large particle modeling solver with openfoam
Like Tree3Likes
  • 1 Post By cryabroad
  • 2 Post By akidess
Old   August 16, 2019, 17:39
Default large particle modeling solver with openfoam
Virtual-iCFD is on a distinguished road
Hi foamers,
I am looking for a solver in openfoam similar to MPM (Macroscopic Particle Model) in Fluent. The goal is to model 2-phase flow where dispersed particle size is larger than local cell size. My understanding is DPM (Discrete Phase Model) isn't sufficient to model this large particle approach. What OF solver should I look for?
Thanks!
Virtual-iCFD is offline   Reply With Quote
Old   August 19, 2019, 05:26
Ruiyan Chen
cryabroad is on a distinguished road
I doubt that OpenFOAM has such solvers, but I hope that there are existing solvers that deal with such problems! You may need to implement one by yourself.
The MPM in Fluent uses the Immersed Boundary Method, and I believe it uses a linear interpolation between the fluid velocity and the solid velocity. If you are not familiar with IBM you can take a look at some review papers first.
Virtual-iCFD likes this.
cryabroad is offline   Reply With Quote
Old   August 19, 2019, 10:57
akidess's Avatar
Anton Kidess
There is an IBM in the community version of OpenFOAM:
https://openfoamwiki.net/index.php/E...mersedBoundary
Better even, the CFD-DEM toolkit also provides an IBM method for large particles:
https://www.cfdem.com/resolved-cfd-d...ersed-boundary
Virtual-iCFD and cryabroad like this.
*On twitter @akidTwit
*Spend as much time formulating your questions as you expect people to spend on their answer.
large particle, multiphase flow, openfoam
Map of the OpenFOAM Forum - Understanding where to post your questions! wyldckat OpenFOAM 10 September 2, 2021 06:29
Radiation Modeling Using Discrete Ordinates Method and Parallel Solver malicemethods FLUENT 3 May 25, 2018 15:25
Particle tracking error alchem OpenFOAM Bugs 5 May 6, 2017 17:30
OpenFOAM v3.0+ ?? SBusch OpenFOAM 22 December 26, 2016 15:24
Does OpenFoam have an appropriate solver for particle collision into a water droplet? Hossein1 OpenFOAM Running, Solving & CFD 3 October 10, 2015 09:28
