change boundary condition when switching solver
Like Tree1Likes
  • 1 Post By sufjanst
Old   August 8, 2019, 22:52
Default change boundary condition when switching solver
Virtual-iCFD is on a distinguished road
Hi Foamers,
I first solve the model with potentialFOAM and then solve with simpleFOAM for a internal pipe flow.
Since my boundary condition I set up in simpleFOAM is both pressure inlet and pressure outlet, it won't solve the initial flow field using potentialFOAM. I changed inlet BC to inlet velocity.
After solving potential flow-field, i want to switch to solve simpleFOAM but now i need to change to original BC with pressure inlet instead of inlet velocity.
What is the file i need to make change? I tried to replace the folder 0 from my simpleFOAM to potentialFOAM once i completed my potentialFOAM computation but the simpleFOAM solver seems to ignore the new pressure inlet BC and still regard the inlet as velocity inlet.
Does anyone would know how I can do this correctly?
Thanks,
Virtual-iCFD is offline   Reply With Quote
Old   August 9, 2019, 16:53
I am providing more details of the boundary conditions files i used.
The problem i am solving is pressure driven flow so in simplefoam i need to use both inlet and outlet pressure.
however, for initial flow field i need reasonable one to run simpleFOAM but with both inlet and outlet pressure, i don't know how to initialize such flow field.
Here is the BC files i use for calculating potentialFOAM
HTML Code:
FoamFile
	version 2.0;
	format binary;
	class volVectorField;
	location "";
	object U;
dimensions [0 1 -1 0 0 0 0];
internalField uniform ( 0. 0. 0. );
boundaryField
	outlet
		type zeroGradient;
	inlet
		type            uniformFixedValue;
        	uniformValue    constant (0 0 -0.2);
	post1
		type 		fixedValue;
		value		uniform (0 0 0);
	post2
		type            fixedValue;
	post3
		type            fixedValue;
	post4
		type            fixedValue;
	post5
		type            fixedValue;
	post6
		type            fixedValue;
	wall1
		type            fixedValue;
	wall2
		type            fixedValue;
HTML Code:
FoamFile
	version 2.0;
	format binary;
	class volScalarField;
	location "";
	object p;
dimensions [0 2 -2 0 0 0 0];
internalField uniform 0.;
boundaryField
	outlet
		type            fixedValue;
        	value           uniform 0;
	inlet
		type zeroGradient;
	post1
		type zeroGradient;
	post2
		type zeroGradient;
	post3
		type zeroGradient;
	post4
		type zeroGradient;
	post5
		type zeroGradient;
	post6
		type zeroGradient;
	wall1
		type zeroGradient;
	wall2
		type zeroGradient;
Here is the BC files i use for calculating simpleFOAM
HTML Code:
FoamFile
	version 2.0;
	format binary;
	location "";
	object U;
boundaryField
	outlet
		type zeroGradient;
	inlet
		type zeroGradient;
	post1
		type 		fixedValue;
	post2
		type            fixedValue;
	post3
		type            fixedValue;
	post4
		type            fixedValue;
	post5
		type            fixedValue;
	post6
		type            fixedValue;
	wall1
		type            fixedValue;
	wall2
		type            fixedValue;
HTML Code:
FoamFile
	version 2.0;
	format binary;
	location "";
	object p;
boundaryField
	outlet
		type            fixedValue;
        	value           uniform 0;
	inlet
		type            fixedValue;
        	value           uniform 865.470938;
	post1
		type zeroGradient;
	post2
		type zeroGradient;
	post3
		type zeroGradient;
	post4
		type zeroGradient;
	post5
		type zeroGradient;
	post6
		type zeroGradient;
	wall1
		type zeroGradient;
	wall2
		type zeroGradient;
Old   August 14, 2019, 04:50
sufjanst is on a distinguished road
When you run potentialFoam, the u-File in you "0" folder will be modified (so make sure to make a backup).
If you open the modified u file you will first see the values for "internalField". If you scroll down to the end of the file you can set up the bounday conditions (I would recommend using nedit for editing because the file can be very long).
Remember to delete phi in "0" after running potentialFoam, otherwise you will get an error in simpleFoam.
Virtual-iCFD likes this.
sufjanst is offline   Reply With Quote
Old   August 14, 2019, 06:02
anonymous
simrego is on a distinguished road
Hi!
Use changeDictionary. And change only the type of your BC, nothing else (Also leave the internal field as it is). It should works. But there is a newer utility for changing dictionaries but honestly I have never used it. It is called foamDictionary if i'm correct.
simrego is offline   Reply With Quote
change boundary condition, potentialfoam, simplefoam
How to change boundary condition from command fluent87 FLUENT 8 September 11, 2019 14:27
Constant mass flow rate boundary condition sahm OpenFOAM 0 June 20, 2018 23:45
fluent divergence for no reason sufjanst FLUENT 2 March 23, 2016 17:08
problem of implementing a new solver with a special boundary condition huyidao OpenFOAM Programming & Development 0 April 27, 2015 09:24
Star cd es-ice solver error ernarasimman STAR-CD 2 September 12, 2014 01:01
