Issue with topoSetDict file
Like Tree1Likes
  • 1 Post By ingraban
Old   September 1, 2019, 11:56
Default Issue with topoSetDict file
MarineAiry's Avatar
Berin
MarineAiry is on a distinguished road
Dear All,
I am facing an issue with the topoSetDict file, as I currently don't know how to edit properly this file.
It is shown below:
  \\      /  F ield         | OpenFOAM: The Open Source CFD Toolbox
   \\    /   O peration     | Website:  https://openfoam.org
    \\  /    A nd           | Version:  6
     \\/     M anipulation  |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "system";
    object      topoSetDict;
actions
        name    c0;
        type    cellSet;
        action  new;
        source  boxToCell;
        sourceInfo
            box (-20 -15 -0.4) (13 0 5);
When I try to type this command:
$ topoSet -dict system/topoSetDict.1
I get this error:
|  \\    /   O peration     | Version:  5.x                                   |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
/*   Windows 32 and 64 bit porting by blueCAPE: http://www.bluecape.com.pt   *\
|  Based on Windows porting (2.0.x v4) by Symscape: http://www.symscape.com   |
Build  : 5.x-963176928289
Exec   : D:/PROGRAMMI/blueCFD-Core-2017/OpenFOAM-5.x/platforms/mingw_w64GccDPInt32Opt/bin/topoSet.exe -dict system/topoSetDict.1
Date   : Sep 01 2019
Time   : 16:41:34
Host   : "DESKTOP-8DN55BA"
PID    : 48568
I/O    : uncollated
Case   : D:/PROGRAMMI/blueCFD-Core-2017/ofuser-of5/run/IWWTC_Model
nProcs : 1
SigFpe : Enabling floating point exception trapping (FOAM_SIGFPE).
fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 10)
allowSystemOperations : Allowing user-supplied system call operations
Create time
Create polyMesh for time = 0
Reading topoSetDict
--> FOAM FATAL ERROR:
cannot find file "D:/PROGRAMMI/blueCFD-Core-2017/ofuser-of5/run/IWWTC_Model/system/topoSetDict.1"
    From function virtual Foam::autoPtr<Foam::ISstream> Foam::fileOperations::uncollatedFileOperation::readStream(Foam::regIOobject&, const Foam::fileName&, const Foam::word&, bool) const
    in file global/fileOperations/uncollatedFileOperation/uncollatedFileOperation.C at line 522.
FOAM exiting
What is wrong ?
Thank you all for any help you might be able to provide,
Berin
MarineAiry is offline   Reply With Quote
Old   September 2, 2019, 05:22
ingraban's Avatar
Ingo Riess
ingraban is on a distinguished road
From the error message, I conclude that topoSet is unable to find the topoSetDict.1 you specified. Either the path or the filename are incorrect. I have to admit, I only use the file standard filename topoSetDict in the system folder. Consequently, I don't need the -dict option.
MarineAiry likes this.
ingraban is offline   Reply With Quote
Old   September 4, 2019, 14:13
MarineAiry's Avatar
Berin
@ingraban Thank you for your response.
It helped me because I made a really banal mistake by ignoring the real name of the TopoSet file, which was "topoSetDict.1.1", because I didn't see the extension file.
I use a text editor which sometimes implies changes in the extension file, e.g. add a number to my file's name.
Thank you a lot !!
[Other] Tabulated thermophysicalProperties library chriss85 OpenFOAM Community Contributions 62 October 2, 2022 04:50
[swak4Foam] Installation Problem with OF 6 version Aurel OpenFOAM Community Contributions 14 November 18, 2020 17:18
OpenFoam "Permission denied" and "command not found" problems. iyidaniel@yahoo.co.uk OpenFOAM Running, Solving & CFD 11 January 2, 2018 07:47
[swak4Foam] build problem swak4Foam OF 2.2.0 mcathela OpenFOAM Community Contributions 14 April 23, 2013 14:59
friction forces icoFoam ofslcm OpenFOAM 3 April 7, 2012 11:57
