chtMultiRegion cannot achieve no slip boundary condition on the interface |
August 23, 2019, 14:22 |
Rep Power: 7 |
Dear Foamers ,
I am trying to conduct a multi region heat transfer simulation using chtMultiRegionSimpleFoam. I started big and things were going wrong so now I have a very simple geometry of two cubes (i.e. fluids) sharing an interface. The boundary condition on the interface for velocity in both regions is specified as: Code:
one_to_two { type fixedValue; value uniform (0 0 0); } Code:
two_to_one { type fixedValue; value uniform (0 0 0); } Code:
paraFoam - builtin I'm using wall functions and checked y+ which is in range 30<y+<300 Some further info for fvSolution: Code:
"(U|h|e|k|epsilon)" { solver PBiCGStab; preconditioner DILU; tolerance 1e-6; relTol 1e-3; } Code:
ddtSchemes { default steadyState; } gradSchemes { default Gauss linear; } divSchemes { default none; div(phi,U) bounded Gauss upwind; div(phi,h) bounded Gauss upwind; div(phi,e) bounded Gauss limitedLinear 1; div(phi,K) bounded Gauss upwind; div(phi,k) bounded Gauss upwind; div(phi,epsilon) bounded Gauss upwind; div(((rho*nuEff)*dev2(T(grad(U))))) Gauss linear; } laplacianSchemes { default Gauss linear corrected; } interpolationSchemes { default linear; } snGradSchemes { default corrected; } |
August 24, 2019, 07:03 |
Peter Hess
Rep Power: 17 |
Hello!
I can not see where is the problem and can not give you a direct answer. Anyway, I have a case, where I have two regions with solid and fluid regions. I modified the case to have just fluids as in your case and made the necessary changes to let it run. I tested the case and the velocity at walls (interfaces) are zero! All I can do is to give you the working case and you could compare your case with mein to see where is the problem/difference. Just run Allrun. The mesh is generated using Salome 8.5. OF7.0 is used! If the problem still exists please share the case and let me have a closer look to the setups. Post a feedback please, also if you fixed the problem to share experiences. Regards Peter https://drive.google.com/file/d/1GfD...ew?usp=sharing Last edited by peterhess; August 25, 2019 at 12:53. |
August 27, 2019, 16:38 |
#3 | |
Rep Power: 7 |
Thank you very much for your reply and sharing the file. I tried to run the case but got some errors. I could resolve two of them but the last one is not going away (probably due to the OF version difference ?) The error is: Code:
[1] #0 Foam::error::printStack(Foam::Ostream&)[2] #0 Foam::error::printStack(Foam::Ostream&)[0] #0 Foam::error::printStack(Foam::Ostream&)[3] #0 Foam::error::printStack(Foam::Ostream&) at ??:? [1] #1 Foam::sigFpe::sigHandler(int) at ??:? [2] #1 Foam::sigFpe::sigHandler(int) at ??:? at ??:? [3] #1 Foam::sigFpe::sigHandler(int)[0] #1 Foam::sigFpe::sigHandler(int) at ??:? [2] #2 ? at ??:? [1] #2 ? at ??:? [0] #2 ? at ??:? [3] #2 ? in /lib/x86_64-linux-gnu/libc.so.6 [1] #3 Foam::divide(Foam::Field<double>&, Foam::UList<double> const&, Foam::UList<double> const&) in /lib/x86_64-linux-gnu/libc.so.6 [2] #3 Foam::divide(Foam::Field<double>&, Foam::UList<double> const&, Foam::UList<double> const&) in /lib/x86_64-linux-gnu/libc.so.6 [3] #3 Foam::divide(Foam::Field<double>&, Foam::UList<double> const&, Foam::UList<double> const&) in /lib/x86_64-linux-gnu/libc.so.6 [0] #3 Foam::divide(Foam::Field<double>&, Foam::UList<double> const&, Foam::UList<double> const&) at ??:? [1] #4 Foam::operator/(Foam::UList<double> const&, Foam::UList<double> const&) at ??:? [2] #4 Foam::operator/(Foam::UList<double> const&, Foam::UList<double> const&) at ??:? [3] #4 Foam::operator/(Foam::UList<double> const&, Foam::UList<double> const&) at ??:? [0] #4 Foam::operator/(Foam::UList<double> const&, Foam::UList<double> const&) at ??:? [1] #5 Foam::diagonalSolver::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const at ??:? [2] #5 Foam::diagonalSolver::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const at ??:? at ??:? [3] #5 Foam::diagonalSolver::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const[0] #5 Foam::diagonalSolver::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const at ??:? [1] #6 Foam::fvMatrix<double>::solveSegregated(Foam::dictionary const&) at ??:? [2] #6 Foam::fvMatrix<double>::solveSegregated(Foam::dictionary const&) at ??:? [3] #6 Foam::fvMatrix<double>::solveSegregated(Foam::dictionary const&) at ??:? [0] #6 Foam::fvMatrix<double>::solveSegregated(Foam::dictionary const&) at ??:? [1] #7 Foam::fvMatrix<double>::solveSegregatedOrCoupled(Foam::dictionary const&) at ??:? [2] #7 Foam::fvMatrix<double>::solveSegregatedOrCoupled(Foam::dictionary const&) at ??:? [3] #7 Foam::fvMatrix<double>::solveSegregatedOrCoupled(Foam::dictionary const&) at ??:? [0] #7 Foam::fvMatrix<double>::solveSegregatedOrCoupled(Foam::dictionary const&) at ??:? [1] #8 Foam::fvMesh::solve(Foam::fvMatrix<double>&, Foam::dictionary const&) const at ??:? [2] #8 Foam::fvMesh::solve(Foam::fvMatrix<double>&, Foam::dictionary const&) const at ??:? [3] #8 Foam::fvMesh::solve(Foam::fvMatrix<double>&, Foam::dictionary const&) const at ??:? [0] #8 Foam::fvMesh::solve(Foam::fvMatrix<double>&, Foam::dictionary const&) const at ??:? [1] #9 at ??:? [2] #9 Foam::fvMatrix<double>::solve()Foam::fvMatrix<double>::solve() at ??:? [3] #9 in ~/OpenFOAM/OpenFOAM-v1812/platforms/linux64GccDPInt32Opt/bin/chtMultiRegionFoam [2] #10 in ~/OpenFOAM/OpenFOAM-v1812/platforms/linux64GccDPInt32Opt/bin/chtMultiRegionFoam [1] #10 at ??:? [0] #9 Foam::fvMatrix<double>::solve()??Foam::fvMatrix<double>::solve() in ~/OpenFOAM/OpenFOAM-v1812/platforms/linux64GccDPInt32Opt/bin/chtMultiRegionFoam [3] #10 in ~/OpenFOAM/OpenFOAM-v1812/platforms/linux64GccDPInt32Opt/bin/chtMultiRegionFoam [2] #11 __libc_start_main in ~/OpenFOAM/OpenFOAM-v1812/platforms/linux64GccDPInt32Opt/bin/chtMultiRegionFoam [1] #11 __libc_start_main in ~/OpenFOAM/OpenFOAM-v1812/platforms/linux64GccDPInt32Opt/bin/chtMultiRegionFoam [0] #10 ? in /lib/x86_64-linux-gnu/libc.so.6 [2] #12 in /lib/x86_64-linux-gnu/libc.so.6 [1] #12 ??? in ~/OpenFOAM/OpenFOAM-v1812/platforms/linux64GccDPInt32Opt/bin/chtMultiRegionFoam [3] #11 __libc_start_main in ~/OpenFOAM/OpenFOAM-v1812/platforms/linux64GccDPInt32Opt/bin/chtMultiRegionFoam [0] #11 __libc_start_main in ~/OpenFOAM/OpenFOAM-v1812/platforms/linux64GccDPInt32Opt/bin/chtMultiRegionFoam [VM:09945] *** Process received signal *** [VM:09945] Signal: Floating point exception (8) [VM:09945] Signal code: (-6) [VM:09945] Failing at address: 0x3e8000026d9 [VM:09945] [ 0] /lib/x86_64-linux-gnu/libc.so.6(+0x3ef20)[0x7f7eb1395f20] [VM:09945] [ 1] /lib/x86_64-linux-gnu/libc.so.6(gsignal+0xc7)[0x7f7eb1395e97] [VM:09945] [ 2] /lib/x86_64-linux-gnu/libc.so.6(+0x3ef20)[0x7f7eb1395f20] [VM:09945] [ 3] /home/administrator/OpenFOAM/OpenFOAM-v1812/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so(_ZN4Foam6divideERNS_5FieldIdEERKNS_5UListIdEES6_+0xae)[0x7f7eb2a0228e] [VM:09945] [ 4] /home/administrator/OpenFOAM/OpenFOAM-v1812/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so(_ZN4FoamdvERKNS_5UListIdEES3_+0x54)[0x7f7eb2a04674] [VM:09945] [ 5] /home/administrator/OpenFOAM/OpenFOAM-v1812/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so(_ZNK4Foam14diagonalSolver5solveERNS_5FieldIdEERKS2_h+0x4e)[0x7f7eb27be34e] [VM:09945] [ 6] [VM:09944] *** Process received signal *** [VM:09944] Signal: Floating point exception (8) [VM:09944] Signal code: (-6) [VM:09944] Failing at address: 0x3e8000026d8 in ~/OpenFOAM/OpenFOAM-v1812/platforms/linux64GccDPInt32Opt/bin/chtMultiRegionFoam in /lib/x86_64-linux-gnu/libc.so.6 [3] #12 /home/administrator/OpenFOAM/OpenFOAM-v1812/platforms/linux64GccDPInt32Opt/lib/libfiniteVolume.so(_ZN4Foam8fvMatrixIdE15solveSegregatedERKNS_10dictionaryE+0x187)[0x7f7eb4f8c417] [VM:09945] [ 7] [VM:09944] [ 0] /lib/x86_64-linux-gnu/libc.so.6(+0x3ef20)[0x7f7a51c81f20] [VM:09944] [ 1] /lib/x86_64-linux-gnu/libc.so.6(gsignal+0xc7)[0x7f7a51c81e97] [VM:09944] [ 2] /home/administrator/OpenFOAM/OpenFOAM-v1812/platforms/linux64GccDPInt32Opt/lib/libfiniteVolume.so(_ZN4Foam8fvMatrixIdE24solveSegregatedOrCoupledERKNS_10dictionaryE+0x3a5)[0x7f7eb4ad8215] [VM:09945] [ 8] /lib/x86_64-linux-gnu/libc.so.6(/home/administrator/OpenFOAM/OpenFOAM-v1812/platforms/linux64GccDPInt32Opt/lib/libfiniteVolume.so(_ZNK4Foam6fvMesh5solveERNS_8fvMatrixIdEERKNS_10dictionaryE+0x23)[0x7f7eb4a7bff3] [VM:09945] [ 9] +0x3ef20)[0x7f7a51c81f20] [VM:09944] chtMultiRegionFoam(_ZN4Foam8fvMatrixIdE5solveEv+0xe0)[0x55d8e315e0f0] [VM:09945] [10] chtMultiRegionFoam(+0x50da0)[0x55d8e312bda0] [VM:09945] [11] [ 3] /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xe7)[0x7f7eb1378b97] [VM:09945] [12] chtMultiRegionFoam(+0x5588a)[0x55d8e313088a] [VM:09945] *** End of error message *** /home/administrator/OpenFOAM/OpenFOAM-v1812/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so(_ZN4Foam6divideERNS_5FieldIdEERKNS_5UListIdEES6_+0xae)[0x7f7a532ee28e] [VM:09944] [ 4] /home/administrator/OpenFOAM/OpenFOAM-v1812/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so(_ZN4FoamdvERKNS_5UListIdEES3_+0x54)[0x7f7a532f0674] [VM:09944] [ 5] /home/administrator/OpenFOAM/OpenFOAM-v1812/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so(_ZNK4Foam14diagonalSolver5solveERNS_5FieldIdEERKS2_h+0x4e)[0x7f7a530aa34e] [VM:09944] [ 6] /home/administrator/OpenFOAM/OpenFOAM-v1812/platforms/linux64GccDPInt32Opt/lib/libfiniteVolume.so(_ZN4Foam8fvMatrixIdE15solveSegregatedERKNS_10dictionaryE+0x187)[0x7f7a55878417] [VM:09944] [ 7] /home/administrator/OpenFOAM/OpenFOAM-v1812/platforms/linux64GccDPInt32Opt/lib/libfiniteVolume.so(_ZN4Foam8fvMatrixIdE24solveSegregatedOrCoupledERKNS_10dictionaryE+0x3a5)[0x7f7a553c4215] [VM:09944] [ 8] /home/administrator/OpenFOAM/OpenFOAM-v1812/platforms/linux64GccDPInt32Opt/lib/libfiniteVolume.so(_ZNK4Foam6fvMesh5solveERNS_8fvMatrixIdEERKNS_10dictionaryE+0x23)[0x7f7a55367ff3] [VM:09944] [ 9] chtMultiRegionFoam(_ZN4Foam8fvMatrixIdE5solveEv+0xe0)[0x55cbfb7bb0f0] [VM:09944] [10] chtMultiRegionFoam(+0x50da0)[0x55cbfb788da0] [VM:09944] [11] /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xe7)[0x7f7a51c64b97] [VM:09944] [12] chtMultiRegionFoam(+0x5588a)[0x55cbfb78d88a] [VM:09944] *** End of error message *** in /lib/x86_64-linux-gnu/libc.so.6 [0] #12 ?? in ~/OpenFOAM/OpenFOAM-v1812/platforms/linux64GccDPInt32Opt/bin/chtMultiRegionFoam [VM:09946] *** Process received signal *** [VM:09946] Signal: Floating point exception (8) [VM:09946] Signal code: (-6) [VM:09946] Failing at address: 0x3e8000026da [VM:09946] [ 0] /lib/x86_64-linux-gnu/libc.so.6(+0x3ef20)[0x7f044a4e1f20] [VM:09946] [ 1] /lib/x86_64-linux-gnu/libc.so.6(gsignal+0xc7)[0x7f044a4e1e97] [VM:09946] [ 2] /lib/x86_64-linux-gnu/libc.so.6(+0x3ef20)[0x7f044a4e1f20] [VM:09946] [ 3] /home/administrator/OpenFOAM/OpenFOAM-v1812/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so(_ZN4Foam6divideERNS_5FieldIdEERKNS_5UListIdEES6_+0xae)[0x7f044bb4e28e] [VM:09946] [ 4] /home/administrator/OpenFOAM/OpenFOAM-v1812/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so(_ZN4FoamdvERKNS_5UListIdEES3_+0x54)[0x7f044bb50674] [VM:09946] [ 5] /home/administrator/OpenFOAM/OpenFOAM-v1812/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so(_ZNK4Foam14diagonalSolver5solveERNS_5FieldIdEERKS2_h+0x4e)[0x7f044b90a34e] [VM:09946] [ 6] /home/administrator/OpenFOAM/OpenFOAM-v1812/platforms/linux64GccDPInt32Opt/lib/libfiniteVolume.so(_ZN4Foam8fvMatrixIdE15solveSegregatedERKNS_10dictionaryE+0x187)[0x7f044e0d8417] [VM:09946] [ 7] /home/administrator/OpenFOAM/OpenFOAM-v1812/platforms/linux64GccDPInt32Opt/lib/libfiniteVolume.so(_ZN4Foam8fvMatrixIdE24solveSegregatedOrCoupledERKNS_10dictionaryE+0x3a5)[0x7f044dc24215] [VM:09946] [ 8] /home/administrator/OpenFOAM/OpenFOAM-v1812/platforms/linux64GccDPInt32Opt/lib/libfiniteVolume.so(_ZNK4Foam6fvMesh5solveERNS_8fvMatrixIdEERKNS_10dictionaryE+0x23)[0x7f044dbc7ff3] [VM:09946] [ 9] chtMultiRegionFoam(_ZN4Foam8fvMatrixIdE5solveEv+0xe0)[0x55ca46a6b0f0] [VM:09946] [10] chtMultiRegionFoam(+0x50da0)[0x55ca46a38da0] [VM:09946] [11] /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xe7)[0x7f044a4c4b97] [VM:09946] [12] chtMultiRegionFoam(+0x5588a)[0x55ca46a3d88a] [VM:09946] *** End of error message *** in ~/OpenFOAM/OpenFOAM-v1812/platforms/linux64GccDPInt32Opt/bin/chtMultiRegionFoam [VM:09943] *** Process received signal *** [VM:09943] Signal: Floating point exception (8) [VM:09943] Signal code: (-6) [VM:09943] Failing at address: 0x3e8000026d7 [VM:09943] [ 0] /lib/x86_64-linux-gnu/libc.so.6(+0x3ef20)[0x7fa38ba79f20] [VM:09943] [ 1] /lib/x86_64-linux-gnu/libc.so.6(gsignal+0xc7)[0x7fa38ba79e97] [VM:09943] [ 2] /lib/x86_64-linux-gnu/libc.so.6(+0x3ef20)[0x7fa38ba79f20] [VM:09943] [ 3] /home/administrator/OpenFOAM/OpenFOAM-v1812/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so(_ZN4Foam6divideERNS_5FieldIdEERKNS_5UListIdEES6_+0xae)[0x7fa38d0e628e] [VM:09943] [ 4] /home/administrator/OpenFOAM/OpenFOAM-v1812/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so(_ZN4FoamdvERKNS_5UListIdEES3_+0x54)[0x7fa38d0e8674] [VM:09943] [ 5] /home/administrator/OpenFOAM/OpenFOAM-v1812/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so(_ZNK4Foam14diagonalSolver5solveERNS_5FieldIdEERKS2_h+0x4e)[0x7fa38cea234e] [VM:09943] [ 6] /home/administrator/OpenFOAM/OpenFOAM-v1812/platforms/linux64GccDPInt32Opt/lib/libfiniteVolume.so(_ZN4Foam8fvMatrixIdE15solveSegregatedERKNS_10dictionaryE+0x187)[0x7fa38f670417] [VM:09943] [ 7] /home/administrator/OpenFOAM/OpenFOAM-v1812/platforms/linux64GccDPInt32Opt/lib/libfiniteVolume.so(_ZN4Foam8fvMatrixIdE24solveSegregatedOrCoupledERKNS_10dictionaryE+0x3a5)[0x7fa38f1bc215] [VM:09943] [ 8] /home/administrator/OpenFOAM/OpenFOAM-v1812/platforms/linux64GccDPInt32Opt/lib/libfiniteVolume.so(_ZNK4Foam6fvMesh5solveERNS_8fvMatrixIdEERKNS_10dictionaryE+0x23)[0x7fa38f15fff3] [VM:09943] [ 9] chtMultiRegionFoam(_ZN4Foam8fvMatrixIdE5solveEv+0xe0)[0x55e82c06c0f0] [VM:09943] [10] chtMultiRegionFoam(+0x50da0)[0x55e82c039da0] [VM:09943] [11] /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xe7)[0x7fa38ba5cb97] [VM:09943] [12] chtMultiRegionFoam(+0x5588a)[0x55e82c03e88a] [VM:09943] *** End of error message *** |
August 28, 2019, 02:25 |
Rep Power: 21 |
This is a bug in paraView. ParaView is not able to display the values at the boundary from the boundary condition. This is because it is a mixed boundary condition, which paraView does not display correctly. Hence it extrapolates those values. Nevertheless the profile should be correct. It should only be the value at the face itself which is not zero. You can see that this is the case if you load the face itself.
After opening the case with paraFoam -builtin check the walls under mesh regions and not just the internalMesh. You should see a zero velocity |
August 29, 2019, 09:20 |
#5 | |
Rep Power: 7 |
paraFoam -builtin I used the following commands to get the heat flux over the shared interface: Code:
chtMultiRegionSimpleFoam -postProcess -func wallHeatFlux -region one -latestTime chtMultiRegionSimpleFoam -postProcess -func wallHeatFlux -region two -latestTime Code:
wallHeatFlux wallHeatFlux write: writing field wallHeatFlux min/max/integ(wall) = 0, 0, 0 min/max/integ(one_to_two) = 971.472, 2360.53, 950.336 Code:
wallHeatFlux wallHeatFlux write: writing field wallHeatFlux min/max/integ(wall) = 0, 0, 0 min/max/integ(two_to_one) = 122167, 436310, 118863 |
August 29, 2019, 09:36 |
Rep Power: 21 |
It seems that there is a heat flow between the regions. The numbers for two_to_one one_to_two should be identical (are you using a radiation model?).
That they are not zero and not identical can results from a few things
even without heat sources your flow can heat up due to density changes, kinetic energy changes etc Check your temperature field. And evaluate if this is a significant value for your simulation. Maybe 118863W are basically zero for your case. |
chtmultiregionsimplefoam, noslip, openfoam 1812, salome |
How to use the CFX periodic interface | zhihuawan | CFX | 61 | January 15, 2018 16:20 |
Problem in setting Boundary Condition | Madhatter92 | CFX | 12 | January 12, 2016 04:39 |
GETVAR Error in Multiband Monte Carlo Radiation Simulation with Directional Source | silvan | CFX | 3 | June 16, 2014 09:49 |
slip boundary condition within an AMI interface | louisgag | OpenFOAM Running, Solving & CFD | 0 | November 26, 2013 05:28 |
Low Mixing time Problem | Mavier | CFX | 5 | April 29, 2013 00:00 |
