDict dictionary
Like Tree1Likes
  • 1 Post By snak
Old   September 10, 2019, 08:09
Default #sinclude "sampling" in controlDict dictionary
philip lu
philiplu is on a distinguished road
does someone know what's the objective of
in
from the tutorial
$FOAM TUTORIALS/multiphase/interFoam/laminar/damBreak/damBreak
the tutorial-links:
https://develop.openfoam.com/Develop...amBreak/system
thank you in advance
philiplu is offline   Reply With Quote
Old   September 10, 2019, 21:39
shinji nakagawa
snak is on a distinguished road
Hi
Some info...
https://www.openfoam.com/documentati...y.html#details
The #sinclude directive (and the #includeIfPresent alias) behaves identically to the #include directive, but does not generate an error if the file does not exist.
And, the #include directive for including a file, expects a single string to follow.
salehi144 likes this.
snak is offline   Reply With Quote
Old   September 11, 2019, 07:22
Default thank you
philip lu
Hello, snak,
thanks for the reply and sure, it helps.
another concern:
literally I guess
ONLY samples data during the solving, WITHOUT any impact on solving results...
As I'm not familiar with the OF-background-mechanism yet, so to rephrase my concern:
#sinclude "sampling" won't influence the results, right?
additionally: 1 question, 1 confirmation:
what's "phirb"?
confirmation:
i.e. pressure, if its input unit is e.g. m2/s2, then that of out-coming results stay still in the same unit (m2/s2), put simply
input in e.g. m2/s2
results still in m2/s2
right?
thank you and OF-friends in advance
Old   September 13, 2019, 05:10
shinji nakagawa
Originally Posted by philiplu View Post
another concern:
literally I guess
Yes.
#sinclude itself do nothing. Just copy and paste the content of the file.
In your case (damBreak), "type set" in "sample library" will do its job.
There should be no impact on solving.
what's "phirb"?
phirb is related to a compression velocity.
Details are explained in the PhD thesis by Henrik Rusche. It appears in eq.(4.14).
https://spiral.imperial.ac.uk/handle/10044/1/8110
confirmation:
input in e.g. m2/s2
right?
Yes.
You can check it by looking the output file itself.
A file wrriten as a result also have a line of "dimensions".
Old   September 16, 2019, 01:28
Default thank you, snak
philip lu
hello, snak,
thanks for your scientifically summarized and clear answers, alleviating my "worry" essentially e.g. that p switches to kgm-1s-2 as output.
as I'm even new i.e. just start, online to post sth, so forgive my further Qs without self-refraining rationally:
Q1:
(still in damBreak case as in preceding posts)
as in the sampling file:
sets
gauge_1
type face;
axis y;
start (0.02 0.20 0.005);
end (0.02 0.25 0.005);
nPoints 100;
gauge_2
type face;
axis y;
start (0.2 0.03 0.005);
end (0.2 0.55 0.005);
nPoints 100;
what's the "nPoints 100"? 100 sample-points between e.g. 0.20-0.25 (0.03-0.55) of y?
anyhow, i checked the output: the output number i.e. number of points are different betwwen gauge_1 and _2 and neither is 100
Q2:
the output-format is vtk, certainly using e.g. python or math-software, even manually excel, the sampling output can be plotted. But paraView must be capable to visualize them.
i tried, individually (in one time step, e.g. one gauge) but without success, so do you or someone knows how to plot them in paraview?
Q3:
still Q2 related, when the time-steps exceeds e.g. 100, how to import them into paraview in batch (if paraview can plot them individually)
regards
Old   September 16, 2019, 06:08
Default additional
philip lu
hello, snak and OFOAM-friends
after an insight of UserGuide, the "face" (an example as in appendix) states:
"Intersection of specified line and cell faces"
then the "nPoints", i.e. "Number of sampling points" (e.g. =100 here) could be overridden, since
number of intersection won't always coincide with the (randomly decided) "Number of sampling points" (e.g. =100 here), right?
thank you and regards
____________________________
appendix:
sets
gauge_1
type face;
axis y;
nPoints 100;
What are dictionaries in Openfoam ? granzer OpenFOAM 3 November 25, 2020 01:47
driftFluxFoam viscosity model modification problem dleduc OpenFOAM Programming & Development 15 October 1, 2018 10:37
ill defined primitiveEntry starting at keyword 'value' on line 197 ChangeDictionary Struggle_Achieve OpenFOAM Pre-Processing 2 December 20, 2017 04:58
Specifying probe locations in controlDict using dictionary file vincent OpenFOAM Bugs 3 December 31, 2008 05:25
Problem with rhoSimpleFoam matteo_gautero OpenFOAM Running, Solving & CFD 0 February 28, 2008 07:51
