chtMultiRegionFoam on multiple cores, run-time increases? |
August 28, 2019, 08:24 |
Vincent
Rep Power: 7 |
Hello fellow foamers,
I am currently working on some heat transfer problems using the chtMultiRegionFoam solver. I want to speed up the solving process by running a decomposed case. To find out how much I would benefit from using multiple cores I tried to run a similar case in single core and multi-core mode. The results had the same quality (in terms of U, T and p), but the run time wasn't as I expected. Here are my results: ~20 000 cells 1 core -> 875s 2 cores -> 1022s ~225 000 cells 1 core -> 57046s 4 cores -> 58539s Now I have some questions: - is it possible, that I didnt use enough cells, per core? I read at about 50 000/core the time will reduce. - is it important to decompose the case in a special way? I used the simple method. Thank you already, Vince. |
August 28, 2019, 09:08 |
anonymous
Rep Power: 14 |
Hi!
Try with scotch method. It will tries to decompose the case on a way that the communication between the processors is minimal. Also a renumberMesh can help. Based on my experiences OF is scaling pretty well. |
August 28, 2019, 09:35 |
scotch
Vincent
Rep Power: 7 |
Thank you for your reply simrego.
I decomposed with scotch and am currently running the case. It might take some time till I can update, as I only work with OF on one day per week. Greetings |
chtmultiregionfoam, decomposed, multi-cores |
pimpleDyMFoam computation randomly stops | babapeti | OpenFOAM Running, Solving & CFD | 5 | January 24, 2018 06:28 |
How to run OpenFOAM using Shared Memory method on local machine with multiple cores? | ronithstanly | OpenFOAM Running, Solving & CFD | 1 | August 4, 2017 01:31 |
pressure in incompressible solvers e.g. simpleFoam | chrizzl | OpenFOAM Running, Solving & CFD | 13 | March 28, 2017 06:49 |
Transient run continues from last time (when startover is desired) | bongbang | CFX | 2 | March 23, 2015 00:05 |
calculation diverge after continue to run | zhajingjing | OpenFOAM | 0 | April 28, 2010 05:35 |
