Rep Power: 16 ![]() |
Hi foamer,
I experienced the pisoFOAM crashes and am wondering any workaround on this issue. Thanks, Cheers, Pete reate time Create mesh for time = 0 PISO: Operating solver in PISO mode Reading field p Reading field U Reading/calculating face flux field phi Selecting incompressible transport model Newtonian Selecting turbulence model type laminar Selecting laminar stress model Stokes No MRF models present No finite volume options present Starting time loop Time = 1e-05 Courant Number mean: 0 max: 0 smoothSolver: Solving for Ux, Initial residual = 0, Final residual = 0, No Iterations 0 smoothSolver: Solving for Uy, Initial residual = 0, Final residual = 0, No Iterations 0 smoothSolver: Solving for Uz, Initial residual = 1, Final residual = 9.62803e-06, No Iterations 66 GAMG: Solving for p, Initial residual = 1, Final residual = 0.0317079, No Iterations 1 time step continuity errors : sum local = 0.0574054, global = -0.0364258, cumulative = -0.0364258 GAMG: Solving for p, Initial residual = 0.0438414, Final residual = 9.43287e-07, No Iterations 43 time step continuity errors : sum local = 3.30835e-06, global = -1.73591e-07, cumulative = -0.036426 ExecutionTime = 47.94 s ClockTime = 48 s Time = 2e-05 Courant Number mean: 0.490971 max: 1208.82 [17] #0 Foam::error: ![]() [17] #1 Foam::sigFpe::sigHandler(int) at ??:? [17] #2 ? in "/lib64/libc.so.6" [17] #3 Foam::GaussSeidelSmoother::smooth(Foam::word const&, Foam::Field<double>&, Foam::lduMatrix const&, Foam::Field<double> const&, Foam::FieldField<Foam::Field, double> const&, Foam::UPtrList<Foam::lduInterfaceField const> const&, unsigned char, int) at ??:? [17] #4 Foam::GaussSeidelSmoother::smooth(Foam::Field<doub le>&, Foam::Field<double> const&, unsigned char, int) const at ??:? [17] #5 Foam::smoothSolver::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const at ??:? [17] #6 ? at ??:? [17] #7 ? at ??:? [17] #8 ? at ??:? [17] #9 ? at ??:? [17] #10 __libc_start_main in "/lib64/libc.so.6" [17] #11 ? at ??:? |
Rep Power: 8 ![]() |
Your courant number is very high it shouldn't be greater than 1 for PISO algorithm.
Just decrease your time step. You cannot use adjustTimeStep and maxCo with pisoFoam unless you modify the original files to add this features. In other hand, pimpleFoam can be run essentially as pisoFoam by setting nOuterCorrectors to 1. you can add this to system/controlDict: Code:
adjustTimeStep on; maxCo 0.5; |
Robert
Rep Power: 12 ![]() |
I'd guess something is wrong with your geometry.
If you liked my answer to your question, please consider leaving a "Like" in return ![]() |
openfoam 5.0, picofoam |
Differences in solution method for pisoFoam and buoyantBoussinesqPisoFoam | mchurchf | OpenFOAM | 7 | August 6, 2023 09:12 |
PisoFoam error: mpirun Exit Code | Jinjolee | OpenFOAM | 3 | April 29, 2019 07:10 |
simpleFoam simulation with mesh from Pointwise crashes immediately | Artur | OpenFOAM Running, Solving & CFD | 5 | September 4, 2015 10:50 |
flo-efd v11.0.0 crashes | YoavF | FloEFD, FloWorks & FloTHERM | 3 | June 21, 2012 12:37 |
pisoFoam compiling error with OF 1.7.1 on MAC OSX | Greg Givogue | OpenFOAM Programming & Development | 3 | March 4, 2011 17:18 |
